I put together an EFIE from Redmeanie's kit, had some problems with implementation so I looked back on the forums here and realized that my VR2 output was still set to 1.0V from the bench test.
I have found the documentation to be quite confusing, so I started this thread to hopefully bring some clarity through conversation.
Here is how I understand the process beginning on the bench:
1 - apply 12V power to the board
2 - apply 500mv test voltage to signal line that will be coming in from O2 sensor
3 - Set rotary switch to richest position
4 - Wait about 3 mins for the circuit to start operating
5 - adjust VR1 so that the LED just comes on
6 - adjust VR2 so that output line (to go to ECU) reads 1.0V
7 - reduce 500mv test voltage down until the LED goes out
8 - check to see that output line voltage drops to zero, if it does then the circuit is working correctly.
OK, I'm pretty sure about it up to here, please correct any mistakes:
9 - make sure the rotary switch is still in richest position.
10 - adjust the test voltage back up to 500mv, the LED comes on
11 - re-adjust VR2 to output 400mv.
12 - install EFIE in the vehicle
13 - With booster running and efie active, try driving at full rich position on rotary switch.
14 - keep leaning out the fuel mixture using the rotary switch one position at a time and trying it out, when you start to have acceleration problems or stalling, back the switch off one position.
Since I had my VR2 set to 1.0V still, when the O2 sensor sent any signal greater than 500mv to the EFIE, the EFIE would send 1.0V to the ecu.
The ecu then 'thinks' the fuel mixture is rich and reduces fuel to the engine.
Correct?
Correct?
