Dear Gentlemen,
As a professional with more than 15 years of experience in academia and industry, I have to say that all this story about Bi Toroidal Transformer and efficiency above 100% (even above 1000%!!!) is absolutely nonsense. All of us very well know that efficiency cannot be above 100%. That is the fact. All the tests and measurements done by third party (Dr. Fusina from Defense Research Lab) are also completely wrong. I asked Thane to send me one transformer to do test and measure real efficiency, but it seems, he does not like that idea.
What he made is just a transformer with very high leakage inductance, nothing else. That is reason why the power factor is almost zero. And, to measure the input power when the power factor is also zero is very difficult. Especially difficulty using primitive method and equipment he uses. The input power must be measured using completely different methodology. Then, you will see, the efficiency is not above 100%, not at all. If I have a chance to have transformer to test it, I will post the real efficiency data.
How many atheists show up in church only to proclaim to the congregation that they are fools for believing in God?
Answer: None
Church is a place of communal worship. The atheist isn't interested in worshiping God because he doesn't believe in God.
However, if the atheist did show up at church and cause such a ruckus, he would most likely be summarily tossed out on his ear.
Now we are gathered here at this forum to discuss concepts and devices which relate to the concept of overunity.
That is the purpose of why we are gathered here at this forum.
Ive been reading a bit about BTT lately, but I have wondered if anyone here has tried to replicate the Gabriel device with any luck? It is based on the same principle ie protecting the primary dipole against negative flux feedback but uses a different geometry. Sorry no link or explanation, but it is easily googled and they can explain it much better than i could ever.
Dear Gentlemen,
Could someone send me one too.
gimme a break build your own.
Dear Gentlemen,
Hi pgrbovic. Welcome to the forum. I have done some testing with the bi-toroid transformer concept, and although my setup may have been a fair bit off from the ideal (Thane Heins didn't provide enough details in his patent application to determine what the ideal configuration might be), I did not see over 100% efficiency in my own tests.
You mentioned that there is a special measurement method required for measuring power when power factor is very low. Can you give a little bit of an overview of what that method is, and how it differs from say just measuring the phase angle between the current and voltage waveforms on an oscilloscope screen?
