Sephiroth's Monopole Radiant Energizer
  • Sephiroth's Monopole Radiant Energizer
    Right Guys...
    This has only been in existance for an hour so I can't say I know much about it yet but it is generating a form of electricity that behaves in a very very unusual way which I believe is pure radiant energy.
    The schematic is attached. I think of it as "distilling" the output.
    A brief summary of the additional componants.
    The MJL21194 transistor is triggered by a standard reed switch with a 400 ohm resistor in series.
    the coil if bifilar wound with 22 guage wire litzed (BY HAND!!! I spent 8 hours yesterday litzing the wire 1 foot at a time as I wound the coil!) approximatly 850 turns with 5-10 twists per inch.
    the core is iron filings mixed with epoxy resin.
    the capacitor WAS 165,000uf but that fried pretty fast since it was only rated for 16 volts so now it is a 40,000uf cap.
    the bridge rectifier is made from 4 x 1N4007 diodes.
    The additional coil is a small 1000 turn (approx) air core coil made from 28 guage wire.
    The caps are discharged with a relay set to discharge for 1/100 of a second every 2 seconds. (but I don't think that is important)
    I think that's everything...
    ANYWAY.... the odd behavior of the output...
    When connected to the capacitor and relay directly, the battery voltage shoots up to over 15 volts (but fluctuates) and is independant of the relay being open or closed. Basically regardless of whether the relay is open or closed that is the voltage reading across the charging battery's terminals.
    so you'll notice in the schematic that I have added a diode between the capacitor and the charging battery. When that diode is present the battery voltage acts "normally" ie. jumps up when the relay closes but sits on 12.35 volts. Don't know if that is a good thing
    and even though there is only 15 volts being read, a neon will light with just one of the legs attached to either the postive or negative of the batteries or capacitor while I hold the other leg.
    But it get's better... it will also light an LED in exactly the same way! This is exciting because it will light despite which leg I connect on the LED. Remember an LED is a diode (so current can only flow in one direction) so this means that energy is being drawn into the system from outside!
    Another bizarre thing is that if I place my hand over the "conversion coil" (the one seperate from the stator) I can feel a cold breeze coming from the hollow core for a distance of about 4 inches then it becomes unnoticable. However there doesn't appear to be any movement of air.
    I can connect one lead from a voltmeter and get a 5v reading while the other lead is attached to nothing. I can attach one lead of an ampmeter and it reads 1 amp while the other leg is attached to nothing. I believe these are errors with the meters since a small filament bulb won't light with one leg attached.
    The oscilloscope is showing instant discharge of the flyback voltage but the spike is too high to capture on the oscilloscope so I don't know what its voltage is.
    So far I am not seeing any amazing charging effects. It will take a few days to get results on it's COP.
    It is drawing approx 200ma.
    so.... what do you think?
    Nikola Tesla
    Sephiroth
    sound nice very nice, congrats for your claim in this research.....
    Ok.
    1. You has elimaminated the trigger coil. (Direct reed switch)
    2. You extract the energy by magnets passes, (before trigger coil)....
    3. Rectifies the electricity by bridge....
    4. Feeding another coil, with DC pulses, that is new for me
    4. Interesanting setup diode, cap diode. That I like..... - > (Source Power supply)
    5. 555 discharge capacitor on the batt. Another Back EMF is produced, that explains me the point 4.
    Good very very good, I love your setup. I would replicate it in small version
    My question is: What if the rotor is NSNS magnets?
    Steve Jobs. Apple CEO
      the rotor is currently in the super pole configuration though I don't think that matters.
      What it is doing is sending the flyback voltage from the primary coil through the "conversion coil" (can't think of a name for it so that will do). Because this coil holds back the amp draw the flyback voltage is instantanious and very high voltage. the flyback from the "conversion coil" is then sent into the capacitors where it is then discharged directly (unless you count the diode) to the charging batteries.
      Don't think it is charging batteries any better in this configuration but it is very odd! Especially the LED!
      Nikola Tesla
        Hmm but, the Back EMF produced by the power coil is loseed?
        charging coil catch back emf and reed switch no shows so much spark or with diode on collector's transistor, can you catch that energy too?
          Hi Sephiroth,
          I like the inductor and cap setup before discharge to the charge battery.What size batteries are you using?.Can you tell us what voltage the caps reach before the discharge.Also do you think it might be possible to take the collapsing of the trigger and also use that to the recovery side?,Someone was asking this question in one of the other threads but I cant remember if anyone replied to that.Interesting affects anyways.thx for the input .
          -Gary
            Sort of... in the same way that all the energy we input from the battery is lost.
            I have tried combining the output from both the recovery coil and the primary coil on a different model but still not sure whether it increases the charge rate. As long as you have a good recovery coil you wouldn't need to collect the flyback from the collector.
            Nikola Tesla
              Yeah Sephiroth...
              it can be easy charge another cap with the collapse on reed switch and relay has NC and ND contacts you can use the second contacts to discharge the second cap on the battery.
                Originally posted by gmeat View Post
                Hi Sephiroth,
                -Gary
                At the moment the charging battery is a 7.2ah Deep Cycle battery.
                Without the diode between the caps and the charging battery the voltage in the caps stays equal with the charging battery... very odd. With the diode inbetween it behaves normally and the caps charge between 1-2 volts above the charging voltage before discharging.
                I'm not sure if it is possible to collect the flyback from the trigger winding as that would mean the base of the transistor is connected to the primary battery's positive and so the motor wouldn't operate. Or at least the transistor will remain in a constant "on" state.
                Nikola Tesla
                  sorry about the poor quality of the vid... looks better before I uploaded it to youtube!
                  YouTube - Radiant Energy?
                  Nikola Tesla
                    Ok Sep,
                    Im a little confused as to your configuration. The third coil (the one that is SHORTING your cap permanently it seems?) is placed where in regards to the Energizer? IS it receiving induction from the rotating wheel? I would think that your placement of the coil would infact cause the cap to conduct at all times, pretty much making the "cap pulser" part void. Have you tried that coil in series on the backend? You could have the cap fill up and then be timed for a large discharge into another coil which is placed on the wheel.
                    In regards to digital multimeters, as you already aware they act the goose every now and then. Id get my hands on a good analogue gauge for verification.
                    Good to see you trying something different!
                      ren, i agree something is not right... but it is still doing odd things..
                      examining it piece by piece!
                      Nikola Tesla
                        wierd... it is wired as in the schematic, but the result is only apparant when the front end is connected to ground.... still investigating... it doesn't make sense...
                        Nikola Tesla
                          nope.... haven't a clue what is causing it... doesn't appear to be charging batteries either....
                          Nikola Tesla
                          • #14
                            well, sorry for the anti climax guys, but it appears I can reproduce the effect by connecting the positive output to the charging battery but leaving the negative output detached while the front end is connected to earth (positive or negative side, doesn't matter)...
                            Still think this is Tesla's radiant, but it isn't my set up that's causing it! oh well, back to the drawing board.
                            Nikola Tesla
                            • #15
                              multicoil
                              Hi Sephitoth that multicoil schematic is good that you've posted in Bedini SG forum pg21 #619 permalink?
                              Cause when I did it the primary coil is singing and rotor stopped.
                              Any help please?
