Well here it is....
My Current Limiting PWM! It is available in Kit Form and Ready Built for now.
$35.00 Kit
$60.00 Ready Built and tested
This is unique to others...If you set a certain current, and the limits are approached, it will back off the Duty cycle to keep in under the set current, plus it has FULL Mosfet Drive capability. It has Current control, Duty Cycle, and Frequency control.It uses a 100 AMP HexFet so it will be able to handle any booster, and running at 20amps it is very reliable and efficient. I have put this design through serious testing and have no problems.
The picture show my prototype that just has the Ground for the Booster coming off of it, but the new update has both + and - for your cell so it is super easy to hook up.
Also I have off board Trimpots available for those that want to put this in a case and have easily accessible controls, so if you want these, let me know and add $2 to your order.
Next I have redesigned the EFIE for a single Dual Efie design, basically both EFIE's on one board. This makes it easier for location selection and hook up. This is available for the original price of $40 per kit $60 Built.
Also the Single EFIE is available still along with the other PWM's at the original same price.
I am steering away from the rotary switches for selection and shifting to 3 way slide switches. Each selection on these 3 ways can preset to whichever setting you wish based off of simple dip switch settings. I think all of you will like this better because this slide switch can be stealthily installed anywhere on your dash cluster and is frankly more reliable than the rotary.
Keep in mind the built version, is just the electronics portion built (as shown in the pics). The switches are not installed, due to your particular set-up and installation. I do include some MUCH improved instructions on how to hook these up, and these are pretty much idiot proof.
I will be putting up a link to a URL that my ISP provided me with so it will be easier to order in the future. I will post it as soon as it's done (hopefully this weekend). It will be www.redmeanie.com.I will make everything that you will need for a "Booster" installation available. Like Relay's, Switches and the like that have all been tested and are all reliable brands.
Until then just send payment like before via Paypal to mira@creative-concepts.us
I will also be finishing up the Mixture Display also, which will run around $17 for the kit. It is super small and adjustable, so that you can shift what you feel is safe for your setup.
Thanks all of you for your input, and I feel these devices are all THAT ANYONE IN THE "BOOSTER" realm should need. However if you have any ideas let me know and I can help make it a reality!
Lee & Mira
$35.00 Kit
Lee & Mira
