Might this be how the Muller generator works?
  • #31
    BEMF timed pickup coils
    And would it be better if BEMF pickup coils were bifilar?
    • #32
      sneek en peek
      hi guy i see finally a discussion on the muller motor
      i am in the proses of building one. it was a bit of a hassle to get all the stuff
      but i am getting to the point of the 1e test. so for now here is a little sneak end peek
      The radiant energy is here!
      The energy revolution is now!
      Ray0energy
      http://www.youtube.com/profile?user=ray0energy
      • #33
        muller RV cobi
        A while ago there was a great web page with lots of pictures and videos of the Muller generator, his coils and motors. Also I think that Peter was in some of those videos, at least judging from the voices that I heard The page was free energy generator magnet motor at theverylastpageoftheinternet.com, unfortunatelly it does not work anymore. It is a shame that I did not download all the videos and pictures from that site when I had a chance. Maybe someone has downloaded these images and videos and can share them? Ash? One of such videos can be seen here:
        YouTube - Bill Muller Coiltest
        Here he is holding a coil that is attached to a 300W light bulb. When he puts the coil near the spinning magnets, the light bulb starts to light up brightly. If the coil core was ordinary iron, then I don't think that he would be able to hold that coil near the magnets so easy, especially since those are big, strong neo magnets. So apearantly the core material does make a huge difference. On that web page I also saw a pocture of one of his coils cut in half. That coil was wound with very heavy gauge wire and there was only about hundered or less turns. So I guess that he was using a different switching method than that what I proposed, because with my method you needed many turns on the coil so that the resistance is high enough to start generating those HV spikes. On the other hand, I was using weak ceramic magnets and my RPM's were only about 300-400, because I could not go too fast as the relay could not keep up with greater speeds. Mr. Muller is using strong neo magnets and the RPM's of his generator are very high, judging from the sound, I would say about 4000-6000. Maybe at those speeds and magnets that strong, it is still possible to generate those HV spikes at lower coil turn number. Also since the spikes coming out of the coil are the same radiant spikes, it is understandabler why the wire gauge is so big - radiant spike likes big wires, that is why John Bedini uses heavy bus bars that connect his big 12pole machine to the charging batteries.
        Here are some pictures from the MULLERPOWER.com ... advancing the legacy of Bill Muller's work in Motor/Generators... page:
        This is the same test as in that video
        Found another video:
        YouTube - More than 200 amps!!
        hello agen well this is the thing i like to make but than wit a RV setup and a 230v freq speed controller its more simple to make and to cheap it running all the electronics i use are simple to order online so no need to reinvent the wheel
        here have a look to this baby's Commander SK
        and u can feed them wit DC
        Ray0energy
        • #34
          Hello Ray,
          Thanks for the videos you upload.
          Iam trying to replicate the rv system and i saw that your using an inverter.Is the inverter you using 1phase to 1phase?Or is 1phase to 3 phase and using only 1phase?
          Also you suggest an inverter with dc supply.Did you try it ? or do you think is going to work better?
          How is the huge muller's wheel project going ?
          Michael
          • #35
            See the following two videos regarding magnetic attraction
            Fuel-Efficient-Vehicles.org » A Few Magnet Motors
            and the following YouTube videos
            YouTube - Xpenzif free energy screw magnet motor
            YouTube - Free Energy Magnet Motor
            As Matt would say:
            Simple is Better
            David Bowling
            • #36
              how much does those nylon plates cost ?
              kind regards l hakvoort
