Originally posted by kcarring
I have been working on the SEC design and figuring out the best way to get an AC electrode boiler / DC HHO wet cell into the compression chamber. It is possible but I am trying to make it simpler.
It has occurred to me that it might be possible to use standard automotive spark plugs for both tasks. We have already established that they can be easily installed into a hydraulic fitting using the correct off the shelf adaptor, so no pressure sealing issues, and they are also configured for an electric circuit because that's what they do.
Spark plugs also come with a choice of electrode material, carbon, various alloys, and the newest type... platinum! So a definite chance here to experiment with HHO production using an inert metal, and platinum is the material of choice but is incredibly expensive.
I have not worked out the dimensions yet but two long reach spark plugs mounted opposed may reach into the chamber far enough to give you a small electrode gap between the two electrodes. Alternatively you could make a custom adaptor that places the spark plug further into the chamber but you might have to go with the smallest 10mm plug for clearance, not sure yet.
How the electrical ground of the spark plug will interfere with the process I am not yet sure because they are grounded to the chamber via the contacting threads in the body (normally the negative connection).
A spark plug on it's own should work perfectly well as an AC electrode boiler, allowing you to constantly control the temperature inside the chamber, however, DC HHO production works on surface area exposed to a quantity of electrical charge.
Faraday's laws of electrolysis - Wikipedia, the free encyclopedia
Keep the DC voltage at 2V maximum but pass a lot of current would be an effective way of spark plug electrolysis without heating the water excessively, which would normally create steam, but as the cell environment is at an applied gauge overpressure from the adiabatic detonation no steam should be created (To be confirmed by experiment).
Another option is to use a spark plug as an AC electrode boiler as already discussed, but use the second spark plug as electrical connections to a cylindrical pipe HHO cell, like stainless seamless schedule pipe for example and gain surface area that way.
Quite a few ways to go about this, so have fun and be safe!
Rob
