Ok after studying Ed Grey's Power Conversion Tube Patent, and Jerry Vollands patent Selective frequency optical generator - Google Patents
and also a patent of Pavel Imris. OPTICAL GENERATOR OF AN ELECTROSTATIC - Google Patents
I noticed how each resembled the leyden jar in construction. So I constructed a leyden jar out of a plastic container. punched a hole thru the bottom for the high voltage discharge of the ignition coil. glued another electrode into the cap of container, so that when the containers top is snapped back on the electrodes are seperated by about 1". I placed a copper tube inside the container that does not touch either electrode, but allows the spark to jump between the electrodes inside the copper sleeve. I connected No wire to the inside copper tube. The outside of the plastic container is wrapped with aluminum foil and has a wire attached to the aluminum foil only.I fired up the ignition coil and attached a 12v DC led to the wire attached to the aluminun foil and the led lit up without the other side of the wire being attached to anything. then I attached a small neon lamp bulb to the LEDs non connected wire and It lit up without the other end of its wire being connected to anything. Picture a single wire off the modified leyden jar having two different current AC plus a DC bulb lighting and the wire doesn't go on to a ground. Can anyone explain this? ImageShack - Hosting :: 1000316pj1.jpg
