I recently read a book written in the 1900's which was on electro medicine. The book was discussing static electricity and different ways of charging a device. After a bit they came to Electrophorus. After reading it i was dumb founded. To me it seemed that by automating this simple little device you could produce energy for free.
Unlike most setups i have seen in the book instead of just having a resin which held the charge and a small metal plate with an insulating handle. It had one large grounded metal plate, resin poured into it that held the charge and a small plate with an insulating handle.
The procedure of use is to charge the resin by rubbing it with cat fur. Then place the small plate onto the resin. Earth the small plate by touching with the result being that you ended up with a positivly charged small plate. If you removed the plate you could then charge something. The process could be repeated continuosly as long as the charge stayed on the resin.
With the three plate setup if I remembered correctly when you touched the small plate you were left with a positive charge on it and the big plate became negativly charge.
Ok first why couldnt you instead of touching it replace that with a mechanical switch such as a relay. When the small plate is becoming positivly charged negative charge is flowing to ground. That one unit of energy you just got for free minus a little switching cost. Secondly as the negative is flowing to the ground so to is the positive flowing to the ground on the positive plate and so the large plate becomes negativly charged. Here is another unit of energy gained.
Thirdly now if you unearth the large plate at the same time as you unearthed the small plate you would be left positive on the small plate and negative on the large plate. If you close the circuit between the small and the large plate then you have another unit of energy.
Does this sound valid.
Here is the book i got the details from. I elaborated on the switching part.
Medical Electricity, Röntgen Rays, And Radium - Dr. Sinclair Tousey (Electrotherapy, Rontgen Rays, Roentgen Rays, Tesla Coils, Radium)
It is under static electricity chapter
While your there check out the excellent library
The Turn Of The Century Electrotherapy Museum Tesla Library
