Inductive Heating
  • Inductive Heating
    In theory only 3 things are essential to implement induction heating:
    A source of High Frequency electrical power,
    A work coil to generate the alternating magnetic field,
    An electrically conductive workpiece to be heated.
    Having said this, practical induction heating systems are usually a little more complex. For example, an impedance matching network is often required between the High Frequency source and the work coil in order to ensure good power transfer. Water cooling systems are also common in high power induction heaters to remove waste heat from the work coil, its matching network and the power electronics. Finally some control electronics is usually employed to control the intensity of the heating action, and time the heating cycle to ensure consistent results. The control electronics also protects the system from being damaged by a number of adverse operating conditions. However, the basic principle of operation of any induction heater remains the same as described earlier.
    High Frequency Induction Heating
    Will an automotive coil produce enough HV to make something like this work?
