Gray Tube Replication
  • bridge
    Brian,
    If you want to use a transformer to output 1000v to your caps, use a bridge with double the voltage rating of what you need.
    I had problems with 1000v bridge (with the 6a100 diodes 1000v 6a) and went thru quite a few and the transfomer worked harder...problems from 600 volts +. As soon as I made a bridge with 2 in series for 2kv so 8 diodes total on the bridge, no problems ever since.
    RPX & MWO http://vril.io
      Brian,
      Aaron,
      Thanks for the suggestion. I can try that because I only have 8 more of the 6a100 diodes. However, I don't have any more to make the LV diode bank. (I need to buy more at Mouser or somewhere else.)
      Should I also change my 10kv transformer because this might be too powerful for those diodes, since 2kv is way under the 10kv that the transformer puts out?
      Maybe I should make a hv powersupply out of the camero ignition coil I have. Looks like you also use an auto ignition coil for your powersupply. My question is: isn't a 2kv bridge rectifier too small also for an ignition coil since ignition coils usually put out 10kv? I know it depend on the input you put in the coil that determines output, so is 120v charged pulsed cap to the input of the ignition coil appropriate for a 2kv bridge?
      -brian
      • bridge
        Brian,
        Ok.
        My transformer is adjustable with a variac so I don't let it go above 1000v on the output thru the 2kv bridge.
        The hv ignition coil side is on a different supply.
        Charging the cap over a gap with your supply is ok but it will be slower I think. I have done it but doesn't seem optimum.
        It doesn't have to be too slow if your transformer can operate at higher frequency to charge the cap fast.
          Brian,
          Ok.
          Aaron,
          Now I'm starting to get a whole picture of your setup much better. A variac is a nice convenience to have for this project. Since I don't have one, a car ignition coil with an adjustable 555 timer might be a good alternative for a variable power supply. I also have to watch the gap width to not get it too wide, otherwise I'll keep blowing my components.
          Brian
          • Originally posted by n84dafun View Post
            I did a diode check with my multimeter and it looks like I was working with bad diodes.
            Semiconductor diodes on reverse operation are rated for an "unrepetitive" mode, witch generally is not the the case for vacuum tubes. This is the weakness of the "material" vs. "vacuum" (what can you breakdown in a vacuum? Melt down the vacuum and drill a conductive "hole" in it?).
            • Originally posted by barbosi View Post
              Vacuum tubes would be ideal. I would definitely like to try that in the future. For now the solid state diodes are working adequate now that I got my 20kv diodes from China. By the way, Aaron's theory of the low current/high potential synergistic mixing works according to my tests. All I have to say is WOW!!! It really works they way he describes it. I will post a video soon.
              Brian
              • Brian's video
                Hi Brian,
                I REALLY look forward to it!
                • Senthetic/Synergistic discharge
                  Hi Brian,
                  Hi Aaron,
                  Here's my youtube video of the test proving what you mentioned a few threads ago with your diagrams showing the current paths and voltage potentials. One thing that sucks about the video is that the discharges, normal and mixed, seem to look the same. But you can tell if you look and listen carefully that they are different.
                  YouTube - Murakami-Gray Effect Low Current / High Voltage Synergism
                  It really does make a difference when you combine the two elements of LV current and HV potiential. The HV potential seems to catepult the LV current across that gap in a big way. Pretty cool to see, hear, and compare the difference between normal cap discharge and mixed LV/HV cap discharge.
                  Brian
                  • @Brian
                    Brian, that was exciting to see! I can REEEEALLY appreciate that video.
                    The first time I saw the plasma burst, I know what it felt like.
                    But knowing the principle - the "key" almost makes the diagrams and schematics obsolete if it is known. Because it can then be applied in a multitude of different ways. I felt by sharing that diagram showing the mixing effect that people can be empowered so they don't have to rely on diagrams anymore and do their own thing.
                    The biggest hurdle I had about 5 years ago is convincing people first that the voltage from another source can even go backwards through a diode. Anyway, Gotoluc made it easy for everyone when he found a simplified way to do it with the ignition coils.
                    That is why 100% of every circuit I made worked because I simply applied the principle of the mixing.
                    Good luck and be safe and hope to see more. You'll have fun with adding a coil to the circuit.
                    If you have 1 joule of potential energy in one side and 1 in the other that is 2 joules you put in. That 2 joules of energy is supposed to be able to lift an object of X weight to X height over X time. But if you put in 2 joules in this mixing method, do we get the object to get higher faster? And on top of that almost all of it can be recovered when the coil collapses.
                    Just a concept to play with if you get the opportunity.
                    Even without the mixing, it is over 1.0 COP because the object will launch and there is still recovery. Any recovery means that work was done and we have some left to launch again - won't go as high but still more work is done for the same input - Everyone is doing this already at different levels but don't know it. Anyway, just make up the loss and you get work for less input than the math says is required.
                    • about the commutator
                      can any one tell me
                      how can i connect the commutator wiring
                      • X-Ray shielding for gray tube
                        Hi all,
                        I am rather new to this thread and not yet through with the 56 pages. However, there is something I am wondering about with regard to gray tube experiements that has not been covered yet as far as I am aware of. We are experimenting with electrons accelerated in a spark gap to 5keV. When these electrons hit the LV copper rod, not so mild x-rays are generated and probably emitted in all directions around the tube. What exactly do we do about that to not get hurt (-> cancer) by our experiments? I always have a copper tube aroundthe spark gap, but I am not so sure that 1mm of copper is sufficient to shield away the x-rays generated by 5keV electrons!? I don't want to follow the curies to the grave earlier than necessary. Anyone?
                        • X-Ray Concerns
                          Originally posted by ahoesch View Post
                          Hi all,
                          Dear ahoesch,
                          Safety is always an issue when working with High Voltage. Concerning the risk from X-rays. Consider that in order to produce a significant flux of X-rays the electrons must be accelerated in a hard vacuum to develop the 5K ev of kinetic energy. In this research we are working in open air at STP. Even though the potential between the electrodes is on the order of 5KV there is almost zero chance that any of them will even come close to that energy level before hitting an air particle or other plasma particle. The mean free path of electrons in air is pretty dismal, it is even less in a plasma.
                          I would venture that the risk from UV radiation is more of a concern than X-ray production. Now, if this research moves towards hard vacuum enclosures then your concerns will need to be re-visited.
                          Spokane1
                          • Originally posted by Spokane1 View Post
                            Dear ahoesch,
                            Spokane1
                            Thanks for the explanation that I should have come up with by myself. Of course the air makes the whole thing rather harmless, as long as we don't burn our fingers at a not completely discharged capacitor. :-) UV radiation is not so much an issue for me since I most often have a copper pipe over the spark gap and that shields UV very well.
                            Thanks a lot!
                            ahoesch
                            • Hi all,
                              I just observed an interesting effect that unfortunately toasted my HV power supply. When the spark gap in my tube fired the voltage over the capacitor of the HV power supply started to oscillate for 100ns with a very great amplitude (over 10kV, in one case over 15kV). Since my power supply delivers 5kV this means that the voltage in the capacitor became negative (-10kV)!? Any idea what's happening here? Is this negative resistance or normal LC oscillations? I have attached an image showing this event (the first one with only 10kV oscillations). I unfortnately can't repeat this experiment right now since this event toasted my power supply consisting of a car ignition coil, a bridge rectifier of diodes rated for 12kV and a capacitor in the 48nF range. The ignition coil is toast now, most likely the rectifier diodes as well. No problem, I planned to build a more powerful power supply anyway. But I would like to understand what happened here to avoid toasting my new power supply as well. Any ideas?
                              • Originally posted by ahoesch View Post
                                Hi all,
                                Can you post a schematic of how everything was hooked up when this happened?
