I've been running into small problems that as I try to remedy one another arises. But, I will prevail! I made a spinning contact, so I could introduce the ground into the tube only when the rotors magnets are in the proper alignment over the stator coils. This would have been good had I not used a CD disk to attach the spinning contact's spinning bar to. The foil on the CD disk draws the spark whenever, But the high voltage spark is blasting the foil clean and pretty off the disk. Hopefully it will eventually clean all away then spark only to the copper bar thats glued to the disk. I also removed the steel shaft and replaced it with a wooden oak spindle. Anyway I'm still working with this project and haven't given up yet.
YouTube - Gray Motor Test 2
