No problem....
I find the pieces to the puzzle are scattered far and wide, but knowing how to utilize search engines efficiently helps bring it all closer.....I think most people just don't cross reference ideas well, which makes their searches too broad on the internet. The answer to EVERYTHING is out there online, it's just a matter of how you go about looking for it.
It seems with this setup, you could consider the larger low frequency coil the dipole "battery" effectively(with earth and the atmosphere as it's poles), if you drive it with pulsed DC. The other high frequency coil becomes the pump. The direction of the waves from the big one are one way in each cycle, while the small one has many waves in both directions, resulting in a pumping from the smaller one into the bigger one...
Just like schauberger's vortex designs.
If you look at a water vortex in a bottle that you spin up, the outside rotates in 1 direction, and the inside pulses up and down.... I've been trying to figure out how to do that with a tesla coil... I think this is the key....
Now just take the smaller coil and insert it inside the larger one! You have a perfect EM vortex generator! maybe a flat pancake coil primary, with a conical/hemispherical large coil secondary, and a solenoid skinny secondary in the very center....To make a shape that looks like a TOP!!!!
In other words, picture a rim shape in the middle, with a cone or bowl shape going downwards from the inside edge of the rim, and at the center of the bottom of the bowl/cone a straight piece comes up out of the bowl past the lip and extends in the other direction a little....Sounds like a UFO!
