Gray Tube Replication
  • revision
    Pranav,
    Your cdi power supply - with full bridge, your scr probably won't turn off,
    start with half rectification. And you may need some power resistors on
    the negative coming off the bridge to limit the current.
    You also need HV diodes from the primary + to the HV +.
    Remove the capacitor that the HV output is connected to. If you do not
    have enough punch, that cap will eat up everything and it will not jump
    the gap. You can try to add that later but leave it out for now.
    Make sure your bridge from the MOT is a 2k or 3k bridge.
    Make your points geometry just like in the Mark McKay drawing. You MUST
    force the HV to hit the LV before it can go to the load/grid point.
    Please redraw it with the above changes and I'll look at it.
    RPX & MWO http://vril.io
    • @Pranav
      Pranav,
      This will work - this is virtually identical to what I did.
      Now of course, your goal with this setup is not efficiency at
      the moment but to learn the method first.
      For the capacitor charger on the front end, I would move
      towards an off-the-shelf CDI and add the HV diodes in the
      right direction according to the polarity of your ignition coil.
      If your coil has a negative polarity, then reverse the HV diode string.
      • modification
        hi aaron
        thanks lot
        i use 25 amp 1200 volts scr
        16uf means i use 2uf 2kV caps 8 in parallel
        i use all high voltage diode 1x3
        i wrote all details of my circuit on diagram please tell me is every think is ok
        one more time thank you
        • reply
          hi aaron
          i am wating for your reply
          please reply
          • Pranav's circuit
            Hi Pranav,
            The circuit looks correct. 16uf looks pretty big but should work.
            What size wire are you using for an inductor? What are all the dimensions
            of it, turns, etc...? Core diameter/length, etc...? On a few of my tests
            when I went too much on the voltage, I was sparking through the
            insulation.
            • electromagnet
              hi aaron
              i am trying to build 9 stator 3 rotor setup.
              my coil is 125mm length and it has 1000 turns of 27 awg
              my core is transformer lamination it is "I" shape 40mm*50mm size
              tomorrow i will test the circuit i will post video on our thred
              what do you think is everything ok????????
              thanks for reply
              have a great day
              • good luck on your test!
                Hi Pranav,
                Good luck on your test! 27 sounds a little small but you can try it out.
                16uf at 1000v would be quite a punch. if you have 1000v at a couple uf,
                might be a safer test.
                Anyway, sounds like you know what you're doing.
                Looking forward to some pics or vids!
                • test
                  hi aaron
                  thanks for best wishes
                  i will post pic and vid
                  have wonderful day
                  • power resistor problem
                    hi aaron
                    i am using 100 ohm 10 watt resistor but while turning circuit on resistor getting heat and after few second it will bust
                    your circuit is workig very well but problem is resistor
                    now i am going to use 100 ohm 100 watt
                    what do think will it work properly
                    please reply
                    have great day
                    • power resistor
                      hi aaron
                      can you tell me what is the value of your resistor ?????
                      have wonderful day
                      • power resistors
                        Hi Pranav,
                        I used eight 10 ohm resistors. They were
                        in series and parallel. So 2 in series was 20 ohm
                        and I had 4 of those in parallel. I think the
                        watt rating of them were 100w.
                        It is possible they were 100 ohm resistors, I'll
                        check later. In any case, yes, they will get hot
                        and melt the solder.
                        I have some really large inductive resistors that
                        are 10 ohm 250 watts and I would use one
                        of those if I charged from wall power again.
                        Do you have access to an off the shelf CDI for
                        auto ignitions? If so, you can charge the cdi cap
                        from that and have that cdi connected to a car
                        battery with no problems.
                        I charged a cap from the wall for simplicity sake
                        so I didn't have to build a real circuit.
                        But if you have a CDI, that is preferable. The CDI
                        will have a cap around 4uf and 400~600 volts,
                        which is usually not enough to get the effect with
                        the booster caps. However, with the diode from
                        primary to HV on ignition coil you are getting plasma
                        two times.
                        One is a small plasma burst from the CDI + diode
                        setup and the other is to mix that with the booster
                        cap. So you're using a smaller plasma to trigger the
                        larger plasma.
                        The other reason I used wall supply was because
                        the cap was 47uf, which is more than 10 times the
                        size of one in a CDI unit and wanted to make sure
                        it was instantly charged at any speed. Again, the
                        wall was for convenience but I'd use a cdi if I did
                        it again.
                        • power resistor
                          hi aaron
                          i am also using wall power to charge my cdi cap 47 uf. i mix low vol with the high vol i put diode primary + to secondary + just like you
                          now I am thinking about power resistor I am going to use 10ohm 250watt
                          is this ok ?????
                          have wonderful day
                          • @Pranav
                            Hi Pranav,
                            The 10ohm 250w should be ok. I really don't know what the difference would
                            be from my 110-120v wall compared to your ac wall supply - if you have
                            220-240v?
                            Anyway, it should work.
                            Your diodes should work too but it depends on the polarity of your
                            ignition coil. If the hv is negative then you need to simply reverse the
                            diodes from hv to primary +.
                            Looking forward to your test!
                            • power resistor
                              hi aaron
                              10 ohm 250 watt are not available so i am trying 10 ohm 100 watt
                              today i am going to test it
                              i will tell you the result
                              have wonderful day
                              • @Pranav
                                Pranav, I hope the test goes well!
