Gray Tube Replication
  • Originally posted by Spokane1 View Post
    Dear Bernie,
    Having the grids separated to serve other functions would make more engineering sense to me. My WAG for the morning would be that the inner grid provides the sudden electrostatic field. The second grid is the actual "harvest grid" of any anomalous energy that is projected from the reaction space between the first grid and the anode rod. IF this is so, then the aspect ratio of the device shown in the patent makes more sense than the one used for the EMA6 engine in 1976.
    This is certainly a good topic of discussion.
    Mark McKay
    Hi Mark,
    Makes more engineering sense to me too ..
    Since we don't have a clear picture of the internal connection of the grids, I thought I might initially at least try connecting the grids the following way:
    Assuming three grids.
    From inner(1) to outer grids(3): I take the bottom of 1 to the connector, top of 1 to top of 2, bottom of 2 to bottom of 3, then take top of 3 to the connector. This connects the grids as a 3-turn inductor. Because of the holes, all grids will be acted on by the radiant electrostatic energy as well(capacitive), so I think we can treat the two wires as a parallel resonant circuit and extract the energy from that ..
    Question: Did anyone ever see an inductor wound around the outside of the CEST? If this was done on at least one model, then that would validate my assumption that the grids can be treated as an inductor/capacitor ...
    By the way. I played around last night tying to figure out the best location for my Thyratron switch in the LV circuit. As you know I have a Bifilar wound inductor in there. I found that the arc could be stop/started much easier if the switch was at the center point of the inductor, i.e. there is 1/2 the inductor either side of the switch/Thyratron .. it did not seem to work as well at the "cold" battery end of the LV circuit.
    Bernie
    • Inductor Wrapped around CEST
      Originally posted by bmentink View Post
      Hi Mark,
      Bernie
      Dear Bernie,
      Now and then, around 2005, I saw a few sketches of a proposed arc located inside of the center of a loose wound helix coil. However these where half baked theory conception graphics. I have never seen one that was actually built.
      The FFF might fit the bill since it is an inductor that is warped around the motor. The EMA4 had a multitude of active arcs being struck and stretched inside the motor case proper during the engine's operation. One observer reported how the engine seemed to develop a huge electrostatic charge on its outer case (Cannady 1973). Gray also mentioned this phenomena in the Jack Sacagnetti article (But he called it a magnetic field). So, something very active was going on.
      It is my speculation the the original EMA3 engine's construction was halted in its early stages in order to employ a new engine case that was about 3" longer at its mid section to accommodate the FFF. Most of the remaining components were then canablized to make the successful EMA4. Cole must have had some good reason to go to all that expense to make that retrofit happen. So, the FFF had to be located at that location and I'm sure its purpose is more important than an EMI filter (But that is probably what Marvin told Gray). I suspect that the same phenomena that generated the huge electrostatic case potential was being partially harvested to pre-charge the storage capacitors - or something like that. With out a Cold Electricity generator we can't explore this secondary process just yet.
      So when you speak of an inductor being wrapped around an arc chamber this is what I think of.
      Mark McKay
        Dear Bernie,
        Mark McKay
        Hi Mark,
        Is there any way to confirm if the FFF was wound around the location of the arc exactly? Because as you know, a plasma in particular emits a huge magnetic field .. that's the only reason I can think of that makes placement critical ... if it was wound anywhere over the HV rod, then placement would not be critical ..
        .. also, do we know if the FFF was a Bifilar winding?
        Bernie
        • FFF Location
          Hi Mark,
          Bernie
          Dear Bernie,
          It appears to me that the site location for the electromagnet core to electromagnet core arc could took place any where along the length of these cores (about 1-1/2" x 6 " long). The FFF was located exactly between these cores with out overlapping any of them. There were two sets of stator electromagnets (18 per set) with the FFF between them. Whatever was being harvested was strongest at that location. The engine case was 3/4" aluminum with a 1/4" Teflon liner. The electromagnet mounting bolts were isolated from the case and then again insulated on the outside to prevent accidental contact. So, No the FFF is not wound around an arc location.
          We know almost nothing about the FFF other than the first version employed a single turn of some kind of large cable. Later a smaller diameter wire was used and two turns were taken. That was one (or two) turns per power supply. I maintain that there were 18 power supplies. I liked the idea that the cable might have been a special high inductance radar cable, but I certainly don't know.
          There is a photo of a FFF in the Valentine popping coil photo that is of a different design. It is about 4" and diameter and has 10 turns per layer. I assume two power supplies are used like the patent shows. The windings are wound as a caduses - definitely not bifilar.
          What is odd about this technology is how quickly it change from version to version. The EMA4 was the only engine to have a FFF component. While the EMA6 was the only engine with a CEST. It appears that the "Blue Engine" had neither novel component. We put together some theory to explain one observation and then the next design does something different.
          Mark McKay
            Dear Bernie,
            Mark McKay
            Hi Mark,
            Thanks for that info. Interesting that the winding is caduceous not bifilar, so did it have crossed windings both sides of the core, or just one side?
            By the way, I have just breadboarded my driver circuit and can achieve a 7ns rise time 300v 100ns pulse to the grid ... so am very happy with that .. once I put it onto a PCB with the proper layout, I should get my 3ns ..
            So I have a controller with a fixed fast 100ns on-time and a variable off time, which I will tune for best result..
            Now if only those dang tubes would arrive ..
            Cheers,
            Betnie
            • FFF Layout for Popping Coil Demo
              Hi Mark,
              Cheers,
              Betnie
              Dear Bernie,
              There is a photo in the "Top 10 Hints" paper I sent you on page 8. The FFF is in the center bottom (I have better photos of this component if you like). It appears to be two layers of 1/4" black cable wound in two layers around a 4" PVC (or ABS) plastic pipe section (22" long). There are just two simple coils one on top the other - four wire total. From the other photos the conductors seem to be single and non-shielded, they also appear to be pretty stiff. It is unknown if there is any apparatus in the center of the pipe, but the other photos don't show any wires entering the pipe from either end.
              There is another FFF seen under a table in another GD photo. This unit is also composed to two layers of conductor of about 10 turns as well. It is about 8" in diameter, and again there doesn't appear to be anything inside of the coil form which appears to be Plexiglas.
              There is also mention of a FFF in the Cannady Interview. There the FFF was composed of about 6 each loops (about 36" in diameter) of what appeared to the observer as being extension drop cord (I take it to be a black SO jacket). That application was just an open coil laid on a card table. Gray said it was to reduce TV interference (1973).
              Mark McKay
              • scavenging polypropylene caps
                Yes polypropylene caps ..
                I just found out that polypropylene capacitor is used widely in television CRT and personal computer CRT. Since CRT is nearly obsolete (because of LCD) then anyone that need free polypropylene caps could scavenge them from tossed out CRT at electronic dumpster. Maybe after all of this is through we can make a championship of "Cheapest Gray & Tesla Technology Construction" .
                Wicaksono
                • Originally posted by Wicaksono View Post
                  Wicaksono
                  are you sure ? are they those blue capacitors ? they are not very useful
                  • blue caps picture ?
                    I am wondering what are these blue capacitors ? Do you have any picture or info ? In CRT polypropylene capacitors only used in high frequency & high current circuit of CRT horizontal driver. But they were not too many, only 1 or 2 caps in one printed circuit board. So you really have to scavenge them from a lot of CRT.
                    Wicaksono
                    • Fixed Polypropylene Film Dielectric Metal Foil DC Capacitors Type CBB13 Product Photos,Fixed Polypropylene Film Dielectric Metal Foil DC Capacitors Type CBB13 Product pictures -
                      they are not useful because as you said there is only one or two per CRT and those are small in size (higher ESR) and capacitance
                      • Hi Guys .. an update on my experiments.
                        I placed a small (a few sq inches) copper plate (since I don't have my grids yet) close to the high voltage end of the spark gap and connected to another high voltage cap, the other end of this cap to my common GND.
                        I noticed that I got >120v DC charged on the cap just before the gap fired.
                        I am guessing that what I am seeing is pure radiant energy. From my understanding it is the bunching up of electrons/ions just before the gap firing that causes the radiation.
                        So I moved the copper plate far from the HV line and guess what, I still got the same sort of voltage ... very encouraging, as longitudinal waves should not decrease energy with distance.
                        Next experiment will be with an inductor in series with the cap.
                        Any other suggestions welcome. It's weekend here, so will have time again.
                        Cheers,
                        Bernie
                        • Experiment Details
                          Cheers,
                          Bernie
                          Dear Bernie,
                          Exactly how close was your first measurement and how far away was the second measurement?
                          What kind of capacitor and value was employed?
                          What kind of instrument did you use to measure the 120V?
                          I have also done these kinds of measurements but the magnitude always decreased with distance. It sees there has got to be some falloff at some distance - say 100 ft.
                          Mark McKay
                            Dear Bernie,
                            First measurement was immediately adjacent to the HV lead, 2nd measurement was 1 meter away and voltage was the same, however I did just now try further distances, and it indeed does drop off after 1 meter with distance, I had 10v roughly 5M away. So it looks like you have to have your collecting plates within a meter.
                            Same as my HV discharge cap, 166nF at 6kv (I have two sets).
                            Mark McKay
                            I have a fluke 78 multimeter across the cap, there is also a 2Mohm discharge resistor across the cap, so I could definitely see the voltage building up or discharging when no energy present.
                            I have had up to 200v with the very small 5 square inch copper plate, wish I had something bigger to try. However, I do have some 0.9mm copper plate being punched full of holes as we speak, so should have some grids to try out soon ..
                            I do wonder if the grids should be a combination of copper and aluminium though as was reported to be the case in the Testatika machine.
                            Cheers,
                            Bernie
                            • For some reason I can not edit the above post ... so ...
                              As an experiment I replaced the copper plate with a copper wound pancake coil I had lying around, the coil is wound with one wire diameter spacing so I would have thought it to
                              be similar to a copper plate with 50% holes. I connected the cap to one end of it. To my surprise I found that I had no voltage at all with the coil connected instead of the plate. !!
                              I am puzzled, is there some sort of field cancellation effect going on in the coil?
                              Cheers,
                              Bernie
                              • I did some testing with various metals, shapes and sizes that I had lying around ..
                                Metal Size Voltage
                                Copper 10 sq inch 100v
                                Cu with holes 10 sq inch 180v
                                Al plate 20 sq inch 70v
                                Al with holes 20 sq inch 150v
                                Stainless 10 sq inch 270v
                                Zinc coated Fe 4 sq foot 0.5v
                                Iron plate 1.5 sq ft 0v
                                Stainless Tube 22mm dia 1m 0v
                                Copper Tube 14mm dia 1m 0.5v
                                Brass Rod 4mm dia 2m 60v
                                What stands out is the following:
                                1. The good reading for the brass rod considering the small surface area, must get some sheet.
                                2. Excellent results for the Stainless plate, I wish I had some perforated to test, oh well, out with the drill..
                                3. It seems that anything the shape of a circle (tube, coil) has very poor results. ... maybe it acts as a shortened turn?
                                (remember the spark gap is OUTSIDE the tube, not within it)
                                4. Perforated copper nearly double that of non-perf.
                                Some other interesting points:
                                1. Having the iron anywhere near the spark gap, caused it not to fire anymore.
                                2. I put a carbon rod (from a D-cell) in the LV side and now I get 0v on the copper plates and the spark gap does not fire as readily ..
                                (maybe the carbon block is a red herring?)
                                EDIT: PLEASE DISREGARD THE ABOVE TESTS!!
                                I have just found that I had a small HV leakage path across my benchtop on which the plates were perched ... dang!
                                Cheers,
                                Bernie
