Gray Tube Replication
  • transformer chopper
    This is one of the first I tried...with transistors but I also used a relay like Imhotep's setup...both worked but still slow speed chopping the ignition coil like I wanted.
    The AWA Journal - D Cell Power
    RPX & MWO http://vril.io
      Martin,
      I have a few posts in this forum on two distinct types of cold electricity.
      That's awesome, Im new to this forum thing, how do I find the articles?
      Also, I have a new video I just got done making. VERY interesting. It's 2:18AM here now so Im not sure if I'll get it converted tonight, but this is really neat.
      It's Finished!
      http://www.youtube.com/watch?v=Tu9Qwo-x824
      I really thought I had something until I measured voltage and current. There is something weird going on. Maybe Im overlooking something?
      • Images from mkay2
        Originally posted by nat1971a View Post
        ok i went over the photos in the mkay2.pdf file
        I have extracted all the pictures from this pdf using "pdfimages" (on Linux).
        Enjoy!
        • These are from mkay3.pdf
          Subject says all...
          • And of course mkay4.pdf
            Again, subject says it all
            • One more from mkay4.pdf, from mkay6.pdf and one from mkay1.pdf
              That's all folks!
              • I had to re-upload the video for some reason.
                Here is the correct video link:
                YouTube - Possible Gray Supply Concept
                • Very good circuit !
                  Martin, it's always amazing to see somebody put a light in the water
                  You must be on something if there is no shock in the water ! Is your water conductive ? Have you tried with standard 12V power in that water ?
                  Great experiment
                  Good luck and thanks,
                  MDG
                  PS: lol, NOOO, your workbench is really NOT messy, no, no, no
                  • Originally posted by stephenafreter View Post
                    Great experiment
                    MDG
                    Well, it's just regular drinking water and to tell you the truth, I got so torn up on how bright the bulb got, I forgot to dip it in water w/ just 12v. I mean looking directly at the bulb for a second, it's so bright that I could'nt read the meters on my supply for a minute or so afterward.
                    As for my bench , well, yip. Someday I might see the top again!
                    • Just a quick update, I removed the diodes and replaced them with .1uF capacitors. The brightness of the bulb did decrease, however I felt a static charge on the coils laminated core.... the start of a FFF???! I believe this is some sort of longitudinal wave. If you look at one of the videos that Eric Dollard was in, he does an experiment with paired sets of capacitors and inductors that form a 1/4 wave transmission line. This circuit behaves the same. I believe my circuit could be used as the starting stages in such a setup.
                      • static
                        Great test Martin...what kind of static charge on the cores? Static like what you feel on a tv screen or static like sharp stinging bites like the radiant kickback off an ignition coil oscillator?
                        Nice pasta jar, I use the same one
                          Like a TV I guess. No pain at all, but enough to scare me into thinking I was going to get shocked. I'll just say it was different and odd. I hope that's good?
                          • Martin,
                            I couldn't sleep after seeing your video ! great circuit !
                            I was thinking that if you were to include capacitors on both coils (as you did now) and drive each transistor separately, you could tune each side to it's resonance frequency, and the effect could be enhanced ?!
                            By the way it's a great idea you had with this circuit to collect collapsed spikes in double coil setup
                            Does it show that this collapsing field spikes ARE cold electricity ? because you can put the bulb in water ...
                            By the way, DC in water, you should have bubles from electrolysis coming out of the copper wires and legs of the bulb, no?
                            Thanks for sharing your work,
                            MDG
                              Martin,
                              MDG
                              Well, to tell you the truth, the scope shots on the video is really all I remember because when I wired this up, it was the last trial circuit for the night and it was about 1:15AM. So, when this bulb lit up, I was up until after 3:00AM trying to film and convert it so I didnt get any more time to experiment. After I recover today, I'll get back on it! Like you, I didnt sleep hardly at all because of all the "what if" circuits and scenarios going through my mind and Im dearly paying for it today!
                              I did not notice any bubbling with the light. What I did do though was put one of my Meyer's tube in the water and got some surprising results. If this is a longitudinal wave, I thought about putting a PNP transistor on the 12V input and pulsing (modulating) it along with the other 2 which would give a pulse train waveform like everyone's doing with 2 555's but with it hooked up to a bi-filar coil like this, results may be quite surprising.
                              • Originally posted by martin View Post
                                Martin,
                                Now what happens if you connect your two capacitors to each end of the bulb and disconnect it from ground, so as to conserve that energy/dipole?
