Btw the north monopole is positively charged which makes it a replica of the Gray tube - or the inverse... Anyway, progress.
Gray Tube Replication
Rot E = - dB/dt ; B = k scalar(H); k = constant
E = v x k scalar(H)
H = -v x k scalar(E)
Meyl´s theory above. So the E-field gives us our mass on earth and pushes us down, just like I was thinking yesterday. The B-field of the earth interior should be a spiral around the E-field. Day and night shifts balance between ionosphere and center sphere.
Hence, when we crash the E-fields into eachother we will get two expanding H vectors moving away from eachother in spiral(circle) fashion. Remember the direction of magnetic fields are opposite to the E-field vector. Now this really starts to make sense. It is like a water drop crashing into the water surface creating expanding circles of magnetic waves perpendicular to the E-field direction. Maybe it will expand spherically, not sure yet. If one vector is dominant we could have a scroll wave....
Now this I believe is IMPORTANT for the Gray tube design.
Why is earth negatively charged(Answer: neutrinos(aether units) that convert into electrons!):
"If gravity really is a flow of aethers of some voluminosity, towards mass, how can mass accumulate this voluminous aether, while it empirically seems to disappear into nothing."
[R. N. Boyd]: The problem is easily resolved by the realization of the fact that, as the aether flux becomes subluminal, because it is slowed down by interactions with "normal matter", it will "self-organize" to become electrons. This sequence of the creation of electrons from aether fluxes, ab initio, was actually demonstrated experimentally by Nikola Tesla in the 1920s. Tesla obtained massive electrical power this way, quite by accident, as he was attempting to find the proper numbers of power pulses per second which would couple into the interstellar aether flux at resonance with the Earth's aether resonance rate. Tesla found that his Earth-pumping magnifying transmitters would operate at peak efficiencies, only when specific rates of pulsations were applied. He also noticed that the timing of the applied pulsations could produce either zero readings, or maximum readings of power, on the output side of his system.
This caused him to realize that there were incoming aether flux "waves" that were arriving with unfailing regularity. He realized that the instances where he had obtained zero output readings were those cases where his applied pulses were 180 degrees out of phase with the incoming aether waves, and of course, strongest when the pulses were applied in-phase with the incoming flux peaks. This situation provided evidence that aether flux from interstellar space is not a constant and smooth value, but varies with time. He realized that the Earth, as a massive whole, was modulating parts of the aether flux. He discovered a large number of various periodicities within the aether fluxes. He found the sources of all these various flux rates had several causes.
Space-sourced aether pulses entered the Earth at rates apparently related to mysterious processes occurring in the deepest reaches of outer space. Many such interstellar processes generated pulsations having nothing to do with Earth. Other rates had to do with processes in space we may never fully understand, representative of the properties of the interstellar medium itself. Yet, there existed a class of pulse rates definitely related to the nearby sun and to the Earth as a resistive mass. Tesla found that the Earth's rocky crust represented a resistance to the otherwise smooth passage of aether flux pulsations through interstellar space.
Tesla found that the resistance of the Earth's crust to the passage of aether, caused a local intensification of the aether flux to occur. He observed that a self-magnifying, self-collimating, property occurred when the aether fluxes encountered the massive body of the planet.
The so-resisted aether then self-focused into the locally resistive medium comprising the planet, resulting in locally intense aether flux bombardments in the resistive media, resulting in locally explosive emissions of showers of subatomic particles. One of the principle emissions was numbers of electrons. It appeared that electrons would spontaneously appear in the matter of the planetary body due to such resistivity to the aether flux. The resulting electrons acted as an aether "contaminant" which would choke off the normally smooth and unencumbered aether flows. In other words, the process of the conversion of aether particles, into electrons, due to the resistivity of the Earth's crust, acted to further retard the aether flows, in addition to the resistances inherent in the materials of the Earth's crust.
On the terrestrial scale, the results of these processes were observed to be enormous in scope. Tesla found, for example, that these processes were responsible for the molten core of the planet, and for the constant excesses of electrons which give the planet a constant net negative charge. Tesla also found a direct correlation between the local aether resistivity of the earth's crust and the local rate of lightning discharges, in certain areas which were already notable for locally prodigious lightning activities. And so on...
Anyway, when the proper pulse rates were found, Tesla had gigawatts of electricity to deal with in his Magnifying Transmitter equipment, rather unexpectedly. Fortunately, no one was hurt.
On the other side of the same coin, explosive discharges of electricity, approaching the ideal of the Dirac delta function, cause the dissociation of electrons into their component aether particles, which then stream away from the discharge site in superluminal ever-expanding shells. Similar processes are probably occurring all the time in the bodies of the stars, resulting in aether emanations from the various stellar bodies. It is possible that localized processes can also occur in interstellar space, which can also result in aether fluxes. Interstellar space is not at all a perfect vacuum.
Ok, so here I continue my monologue(any comments are welcome..)...
Earth is a mirror image of the Gray/Meyer circuits when making electrons(and protons). Earth has positive core, positive ionosphere and an electron generator at the collisoion site between the E-fields from ionosphere and core. The E-fields meet at the crust - BOOM, we get materia and negative current(electrons from neutrinos/aether units converting where the E-fields meet) which make the crust grow year by year.
Anyone sees the importance of this??! Only thing remaining to figure out is how protons are created(positive-positive makes electrons, how about protons?) to make the balance complete. Day and night balance should give us the answer.. Look at the magnetosphere during daytime and night time..
The cold current receiver hence should be constructed like the earth with a spherical geometry(conducting core(+), dielectric(HHO?), thin conductor(crust), dielectric(atmosphere) and thin conductor(ionosphere)). Rotation is the final twist to aether reception balance I believe.
So the beads are simple to realize now.. Just mirror image the planet for electrons and proton generation(cold fusion is proton generation). Remember magnetocurrent are either imploding(proton creation) or expanding(electron creation).
This is getting VERY CLOSE I believe, anyone cares to feedback?
Gauss,
I'm trying to follow youbut I can't find what is scroll wave . Can you explain ?
I would understand better but due to lack of education I must study Maxwell before
There is something in it... Can you compute Meyl equations for the case of stationary AC longitudinal waves on secondary transformer wire ? What remains ? Tesla described it as white misty non -electric flame , several inches long.
Would it be a magnetocurrent ????
Gauss,
I think I get it.But could ya upload a diagram So's I can See It . That is if it is buildable. The use of spheres instead of cylindrical electrodes sounds interesting
but It has to be a reality to build, and work with the intended purpose that Greys tube is supposedly designed to do.
Ok, so about the scroll(vortex) wave, try this link to get a pic: 'The Tesla Crop Glyph - read the full article, very interesting.
So I believe the dielectric, oscillating magnetocurrent from HV-LV collision is an expanding scroll(vortex) wave with clockwise rotation, the Gray/Meyer tubes have a scroll wave expanding 90 deg out from the collision site converting neutrinos into electrons inside the dielectric water or a coil/cap/spark gap. Before we have had the concept about magnetic fields being concentric circles and I believe the expanding/imploding scroll wave is the more exact truth about what happens when we crash HV, LV, HF E-fields into eachother like Gray/Meyer.
It corresponds to Tesla´s words about a longitudinal wave, looking for dielectric materials and oscillating. As long as we continue to pulse the WFC the scroll wave will screw further and further out until we have a complete electric circuit along the scroll from anode to cathode with an E-field around the magnetocurrent - that means breakdown of the WFC, we have to stop the pulse train after about 10 pulses. That one I have waited for a long time to crack...
Next question is what happens when 2 south monopole magnetocurrents LV, HV(2 positive E-fields carry S-pole magnetocurrents with them) crash into eachother. As the E-field fades very quickly after impact I believe we will have an imploding S-pole scroll wave(basically first it screws itself out and then in again) just after impact. This implosion will give us a proton and possibly at the anode!
So rapidly increasing E-field gives us an electron. Rapidly fading E-field gives us a proton. Screwing out, screwing in, electron, proton. And it will look like an expanding cone from implosion site(proton) to the full diameter of the scroll wave(electron generation site). Like a tornado with one end making protons and one end making electrons. Large potential between the 2 sites.
To conclude we have 2 phenoms from the Meyer/Gray tubes.
We have one electron generation site(HV, HF E-fields) with an expanding scroll wave and one proton generation site with an imploding scroll(vortex) wave from the electrode where it will implode, voilá we have BALANCE, we have cone geometry, we have circular/cylindrical geometry, we have a double vortex(implosion+explosion)!!
Next step is imagining the spherical case with a rotating crust around a still center core.
This is exactly what Tesla did with his light bulbs shining, figuring out what happens at day/night time etc. Now I know he knew exactly what the planet really looks like and how it functions, that is why he understood electricity. Earth is a machine picking up cosmic radiation and turning it into life and materia.
Finally some common sense to it all. And this is exactly what Meyl´s equations anticipate but not applies in pictures and examples in his book.
So if we turn back to Master nature we should do spherically layered beads.
If you make layered beads like the earth model you should be able to get electrons at the third layer(crust) and protons at the electrodes. After awhile we will realize how to make any material, just use the right electrode material. Read about Kanarev, he can not explain what happens at his electrodes. But he has no idea about the E-fields and the magnetocurrents, that is why all cold fusion guys are lost, they have no idea about electronics and physics, they just know chemistry. You must know it all to be able to do anything and this is the starting point, the rest will be so much easier.
Sorry about lack of pics, they would take ages for me to do on my computer, maybe I can post some sketches from the scanner. For later though, I am choked everywhere...
About scroll waves, Kreb etc you can find alot of info from meds and biologists. Just look at the planet and our plants, they have them in photosynthesis etc.
Puuh, tired, tired, I hope you enjoy my theory!
big cap and carbon resistor
Originally posted by Mr. Sherlock View PostHi everyone,
I am new here. I am building a Gray tube and in need of two 12uF 7-10kV capacitors. I have all the rest of the materials lined up.
Can anyone point me to where I can buy these (cheaply)?
Thanks.
I see good deals for caps that big on ebay once in a while.
What are you using for a carbon resistor?Sincerely,
RPX & MWO http://vril.io
I found a 16uF cap, at 7.5kV, in a junk defibrillator which came out of a dumpster behind a used medical equipment store. There was also a bunch of other hV stuff. Switches, vacuum relays, diodes, a transformer, etc. The only thing burnt out was the hV slide switch.
I went in and talked to the guy, and he said that the general public can only buy non-working equipment. So he sold me another defibrillator for $25. This was a newer, smaller type. The cap is only 5kV, but it's 46uF. And the kiloVac DPDT relay has a 12V coil.
@Aaron
I've been looking on eBay for some time now. I don't find any that size. I'll keep looking...
For the carbon, I took a "D" size battery, opened it up and took out the graphite rode from the positive terminal. Cleanded it up, cut it into 3/4", 1/2" pieces with my dimond blade wet saw and made a 1/4" hole on to each end on my lathe for press fitting my LV stainless steal rod.
@Elecrtotek
Thanks, I wish I should be as lucky and find some the way you did.
Thanks guys.
@Gauss
I bought my diodes from them but they dont have that particular cap. I thought of buying two of the 24uF 5.2kv caps they have and connect them in series. That would give me about 12 uF at 10.4kV wich is close enough, but it will cost me $600 for the 4 I have to buy in order to make 2 of what I need.
That price is way over my head. If I could knock of a zero from that price, I'd be happy.
Thanks for the info though.Last edited by Mr. Sherlock; 12-19-2008, 02:24 PM.
I don't think a big caps are required.Anyway you could easily build smaller one yourself for no more then 20$. Investigate Tesla patents.Use SS plates (cheap China plates) and container filled with boiled oil. Of course that wouldn't be 10 uF
