Originally posted by Aaron
Gray Tube Replication
Guys,
I don't know if anybody noticed. But schema that I created is hybrid between latest Gray's patent and first one.
I was thinking some more on how to make this schema with CSET and to make it work. It's missing one key component!!! Check out my idea.Attached FilesMike
Originally posted by Aaron View PostBoguslaw,
Towards the top right of ever post is a "permalink" but to the left of that is a link with a #..can you post that link instead because that will take me straight to the exact post you refer to. I'm not sure why the post # links just go to the thread.
In the Investor photo, capacitor 16 is in the Black Box sitting on the floor. There's a small wire running to the CSET electrode, on the far end.
Radiant CSET
Originally posted by boguslaw View PostThat commutator I struggled with and I found the same part in Tesla patent for device utilizing radiant energy 685957.
What if Gray tube is really a special capacitor, charged from inside by a radiant energy and discharged through secondary circuit by commutator ?
But it's the capacitor which is discharged by the commutator.
With Aaron's setup, his Tube is equivalent to the "one way energy path". If he connects his grid to the electrode of a Power Conversion CSET, with multiple grids, the pulse from his Tube might produce Radiant Energy within the CSET, charging the capacitor.
In the Investor photo, only one wire is connected to the CSET electrode, like an antenna.
Sparks are amazing
I wasn't blazing any new ground tonight, just tinkering with my setup - driving my coil and gray tube with a Imhotep's oscillator at 12V.
I took the HV from the ignition coil through a bridge rectifier and into a microwave oven capacitor. I was able to store 450-500V in the cap.
Then I changed the setup and first took the HV through the smallest of spark gaps, and with no other change I was into kilovolts, and overranging on 2KV scale. That's stored capacitor charge, not just a voltage peak.
Pretty amazing I think.
No doubt the spark is magical. But I'm not telling you anything you don't know.
cap rating?
WTF, What is the rating of that cap?Sincerely,
Originally posted by Electrotek View PostI think you're on the right track. In Tesla's patent, Radiant Energy hitting the plate pulls electrons from it, placing a charge on his capacitor. In the CSET, Radiant Energy from the electrode pulls electrons from the grids, producing a momentary positive charge. This charge pulls electrons from the battery, but not the capacitor, due to the extra diode at this point. Unlike Tesla's receiver, the grids aren't insulated, so the electrons from the battery flow into the capacitor, through the diode, after the Radiant Energy pulse is over, and the pulled electrons condense back onto the grids. Repeating this at a high rate - 3 to 6 kps - quickly charges the capacitor, due to the blocking diode of the "one way energy path" from the battery. As long as there is no arcing from the electrode to the grids.
1. capacitor 38 was added by Gray, there was no such part in original Marvin Cole setup. That means only CSET could be a capacitor discharged by commutator like in Tesla radiant patent.
But...
2. In Gray photos grids are very narrow, taking only small space at the bottom of container. Where is the capacitance so ?
Magnifying transformer concept fit better to photos and facts. And electron pulling from battery is also required in that concept to create really big unidirectional spark. I recall Tesla said that convertion from DC current is the hardest and minimum 100V is required. Marvin Cole used 12V battery so he need a source of fast electrons as a replacement for 100V DC current. IMHO powering vaccum diode heater create high voltage potential on anode.
Originally posted by Aaron View PostWTF, What is the rating of that cap?
Originally posted by mlurye View Post@What The Flux. Try to remove spark gap. I do belive cap will charge as well.
Originally posted by boguslaw View PostThat was my first idea, but I think it was wrong, because :
But...
It's entirely possible that the operation is based on the Magnifying transformer, or even something else. That's why we need to experiment with various approaches.
My experience with Super Bolt capacitor discharges has shown that it takes four or five seconds to charge something like a CSET to a high uF value. The time varying pulses are related to the relaxation time of the NST primary. I don't know if this can be speeded up for rapid discharge repetition. I'll play with this a little more, eventually. For now, I'll be happy when I can charge Cap 38 in a fraction of a second - with a battery.Last edited by Electrotek; 02-13-2009, 04:01 PM.
Originally posted by mlurye View Post@Electrotek: Could you make a picture of your setup?
The defibrillator inductor is at the very top, with the 'hot stick' dowel rod stuck in the hole, for storage. The big cap it's setting on is 38. And the blue wire to the diode is the arc gap, which is 42.
Not shown is the diode T-tap from the other end of the diode to the arc.
What is the value for cap 16? And actualy if you can provide params for all your components it would be realy good. Also could show your power supply and how it is connected?
I did markup your picture. Is it correct?Attached FilesLast edited by mlurye; 02-13-2009, 07:34 PM.Mike
