Making blank water
  • Making blank water
    Hi all.
    I have heard that blank water can be transformed in anything you want it to be. You can pray to it and get some healing effect out of it, you can drop some gasoline in it and the water will take the gasoline properties and burn and so on. I decided to experiment in this area. So far the only way I know how to make blank water is splitting ordinary water in HHO and getting it back by burning the HHO. I made a simple water head out of aluminum for the water to condense. I used aluminum because it transfers heat very good. I circulate some cold water in the aluminum water head so that it stays cool all the time. This is important, because not much water will condense on a hot surface. Then I just point my hho torch on the aluminum surface and recombined water droplets are just dropping in a glass. This works good, in about 10 minutes there is about a sip of water in the glass. The thing is that the water smells like metal and is acidic, I used some PH strips to test it and the water PH is about 4-5. That is weird because I don't know what causes the acidity. I am using KOH as electrolyte and this stuff is strong alkaline. Maybe the water somehow reacts with aluminum and that is why it becomes acidic? I should probably use some food grade stainless steel for the condensation plate.
    What are your thoughts about this?
    Can you elaborate more by providing information? I googled "blank water" but the results are irrelevant.
      reset water
      Will it condense against clean stainless steel? Aluminum is not a healthy metal if you did want to drink it or something. Will it condense against glass? That might even be better than stainless steel.
      If you take the hho output without the flame and bubble it through pure distilled water for a while, wouldn't that water take on the properties of being reset?
      RPX & MWO http://vril.io
        Broli, look in youtube for "Masaru Emoto". This man discovered that water forms different crystals when freezing depending on how it was influenced by magnetic fields, sounds, thoughts ect. If it was influenced in positive way, it forms beautiful symmetric crystals when freezing, but if it was influenced in negative way, it forms misshaped and random crystals of even no crystals at all. This lead him to believe that water has memory. The properties of water are not so much depending on the chemical formula as on the structure of the water. Its all about how the h2o molecules interact with each other and what cluster shapes they form. And this structure can be influenced or changed. I have seen a video where one Chinese guy is mixing 79% of diesel with 20% of structured water and this mix did run a car, he said that the car was now about 15% more powerful. Some Russian scientists had some methods of erasing the structure of water so that it will take any structure you want. They took a bottle of such water and dropped some drops of diesel in it. Then shacked the bottle and let it rest for some minutes. After that, the water had taken properties of diesel and did burn. So if you can erase the memory of the water, you can make it "think" that it is gasoline or wine or whatever you want and it will act like that. Maybe this was how Jesus turned water into wine
        Anyway, they say, that one of the ways to get this blank water with no memory is to recombine the hho gas into water again. So I want to try this out.
        Aaron, it will condense on glass, but as the glass gets warm, the condensation stops and you can not cool the glass because it is a good insulator. So we need a material with good heat transfer properties, that is not damaging to health. So far I found aluminum to be the best material to condense the water, but I agree that it is not healthy.
        I am not sure about the distilled water thing, it might work, but to prove the concept I would rather get some of the HHO water that should be blank.
          Interesting to see someone testing the PH of burnt water...... you might get some of that and input it into something like: The Energy Copier
          Thanks for sharing.
            homeopathic diesel
            Sounds like homeopathic diesel! Take it and don't just shake it but pound a closed jar of it pretty hard against a leather pad like a baseball mitt. Do it a few hundred times minimum. That is called succussion. That is your 1X mixture.
            If that does work, then you can take a 1 part of that mixture and add it to 9 parts of fresh batch of "blank" water. Do the succussion process again and it should get STRONGER. This is your 10X mixture...you can continue many times.
            After the 13th dilution, there are no more molecules of the original diesel left and each dilution gets stronger and stronger. (Avogadro's number - I think this is the correct reference. You can only fractionate it so many times until there isn't any left of the original molecules.)
            Maybe if you used pyrex glass, you can fill it almost full with ice cubes and put the flame on the outside and let it drip down into a clean glass. Maybe the glass will stay cool enough until the ice melts then pour out the melted ice and replace with ice.
              Aaron,
              ordinary glass does not like a hho flame because of the rapid temperatre changes, it will just crack shatter. It happened a few times so I keep my torch away from glass So I guess that glass is out of the question.
              Thank you for the mixing tip Russians said that production costs of one cubic meter of this "blank" water, are about 6$, they said that this involves water circulation through some tubes and centrifuges. Joecell guys also say that stirring the water before using it in a cell, makes it better because of the vortex that is created during stirring. Joe himself demonstrated many times that he can make charged water burn. One time he just poured some of this water into a silver spoon, tapped the spoon with a battery charger leads of small current (just to make some sparks) and then the water would burn with a blue flame. Other method was pouring some of that water into a balloon, then inflating the balloon and set it on fire. The balloon bursts and the water that drops on the ground is now burning with a blue flame.
              Interesting stuff
                Memory of water
                Came across experiments by jacques Beneviste, some details on my blog, 'deep-thoughts' about memory of water
                  heat shock resistant glass
                  Hi Jetijs,
                  The Pyrex glass is made specifically for temp changes. You can pull it out of a hot over after baking something then immediately put it into the refrigerator.
                  Pyrex is a popular glass brand name for this kind of glass and most people in this country probably have a quart measuring pyrex "pitcher" in their kitchen.
                  Whether or not it will stand up to being filled with ice and having the flame on it, I don't know but it is cheap enough to find out. Probably less than $10 US for a quart or so size or more.
                  There are pyrex lab glass or other brand of glass for lab use that are for rapid temperature changes available.
                  Check this out:
                  Borosilicate glass - Wikipedia, the free encyclopedia
                    On the Track of Water's Secret
                    Jetijs,
                    In Johann Grander's book On the Track of Water's Secret...in the back by some scientist..can't recall name off hand...had a great explanation of how homeopathy works. Very interesting!
                    Spiritual Nutrition: Six Foundations ... - Google Book Search
                    this link isn't what I'm mentioning but is just a reference...check out that page though.
                    Revitalized Water - Dr. Johann Grander
                    Universal Tao: Track
                    this one has the reference. This page has a lot in SMALL but has the Ludwig references.
                    Johann Grander has one of the most effective ways to erase water's memory. I personally have the mini Penergizer and it is incredible!
                      Reflection of Mind Projected Thought into Water Photographed
                      [QUOTE=Aaron;37968]Jetijs,
                      Aaron, it is a good reference and starts back on page 161.
                      It is Dr. Felsch.
                      Searching Google on this topic this interesting subject was located:
                      LAB NOTES
                      Great topic,
                      IndianaBoys
                        Maybe there is something inside, what will match, what you want.
                        230 Pages of Plans from Free Energie Machines, lol.
                        http://www.apfn.org/Free_Energy/Plans.pdf
                          Dr. Felsch
                          Originally posted by IndianaBoys View Post
                          Aaron, it is a good reference and starts back on page 161. It is Dr. Felsch.
                          LAB NOTES
                          Thanks IndianaBoys! I'll reread it if I can find my copy.
                          That letter G test is interesting!
                          • #14
                            Dr. Horst Felsch
                            Dr. Horst Felsch states of his research into Grander's revitalized water: "it is known that liquids can be primarily activated in the way that part of the inner energy is transformed by means of refrigeration, so that a higher energy content is impressed. Like this, water in its electromagnetic structure has been successfully transformed in the way that -- both by modifying the magnetic nuclear resonance properties (modification of the spin-spin coupling constants), and by the induction and formation of the supermolecular complexes between the single water molecules -- the electromagnetic state of oscillation was modified. These electromagnetic oscillations are responsible for the formation of an electromagnetic field of defined frequency, phase and amplitude, which spreads evenly in all directions. Surprisingly enough, it turned out that, in such an electromagnetic field, larger particles and molecular groups are decomposed into smaller molecular groups, which results in a reduction of viscosity, the dissolution of harmful molecules and the like. And it is also highly surprising that the energetic state of the activated liquid is preserved, i.e., it does not ease off."
                            • #15
                              Thank you guys for the info
                              Today I made a new cooling head from stainless steel. This works just as well as aluminum. Gathered some water. The water again was acidy and had a metal smell. I dropped some drops of gasoline in this water so that the ratio is about 1:20. I shaked the water for some time and the let it rest for about 20 minutes. I noticed that the gasoline mixes better with this water compared to distilled water. The water turned kinda milky and was not clear anymore. Still, when I tried to burn it later, it did not burn. I managed to get somesmall flames, but these were obviously from the small amount of gasoline left in the water. So I guess there is more to it than we know
