Making blank water
  • #31
    Water hologram
    I think to produce the kind of water you are after you would need to burn it in a vacuum otherwise you dont have a pure flame as it is mixing with the surrounding metal and air. The flame is meant to be clear but most i have seen on youtube tend to be a color suggesting that the process itself is dirty or the surrounding air is causing trouble. I saw a guy on youtube simply take a meter long copper tube which had been capped at the end and directed the flame into the tube. The air evacuated and when finished he tipped the pipe up and water ran out so maybe theres a way
    I've always wanted to try super hydrated water which distilled or otherwise water which has had hho bubbled through. I guess another thing you could do if your feeling dangerous and are after alkalizing the body is to pass hydrogen gas through an ionizing chamber and breath it. I know of one person that did this and he measured the ph of his urine and it was more alkaline.
    As for the biohologram I guy by the name of Rick Anderson use to own a site which he closed which looked into esoteric science. He made a biohologram unit to test the process. I dont think he mentioned how well it worked. He also did the same for regenerating the bodies energy field using lorentz field and made the circuit available. He had a plant that was in terrible trouble. Put it in this box in the dark with the unit turned on for a week or so and the plant came back to life after he opened the box at the end of the time. Anyway here is the url if anyone wants to read and build the units
    ELECTMNU
    • #32
      DW
      Distilling water only removes minerals and impurities, but does not alter the covalent bond between H & O molecules.
      What has not yet been determined is the exact mechanism of action as to how the memories are being stored. Find that out and then it will be possible to manipulate it.
      With the Japanese experiments, there is no formal published paper that specifies how the experiments were conducted in order for other research institutions to reproduce. Numerous requests to the faculty have resulted in no replies.
      The big problem right now is that there is no standard to measure "blank water"
      Magnetic fields alter water bonds from 13 to 5-6 moleculular structures. In a sense this softens the water and allows for rapid absorption and interaction with other molecules once ingested, as for tasting sweeter, i am not so sure.
      • #33
        Dialetric constant
        At a guess i would say the dialectric constant is what changes. Patrick flanagas book Pyramid Power contains a small skematic to build such a unit. He was using to measure the field on humans. Basically its an oscillator circuit the skin plays the part of the dialetric.
        • #34
          Wiping water's 'memory'
          Flower essences carry the signatures of plants, or the consciousness of or message of flowers in a solution of alcohol (preservative) and water. If you leave a bottle on a tv, the 'message' is wiped, and it will no longer work. I'd say expose water to 60hz frequency of magnetic / electric fields. Has to be a reason 'they' picked 60hz for energy grid. Suppression of consciousness / aetheric / subtle body stuff.
          So just steam water, collect in glass jar with tap water cooling glass thru tubing wrapped around jar. Expose water to oscillating mag field.
          Viola, blank water?
          • #35
            Since I have been researching Baron Karl von Reichenbach in the past weeks, here are my notes regarding baron's experiments with Od (Orgone energy) and water. This is an excerpt from my blog (sorry the blog is not online - it's on my intranet).
            I will paste relevant parts on water, but you will need to familiarize yourself with baron's research on Od energies to get the whole picture.
            Various aqueous solutions were exposed to both sun and moonlight. Water exposed to direct sunlight had a “different” taste, being cool and slightly acidulous. When exposed to glass filtered sunlight it tasted “warm and bitter”. Apparently, water was able to retain Od when once exposed to Od sources.
            Large prism was then employed and water exposed to different spectra. Violet color bands produced cool and acidulous qualities, while red colour bands produced warm and nauseating qualities. There were no chemical changes detectable in either water samples.
            Reichenbach stated the belief that all fluids were subject to those laws by which crystals were regulated and formed. It was possible then to store these Od patterns in fluids of the kind which crystals were clearly manifested. This storing of patterns had been cited for the behaviour of remedy substances termed “homeopathic”. The crossover between two worlds, one of qualities and the other of quantities, proved that one precedes the other. Here it was possible to enhost “mere qualities” into matter. Therefore qualities themselves were much more than metaphoric realities.
            Water samples exposed to pure moonlight for several moments produced a “mawkish”, “burnt rubber”, unpleasant and nauseating sensation, occasionally inducing vomiting. Light from celestial bodies was also tested by Dr. Buryl Payne who used a 6 foot metal pipe 5 inches in diameter mounted on a telescope tripod.
            Refrigeration eliminated the foul lunar flavourings and the extreme irritability.
            Venusian light gave a strangely “metallic” flavour, producing an unexpected giddiness. Jupiter exposed water tasted sulphurous, but relieved certain internal upsets with surprising speed. Various other planetary configurations produced specific emotional effects: sadness, weeping, anger, and disorientation, in short, hysterical symptoms.
            When a tumbler full of water was stirred with a clean permanent magnet real and lasting effect resulted. Water which was stirred with either pole gave characteristically different sensations. North poles produced water stimulant while South poles produced an irritant. It was found that water samples were not chemically changed and that the change must have occurred deeper than supposed.
            Od charged water remained active even when poured among numerous glasses. Luminous Od remained in water samples for long time periods. North pole stirred water remained a tonic stimulant while South pole stirred water remained an irritant of nauseating proportion. In addition it was found that hand-held water retained Od. There was a strict polarity transference from hand to sample. Water activated by the right hand produced energetic responses. Water held in the left hand was nauseating.
            Crystals could charge water samples as did magnets and sunlight. Crystal points projected coolness into the water, the acidulous taste resembling that produced by magnetic North poles and violet spectrum sunlight. Crystal bases gave the same nauseating flavour produced through both South magnetic poles and red spectrum sunlight.
            The quest continues...
            • #36
              Another probatly Answer.
              Übersetzte Version von http://www.love-is-freedom.com/gesundheit/super_ion_wasser/super_ion_wasser.htm
              High ionised Water.
              Translated with Google from German.
              At the Circuit below is Zündspule - Ignition Coil antiparallel.
              • #37
                Super Ionized Water
                Am i understanding that circuit right in that its goal is to produce super ionize water. If I will definitly be giving it a go. I remember reading the infomraio on it some time ago and was just blow away by what it could do.
                High ionised Water.
                • #38
                  Any one build Super ionizer
                  I was wondering if anyone has built or taken a look at the super ionizer schamtic. I tried looking for a contact email for the site but none. I was wonderin how do you reckon the electrodes a placed. Are they just two points or is one pole connect a metal surrounding and the other in the middle to create a vortex though im not sure that would work without dc.
                  High ionised Water.
                  • #39
                    Back to the subject of water, changing quality of water can be accomplished using pyramids in the scale of the Great Pyramid. I know most of you are dead set on circuits, but it's time everyone looks up para-sciences such as Radionics because that part of our environment is totally neglected.
                    Anyway, try it and see what happens.
                    Any size pyramid will work, the bigger the better I suppose, it does not have to be solid, frame is sufficient, but geometry is an issue, angle of the side face must be 51.86 degrees (cosine of that is 0.6176).
                    Easiest is cardboard sides, everyone has cardboard at home, right?
                    I'll do the math for you...just fill in the figures.
                    If h is the height of one side (the triangle forming the side), s is the side of the triangle, and b is the length of the base of the triangle then:
                    Following that:
                    So cut four triangles, with base size of b and side size of s, having height of h, tape them together b forming the square base and you are done.
                    Next step is absolutely crucial, you must align the pyramid to the magnetic north, it does not matter which side faces it but one must.
                    Patrick Flanagan found out that it does not matter where you put your items in the structure, so it will work anywhere beside the King's Chamber. Use your best judgment, experiment with both, but remember the alignment of the pyramid is the most important bit, beside the geometry.
                    Place the cup of water into the pyramid and leave it there for 10 minutes, then taste the water or do whatever other experiments (Kirlian photography, spectrophotometery, whatever is your thing) and report on findings.
                    P.S. I wish this forum would not mess up my in-line images, HELLO ADMINS ANYONE HOME ?!
                    P.P.S. Nobody said you couldn't have cgi-bin/ in the image tag, argh !
                    • #40
                      Product to lower SG
                      Water is amazing any way you turn your head to look at it.
                      Viktor Schauberger's research shows how an egg shaped container allows water to flow continuously, keeping it alive and cool.
                      Water wants to be at 4 degree Celsius = 39.2 degree Fahrenheit where
                      is it most dense (Specific Gravity)
                      Water is like a Chameleon taking onto itself its surrounding.
                      External "things" can change the internal structure.
                      Schauberger said cool water is healthier and it seems there is research that backs that up now. Meaning the Specific Gravity (SG) does effect how your body is able to use water. Water wants to be at 4 C.
                      A product I found claims SG reduction by using it to stir your water and thus
                      makes the water healthier for you.
                      Well, yes, stirring does cool water and lower SG, but you don't need to
                      purchase anything to do that. It's physics that does makes it happen.
                      No water just being cold isn't the same thing as it cooling itself via .. dare I say, vortexing.
                      Read Amigo's posting, good stuff.
                      Amigo said
                      Now, in theory (I have not tried it yet) I believe that artificially structuring water could be accomplished through implosion, by running the water through a votex of specific geometry, as it is done in Nature, just on a smaller scale.
                      I saw a video, no I don't remember where, how this guy only drinks spring water and he vortexes it.
                      He used two 6 gallons (yes 6, but 5 gallons are ok) plastic jugs, he had
                      some glass ones but those are heavy and hard to find.
                      He took a pipe metal fitting which fit the necks of the jugs.
                      This fitting comes with a rubber lining, it was purchased from the hardware store and is designed to joint to pipes together.
                      It has two screws that tighten the fitting down.
                      He found something else rubber, cut the top or bottom off it.
                      I don't remember what it was, but it created a donut shaped rubber item which fits snuggly into the fitting between the
                      two jugs reducing the opening between the two jugs for a tighter vortex formation. .. You've seen the two soda bottle vortex experiment.. this is scaled up is all. He also keeps his jugs with water wrapped in blankets to insulate cool.
                      Randy
                      • #41
                        Originally posted by Tishatang View Post
                        Hi All,
                        Video here to mix oil with water with Ph of 11.5 using electrolized water only.
                        YouTube - How To Melt Body Fat ~ Drink Kangen Water
                        These units expensive. Must be a cheaper DIY way?
                        Interesting link here on water that purifies everything. Old paper, what happened, or just BS?
                        https://www.arashi.com/pipermail/scp...q4/000535.html
                        Tishatang
                        Sounds like BS. Again, with the gov conspiracy crap. I pasted the article below. Make of it what you will. Couldn't find part one, but it's probably more of the same. Guess we'll just have to figure this out ourselves.
                        Here's a link to the article. The one above has nothing. I tried to paste the article but it had too many characters???
                        OT:super-ionized water...this is major league stuff here!!! Part 2
                        • #42
                          Thanks for sharing.
                          Welcome to my Gw2 gold site , I was a love of the game, such Aion kinahDiablo 3 Goldas they are usually the most favorite thing to do.
                          • #43
                            more --- food for thought
                            Jetijs … I’ve been an admirer of your constructs for quite a long time you have certainly produced some beautiful machines … I hope I can contribute some observations and links of interest on your thread … although no doubt I'll simply be repeating what you are all ready well aware of
                            “Have you entered the storehouses of the snow or seen the storehouses of the hail” Job 38:22
                            according to Prof Emote it is that quote from the bible that initiated his research.
                            Regarding Victor Schauberger I Include this link to Tom Browns Documentary for those who haven’t watched it.
                            Nature Was My Teacher - The Vision of Viktor Schauberger on Vimeo
                            It was noted long ago that every snowflake was individual what they do have in common however is … six sides. You will have seen that with each of Prof Emoto's crystals.
                            Masaru Emoto - Water is Life ( NARRATIVE VERSION ) - YouTube
                            It needs to be kept in mind that this is a natural phenomena .. and surly the reason for it is connected to your research .. In my own mind I have connected Tesla,Mayer,Puharich, and many others .. it also crosses over into the three battery system I am contributing to at the moment.
                            So lets see if I can make some sense of it! Our present maths and science does not recognise “free energy” and certainly not what you suggest Jetjis .. so any moron knows straight away the place we must look is where Maths and science can't go .. to wit .. The Infinite and the Infinitesimal !
                            Sine waves … Cosine waves … and the perfect pendulum can all be graphically constructed from the circle, But the circle Itself cannot be resolved Pi is an irregular number . We have no idea if its huge … or tiny. The cosine likewise can be assumed to be constructed from an infinite amount of the infinitesimal residue of the sine wave series . Every thing in “real life” seems to be so,
                            The six sides of water …. The work of Joseph Fourier
                            http://www-math.ucdenver.edu/~wchero.../srfourier.pdf
                            Tells us that fundamental frequencies adding together (heterodyne) F1 and F2 for instance do so algebraically so F1 and F2 become F1 and F2 also F1+F2 and also F1-F2 and of course these resulting frequencies again interact …. using energy each time and rapidly becoming undetectable.
                            X6 (6 sides … 6 frequency separation) is a series where this doesn't happen (perhaps the only one?) ,, the phenomena is pointed out by MJN in this post from long ago
                            http://www.energeticforum.com/water-...tml#post111774
                            This of course is how Mayer and Puharich fractured water using almost no energy . If you obtained your “blank water” like this …. I'm prepared to bet …
                            If you have followed the progression of six sides and the heterodyne Its logical to accept that in has a practical Inverse .. obviously being a product of two waves each resultant wave is even that is Harmonics ….. where are the odd numbers ? Where are the overtones?
                            My research seems to indicate that Joseph Fourier was involved with certain “secret societies” much as we would view “The new world order” today... I suggest he opted to selectively remove the maths relating to overtones. However they are still there … here described in music by EPD
                            The Science of Music by Eric Dollard (3 of 12) - YouTube
                            consider for a moment the “odds” (overtones) surrounding that magic frequency separation.
                            1...3...5...6.. 7...9 of course .. like the heterodyne example above going into infinity in both directions. Perhaps the reason Tesla is reported as saying
                            “If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.”
                            Taking the principle figures of that series .. perhaps you see the fit?
                            Some more History which seems to be selectively altered is the fact that Tesla's assistant was given the privilege of turning on the worlds first hv ac grid system .. (Tesla's 4 phase grid) … the last thing he ever did . The grid system was actually on its knee's … huge unexpected amounts of energy were flooding into it …. By far the biggest construction and investment in the world at the time was “In Peril” After the “war of the currents” Tesla and Westinghouse were obviously not on friendly terms with GEC. However the disaster caused by the natural resonance of six which must occur somewhere on an open line had to be sorted. This man did it … Mathematically
                            Charles Proteus Steinmetz: The Man Who Made Lightning - undated - YouTube
                            There is no other reason giant corporations who were arch enemies would be on the same project.
                            The trouble is as far as the money men were concerned the cure (a three phase de-tuned grid) was worse than the illness … “Oh yes Mr Morgan everything’s OK now we don’t need any more of that smelly oil and coal .. there's loads of free power available … “ no wonder his books were buried
                            The trouble is the lie and the evil has been hugely built on. By a progression of “Banksters”
                            I hope the links and diatribe give some food for thought Jetjs … I am of course considering that same x6 progression through crystal …(a crystallised battery) with the 3BS thread ..
                            .High frequency crystals are often designed to operate at third, fifth, or seventh overtones. Manufacturers have difficulty producing crystals thin enough to produce fundamental frequencies over 30*MHz. To produce higher frequencies, manufacturers make overtone crystals tuned to put the 3rd, 5th, or 7th overtone at the desired frequency, because they are thicker and therefore easier to manufacture than a fundamental crystal that would produce the same frequency—although getting the desired overtone frequency requires a slightly more complicated oscillator circuit.[11][12][13][14][15] A fundamental crystal oscillator circuit is simpler and more efficient and has more pullability than a third overtone circuit. Depending on the manufacturer, the highest available fundamental frequency may be 25*MHz to 66*MHz.[16][17] .. that extract from wiki
                            Crystal oscillator -
                            Wikipedia, the free encyclopedia
                            It Is likely regardless of … water … energy … blank water... batteries (crystals) Emoto's crystals
                            don’t you think ?
                            Kind regards Duncan
