Resonance Effects For Everyone To Share
  • #46
    Hi Joit,
    thank you for taking the time to do this test and post the pictures of your results
    Thanks for sharing
    Luc
    • #47
      Hi everyone,
      I just uploaded a new video to which is demonstrating a better effect.
      I must say that I'm surprised and disappointed at the lack of replies of my previous video ... Zero!... not even one post or comment from here.
      I thought we were all looking for a way to use a small amount of power and make more
      Maybe everyone here knows how to do this and I'm just not aware of it.
      If this is the case! then this will be my last post on this topic and I'm sorry to have wasted your time and my time to share.
      New video: http://www.youtube.com/watch?v=LBTSSHYrRJM
      and to All
      Luc
      • #48
        Luc, all your videos are great and I am enjoying all of them. I always give +5 stars, even if I am not commenting. Keep up the good work!
        I posted some questions about the input amp meter and extra coil setup on your video comments, please take a look.
        Jetijs
        • #49
          Jetijs
          Hi Jetijis,
          thanks for being the first to reply
          Your youtube comment:
          Great stuff
          If I understand it right, the input amp meter is connected on the AC side, but you use the DC side voltage in your calculations. Right? If so, then you should put an DC amp meter instead of the small bulb you had there so that you can calculate the input power from DC volts and DC amps. That should be better. Also, how is the other coil connected? Is it connected somewhere to the circuit or is it electrically completely isolated and just sitting there near the first coil?
          My reply to your comment:
          Hi Jetijs,
          The reason I monitor the amps from the 60Hz side is I know the meter will give an accurate reading at 60Hz and mostly because it is sine wave. However monitoring the the amps on the DC side when it is on off 350,000 times a second I don't think any meter will be accurate. Both coils are attached and in series.
          Luc
          • #50
            @ luc
            LOL
            Your stuff are appreciated, always, I dont have time to play with this new stuff yet as Im still busy with the water spark plug
            But will start posting once I got something to share.
            • #51
              Originally posted by Chris31 View Post
              @ luc
              LOL
              Hi Chris,
              thanks for your reply also
              It is a great quality to stay focused... just keep in mind that we may not need a water spark plug if we can create electrical power for free
              Got to go, I've got another coil to wind.
              Luc
              • #52
                Luc
                I'm keeping an eye on your thread. Last night I thought about something I noticed on my last video, and how it may be connected to effect you are experiencing... Btw, it only works for me if I'm holding the alligator clip, spark gap quite pitiful otherwise. I think it may have to do with whatever makes touching wood (my 2 videos before the one I'll post here) increase the spark. But obviously a coil connected at one end does something too......
                Keep up the good work, if one member of energeticforum.com makes a comment or asks a question that another member was going to say, the other person tends to just become a voyeur of the conversation until they have something else to add. Ie, look at the number of 'reads' of your thread - we're all watching closely, and your contributions are wonderful.
                Thankyou
                YouTube - Inquorate 19
                • #53
                  Answer?
                  I think it's an aerial. Tesla's magnifying transmitter wasn't just a tesla coil, it resonated at aetheric frequencies, allowing a channel of less resistance for the aether to flow. He was worried he might split the earth open! But found that electrons would eventually saturate the aetheric current and stop the flow at a safe level.
                  You may have found the answer I was looking for. I would have been a month behind you. I'll do what I intended anyway, and post results here. First I'll try high voltage and a spark gap to get high frequencies, then if that don't work, I'll duplicate yours and groundloop's circuit..
                  • #54
                    P.s.
                    @luc read my blog, bottom post first, then read bodkin's thread on rainbows and alchemy. Also read magnacoaster thread, listen to what the inventor says about pulsing coils...
                    Have you tried running inductive load, ie small electric motor?
                    • #55
                      Hi Inquorate,
                      thanks for sharing your information and your appreciation of the topic
                      Next video I hope to have some lights an motors running as loads
                      Luc
                      • #56
                        Hello Luc
                        please continue on posting the result in multiple forums .first there is the time difference in countries and i know you are working on this day and night
                        i still need to wait for my part to arrive i was postponing buying the scope but after we talked i bought the scope and a signal generator you inspired me to work on resonnace .
                        Najman
                        • #57
                          Love your stuff
                          What about a cone coil 60 degree angle?
                          Im finding it hard to wined but it will be interesting to see if tesla was right!
                          • #58
                            @ bodkins
                            What did tesla say about 60 degree coils? And hadn't thought about it until now, but yeah. That would be a beach to wind :-)
                            • #59
                              I just run around after you Inquorate
                              Chapter 1
                              Nikola telsa and radiant energy page 37 the secrets one!
                              "the most efficient tesla transformations were obtained only when the disruptive radiating wire line equalled the mass of the helical coil"
                              • #60
                                Thanks guys for all your replies of interest and support ... I was wondering why all this silence when things are getting interesting.
                                Thanks also for sharing your ideas. For over a week now the cone coil was on my mind also. So I've been looking at funnels to see if I could use the surface to wind the coil on.
                                We shall see
                                Oh ya, keep an eye on the topic at Overunity also, since much is happening there now: RESONANCE EFFECTS FOR EVERYONE TO SHARE
                                I wouldn't want you all to get behind
                                Luc
