Hi guys,
thanks for your posts and suggestions. I will look them
Just so you know, the research I do is intended to hopefully find an energy solutions to help the less fortunate of the World. I do not want to create waste of researchers time, money and resources. I need to find a way to test my setup so that we are all 100% confident of what we are seeing in my video demonstration.
I have an idea to test my setup and would like your opinion to see if my thinking is correct or not.
I'm thinking of buying enough 9v batteries so once connect in series I'll have the 47vdc I did my video test 8 with. I'll start the circuit with no load and monitor the volts and then I'll load the coils and see if the volts drop. If the volts don't drop and the caps charge then we know that what ever is at the capacitors (which are also under load) is extra power at no cost of amps. I think this should make it indisputable since the batteries in series will show instantaneously a voltage drop with an extra load since the power reserve is really equal to a single 9v battery.
Please let me know if you think this test is good or not.
Thank you all for your time
Luc
![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
Luc
