Splitting The Positives
My Tip is, the Coil start oscillating, and push something forward.
Since you allready play areound with it, i would try magnetic Wire, a unpoled Cap at the Side from the Diode, and maybe make the Coil larger.
Where is your Ground connected to?
Just to Batteries?
And even a Batterie has inside a Connection between - and +.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
After additional test...
The little coil in the Imhotep relay works fine as the coil. Just connect each side tab to one positive battery terminal.
It doesn't seem to matter which battery is where, they both charge.
If either battery is fully charged, the other seems to charge at a faster rate... but does NOT diminish the fully charged battery. I believe the earth ground to be important.
The highest charge I have seen on a battery in this configuration is 15.5v with a 12v 5Ah lead acid battery.
I still don't get it. It is tooooooo stupid simple.
Hi David,
Is your meter definately working properly?seems too good to be true, lol
Nikola Tesla
Sephiroth & DavidE
maybe because the batteries are sulphated
But if batt are sulphated, is possible by using another relay to charge a good batt conditioned with them. Obviously is very slow, but can works, here only we need the potential.
I've a sulphated batt and voltage is high with the SG, 14.4 volts within only a few seconds.Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Steve Jobs. Apple CEO
Based on prior understandings and experimental data... both batteries charging at the same time I have never experienced. Getting a handle on why it works at all may allow us to amplify to significant results. Daylight hours seems to produce best results, but I still don't understand the source of the mechanism.
Sephiroth
Bodkins
Have you tryed a load test?
Do any of you monitor the standing voltages of your battery stock? A few weeks back I started taking readings and noticed that some batteries would bounce between 11-14v. Different days, different voltages. These are just batteries sitting on a shelf. Its almost as if they are responding to environmental factors that change from day to day.
This circuit may just be picking up microwaves (or other) and converting them to usable voltage. I have noticed different rates of charging. And there is just a variable or two (actually countless) that may be causing this. In several areas I am working on the fundamentals, then proving that application of them will allow for scalability. The fewer elements being observed, the more likely to catch natures fingerprint.Last edited by DavidE; 12-18-2008, 01:12 PM.
RE: test..
I tried this last night and my batteries lost voltage. What is your ground like? My ground is 4 foot of 1/2 inch stranded copper wire sunk into the ground.
Always hopeful you have indeed found somethingSee my experiments here...
