Alchemy is a rainbow bridging the chasm between the earthly and heavenly planes
  • #31
    Whatever is below is similar to that which is above. Through this the marvels of the work of one thing are procured and perfected.
    equates this
    A fractal is "a rough or fragmented geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,"[1] a property called self-similarity.
    fractal property of nature
    Patterns of Visual Math - Fractals in Nature
    Fractal in Human Body
    Applications of Fractals - Human Body
    and
    4) The father of it is the sun, the mother the moon.
    5) The wind bore it in the womb. Its nurse is the earth, the mother of all perfection.
    6) Its power is perfected.
    7) If it is turned into earth,
    7) Separate the earth from the fire, the subtle and thin from the crude and coarse, prudently, with modesty and wisdom.
    8) This ascends from the earth into the sky and again descends from the sky to the earth, and receives the power and efficacy of things above and of things below.
    Magnetochemistry
    Magnetochemistry - Wikipedia, the free encyclopedia
    Magnetochemistry is concerned with the magnetic properties of chemical compounds. Magnetic properties arise from the spin and orbital angular momentum of the electrons contained in a compound. Compounds are diamagnetic when they contain no unpaired electrons. Molecular compounds that contain one or more unpaired electrons are paramagnetic. The magnitude of the paramagnetism is expressed as an effective magnetic moment, μeff. For first-row transition metals the magnitude of μeff is, to a first approximation, a simple function of the number of unpaired electrons, the spin-only formula. In general, spin-orbit coupling causes μeff to deviate from the spin-only formula. For the heavier transition metals, lanthanides and actinides, spin-orbit coupling cannot be ignored. Exchange interaction can occur in clusters and infinite lattices, resulting in ferromagnetism, antiferromagnetism or ferrimagnetism depending on the relative orientations of the individual spins.
    see also this post:
    http://www.energeticforum.com/138939-post37.html
    • #32
      Love it thank you
      • #33
        but its a internal process, How to make a golden soul, I be ready and happy about death (the place we came from)
        • #34
          Are we loosing the moon?
          In reply to the moon posts:
          The moon is in a stable orbit with the earth (source: links below)
          So we shouldn't just loose the moon, unless something else is happening....
          Creating Stable Orbits of Large Bodies
          Three Force Orbit Model
          ‎"It's all in the MIND"
