Originally posted by Joit
I've had an interesting few days with the units I built. They didn't work at all the way I thought! The "power coils" didn't produce squat, but the bifiler control coils did.
I built this unit:
I fed the control coil an approximately 1 khz square wave from a PWM. I drove the signal with an IGBT off a 12 volt supply. Initially the draw was around 5 amps.
The output from the "power" coils was negligible, although the waveform was instructive. This was a typical triangular wave normally associated with magnetic devices. However it was distorted.
So I started playing around with the duty cycle to try and clean up this waveform. As soon as I got a good waveform the current dropped to under 1 amp.
The frequency also had an effect, but in a much broader sense. The duty cycle was key to tuning this unit. The input / output ratio varied considerably depending on how it was tweaked, but typically it was around the following numbers when peaked:
The input was 12 volts @ 3/4 amp
The output from the control coil was 8 volts @ 7/8 amp
I could get an amp and a half from the control coil @ 10 v but the input went up to about 6 amps.
I have to say that I don't fully understand this mechanism yet (understatement). I think the problem with the "power" coils is that the domains in the iron never get flipped. The flux only flows in one direction, although it gets interrupted. Just as there needs to be movement with a magnet in a generator, so does there need to be movement of the magnetic field through a coil.The molecules need to be flipped to generate any power. As they roll over, their fields cut across the windings of the coil, producing current. I don't think this happens much when all the domains remain aligned from one cycle to the next. The field expands and collapses, but that doesn't get you much power.
On the other hand, the domains within the control core are definitely flipping. Once the duty cycle is dialed in, the magnets start to have an effect. How much of an effect I won't know until I test the control coil without any magnets attached. But if the magnets do help with efficiency, this could be a very interesting road to explore. I'll do some more work today and see what happens.
Ted
