Radiant Matter
  • Radiant Matter
    I dont know if any have read this but it is entirely on the subject of radiant energy Sir William Crookes - On Radiant Matter This appears to have been written before tesla did his work on radiant energy and was a follow up faradays theory of radiant energy. Tesla however was able to create it without pulling a vacuum which is remarkable. Tesla placed emphasis on the requirement for a unidirectional pulse which must be what the vacuum pulled on the gray tube allows. He never mentioned it i think but tesla probably discharged his hv from a coil as well.
    So the one universal requirement then is to have the hv discharge from a coil and the required condition was to have a unidirecitonal pulse which in one case was done with a quenched spark gap and the other a vacuum in a tube. That would seem problem solved.
    In the book it is mentioed faraday lectures on the topic. Would anyone know where i could get a copy
    I have read that Sir willaim crookes book changed teslas life, he read it once and remember everything in it for the rest of hes life. great find dmonarch
    The Cathode Ray Tube site, Crookes tubes.
      Tesla and Crooke
      Thanks Bodkins. I didnt know that tesla had read it. There is allot of information in those few pages, very cool. Wouldnt it seem to a degree that the gray tube is very similar to Crookes tube.
      A worthy note as well would be that it would seem once the radiant event had been created the positive pole is no longer necessary. The radiant pulse extends out in all directions longitudinally and can be collected or create an electrical event by any piece of copper it comes in contact with. It would explain how one wire electricity works as even after having been collected by the copper it still has no requirement for the positive pole. Teslas remarkable one wire light bulbs would work now. Maybe still producing that same glow against the glass the Crooks noticed. On top of this the cool thing is once the radiant event has occured it would seem that getting more energy out than you put in is simply a matter of creating a larger area coper plate. Thats just plain brilliant.
      Originally posted by Bodkins View Post
      I have read that Sir willaim crookes book charge teslas life he read it once and remember everything in it for the rest of hes life great find dmonarch
        Thanks Bodkins not boring at all. What kind of setup did you have to carry out the Crookes experiment, that is the how did you get the ignition coil to charge then discharge into the tube automatically. I need a rig like that myself. Do you reckon a bifilar coil in self resonance ala bedini would do as a hv source. You could use the back emf to go into an evacuated tube have the carbon on the positive side to encouragee the radiant production.
        Also do you know of any other of Crookes online matarial i can read.
        dmonarch
        I dont what to bore you but if you like crookes watch this stuff i have been doing its all ignition coil stuff
        YouTube - Bodkins 14 BEDINI IMHOTEP TESLA
        Just copper wire
        YouTube - Bodkins 20 stratification effect
        striations
        YouTube - bodkins 45.AVI
        Aurora (astronomy) - Wikipedia, the free encyclopedia
        Always look at nature.
          YouTube - bodkins 44.AVI
          this may help for my setup inform very easy to do. I charge a cap with one wire thanks to arron (note i charge from the negative pole) and the bulb on the ignition secordary will do a diagram if that helps.
          About Crookes im for sheffield where he did the lecture, these a area called crookes after him.
          I will check the local librarys for info.
          I found lots about him in the psychic area read this and you will see why!
          Sir William Crookes Spiritist Society
          'Thirty years have passed since I published an account of experiments tending to show that outside our scientific knowledge there exists a Force exercised by intelligence differing from the ordinary intelligence common to mortals. I have nothing to retract. I adhere to my already published statements. Indeed, I might add much thereto."
            Spiritism
            Thanks for the info on the setup. I think thats what i will do or similar.
            When your reading your always looking for correlations and that seems to be what Crookes work shouts. Ruby was prized by king solomon the diamond in kabalah for the crown chakra. The ability for the radiant matter to move something and to cause the rotaiton of a wheel, conects the radiant matter with light as it is iable to do the same, and as well with paraphysics in raguards to a person being able to rotate a light wheel as well.
            The ability for certain matarials to phosphores when the radiant matter is released is maybe how the pineal glad is able to see. It may have a substance in it that does phospores and so when radiant matter hits it you can see. Maybe thats why some can see the light and others cant. We have a very deficient diet and so it may be purely a matter of bulking up on a supplement. We mustnt forget that we are machines which experience through it and if that machine is not oiled well your experience will be limited. I know of one supplement that has just this effect which is sulfur (MSM dosage important) so maybe phosphorus is one as well however dont know if that can be taken in any form. .
            The question is then why does Crookes radiant matter stop at the glass and go to light. Maybe he didnt use as high a potential as tesla did who could cause shock waves through anything.
            Maybe tere should be a forum for reproudctions pure like that of crookes, and this forum be the research. I dont know just grabbing at space as there seems to be a space that needs filling. It would just seem like good science to atleast reproduce the work of the greats exactly then refine.
            Sorry got of topic. I just love finding the gaps and talking to similar minded.
              Sir William Crookes
              Hi Guys,
              The term "Radiant Matter" was coined by Sir William Crookes. He became interested in the properties of matter and started a formal study of "what is happening" when matter is heated to the point of "incandescence", where it turns red and starts radiating heat. The question is "what is being emitted?" and "what is conveying the heat?" This is a fascinating topic of inquiry and I encourage everyone to look into it.
              Crookes determined that "what was being emitted" was tiny particles of matter. (It is my opinion that the particle in question is some form of what would be called a Neutrino in today's Particle Physics terminology.) To prove the emission was actually matter, he invented the Radiometer, which is that cool little spinner in a vacuum bulb that spins when light hits it. The "proof" was that the particles would penetrate the glass without destroying the vacuum in the bulb, but they could still "convey momentum" to the veins of the spinner, making it spin! Anything that could "convey momentum" was exhibiting INERTIAL PROPERTIES and therefore MUST be matter, and not energy (like some wave front)!
              Nikola Tesla was a personal friend of Crookes and they corresponded a great deal. Tesla called the Radiometer "the most elegant motor ever conceived"!!! Tesla's term "Radiant Energy" was derived from Crookes' term "Radiant Matter" and refers to the situation where the Radiant Matter particles are conveying electrostatic charges.
              Lots to learn.
              Have fun.
              Peter
              Peter Lindemann, D.Sc.
                Greeting Peter
                Thank You for you insite
                The Radiometer is one of the greatest things i have ever seen.I having spent a lot of time looking into the arguments of the momentum.
                If the question is, what can Radiant Matter do? I can only say from what I have experience with experiments with light bulbs.
                YouTube - Bodkins 4 lamp trick!
                I need to think on this a bit dmonarch
                  Radiant Matter vs Radiant Energy
                  Hi Peter. Tesla noticed a luminosity in his labratory during radiant energy production at certain frequencies. Could it be simply that the various effects noticed by tesla are due to him using higher energies and higher frequencies.
                  So in actual fact just like the brain though the information coming in or in this case going out is a singular pulse it is not actually what we are percieving but instead the period between the pulses is the experience.
                  Its kind of like creating a division between the machine reality runs on what we think of as ourselves and experience. Disregaurding all the complexity of the brain and simply treating it as a bunch of neurons you have a storage device. The brain reacts to incoming pulses but our mind, concious is not the brain otherwise we would have direct experience of the neuron and its other physical components. So if all we have is impulses then we, our memories our concious mind must exist in the periods between pulse events.
                  My point being if it is possible that we exist in such a construct then it is possible that the experience of reality is running holographically in such a construct. Tesla required fast rising unipolar pulses but found that it was the period between the pulses which altered the effect. I know it seems a little of track but it isnt really. Maybe tesla was a pioneering software developer for reality. He drew the line between the machinery and the experience.
                  Heres the cool part if you think of everything having this holodgraphic component, that is it reacts to a sharp pulse then the only way that infomration can be passed between matter of different kinds is if the period between pulses can be transmitted by the hardware/machinery of the matter involved. Thus Crookes radiant matter would not pass through glass or mica due to the pulse duration and period being incorrect which Since we know light has the high wave length the pulses must have been compressed litterally against the glass to produce the wave length of light. Which then must mean the fluid or aether is uncompressible to a small degree. This would explain why as well the wheel turns as these uncompressible waves bulled up and push against the mica. That siad there should be a spring like nature to these compressed waves which is exactly what we experience it come to magnetic fields which must be then a compression of waves. The magnetic having effect on the radiant matter beam suggests a sink and that it is able to effect the beam due to it containing multple harmonics as other wise the magnet wouldnt be able to penetrate glass and effect the beam.
                  Gosh knows. All it takes is one statement to be worng for those to come after it to be wrong. It is a very interesting topic though and could talk about it constantly. Does any of this seem valid. It would explain why we have a hard time explaining what energy is. Maybe we should start seperating the two,, that is the machinery upon which reality runs in the local region and the experience itself
                    I aggrees the universe has a pulse to it or should i say our observed(by us) local time has a pulse because we can charge battery with the unobserved time difference pulse.
                    Once again I ad a video plz forgive me this is a better way for communicate my mindset
                    YouTube - Bodkins 39 Time.AVI
                    and now i think of striations and the state that the bulb are in in time.
                    But if i touch the bulb the striation speeds up like matter going down hill or time moving fast with my touch.
                    So as you put it the holodgraphic component Maybe time, that we Make with the machine,our mind.
                    Yes i making a jump here!!!!!
                    So if Radiant time hit he glass in the crookes model the glass lights up, But the glass gets tired!!!
                    interesting the glass gets tired, tired of time!!!
                      Good point about time
                      Way to go keep it coming, im loving the videos. This would mean that time is the average density of pulses (mass) in the local area and graivty and time are kind of one and the same. Dude thats excellent stuff. So a density of anything slows down time being it radiant matter or otherwise. OOh and heres the cool part capacitance/magnetism is just that local densiity. This would put into focus why Bifield Brown was focusing on an asymetric capacitor. Turns out though the charge density is greater in a magnetic field maybe not so using fractal forms such as the pentagram and that magnetism is the better way for now to create the necessary sculpted charge density. I would assume this does actually antigrav due to the rotation placed on the magnetic field otherwise it would just be like a boad on an air table. Mmm i love this stuff. It smells of nerd lol
                        LOL now i need to find out about Bifield Brown
                        one thing if you get a ring rotating around a sphere i think it can give lift.(i think being the word)
                        at work at the moment will be back
                        Nerd no way
                        I leave you will this
                        It's just a ride and we can change it any time we want. It's only a choice. No effort, no work, no job, no savings and money, a choice, right now, between fear and love. The eyes of fear want you to put bigger locks on your door, buy guns, close yourself off. The eyes of love instead see all of us as one.
                        Bill Hicks
                          Interesting Experiment
                          An interesting experiment would be to take an electrophorus unit. Take a piece of metal in the shape of a pentagram . I choose pentagram because it rotates and repeats endlessly. Place it on the charged resin discharge to ground, remove from resin while being insulated and take a look at the charge denisty. At a guess it will produce an ionic column from the center. Or even neater is that because the fractal rurns in both direction that a helix like the one in the link you posted did Bodkins. Though it wont have as much energy as that. Who knows it may be that the fractal nature turning inwards may actual suck the charge right from the outer surface so i guess the other experiment would be to take a round piece of metal with the same surface area as the pentagram and test which discharges the quickes in open air. Because it is a conductor it should have trouble.
                          My reasoning behind this is that the better we are able to create charge denisties and control them the more control we will have over radiant matter, time, and gravity.
                          • #14
                            Electrophorus where is that book ?
                            Kirlian photography - Wikipedia, the free encyclopedia
                            • #15
                              Funny stuff
                              Thats some funny stuff dude. I like the bottom paragraph it is so absolutly true. They control everything but cannot stop you from not being controled.
                              I have never heard of that ring and sphere but if that is true then it would be correct then about the magnetic field.
                              Ok then here is a puzzle. What is inertia? Remember its the desire of an object to continue in a straight direction excluding all else. Just think of gravity, youll get it.
                              Man this is the most ive had for ages. I really dont often get to talk to other people interested in stuff like this.
                              Nerd no way
                              Bill Hicks
