Hi folks, I have been running some tests with a permanent magnet pulse motor and I'm seeing results that dont make sense as far as the equality between applied voltage compared to induced voltage also known as cemf. I am aware of all the work of Peter Lindemann and the no back emf design however when using standard motors as examples of the cemf those designs never have a breather in between pulses compared to a pulse motor that doesnt alternate coil poles and allows a breather in between pulses. I do have a question about properly measuring the cemf in a motor, because when i apply my voltmeter across the motor coils which are all in parallel/series i notice as im sure most here are aware that AC voltage is created when using all north or all south facing a coil but im only seeing with a 24 volt input 2.9V however im not so sure that is the actual voltage being input. the reason im not so sure is because when spinning the rotor at the same speed it correlates exactly to that voltage minus 1.4v for darlington pair transistors which actually makes it 1.5V non powered generator mode is all my motor can induce at the same speed as the motor would be running at. So what im saying is i think this motor is actually getting 21V through the coils or a little more if the transistor voltage drop could be lessend. So What do you folks think, am i missing something here as far as measuring this.
peace, love, light
peace, love, light
