While surfing the patent data base, I've found a flat pulse power coil which I can use in my high power smoke ring launcher. My low power version is a speaker with a plate over the front, having a round aperture. Even though it's a ten inch speaker, it still launches a nice smoke ring, fairly rapidly, when powered with a pulse from a little 9V battery. With this flat coil, I can increase the power several thousand times. Back in the 1940's, German scientists and technicians experimented with this type of device, and were able to knock over a brick wall at a range of four miles. I've found out that the ring vortex makes an excellent 9V fire extinguisher - on a small scale.
Here's the coil, used for electroforming of thin metal sheets:
Apparatus and method for pulsed ... - Google Patents
I found another patent which tells an easy way to make this coil. They silkscreen the pattern onto an insulator, such as a polypropylene sheet, painting a type of glue which is cured with UV. Then they place a sheet of aluminum foil over the thin glue pattern, and apply pressure and heat, such as with a clothes iron. After it cools, any aluminum foil which is not glued down is peeled off, leaving the pattern. The edges are then brushed, to remove any jaggies. I think I can make a coil with regular glue, although the silk screening would produce a more uniform pattern.
Hot stamping glass - Google Patents
Then I found a flat motor for a bicycle, with a printed armature, something this process would be ideal for:
Flat rim type motor drive mechanism ... - Google Patents
Here's a patent which shows the rotor pattern:
Rotor for printed-wiring motor - Google Patents
Who knows? I may come up with an EV Gray type motorcycle.
With silk screening and the right kind of glue, thin line spirals can be made. So this process would also be good for easily making pancake coils, including the bifilar kind.
If anyone wants to buy a vortex fire extinguisher, I have one for $50.00. By offering to sell one, this goes into the Public Domain after one year, whether anyone buys one or not. If someone tries to patent this, it will take longer than a year, so the idea is safe - and free.
