amp fluctuation during electrolysis with self oscillating relay?
  • amp fluctuation during electrolysis with self oscillating relay?
    Hello,
    I am a beginner in applying ether energy. I done some simple experiment on electrolysis and now trying to add PWM or similar kind. I am at the beginning of reading Imhotep Radiant Energy but already read panacea bocaf document and want to try it on electrolysis, with the thinking that relay can be used as some sort of PWM too.
    I can't make the Imhotep original circuit to produce bubble on electrolysis cell. So I modify it a little with assumption that electricity move like fluid. I paralleled self oscillating relay with electrolysis cell.
    The result is making me confuse.
    This is the video:
    YouTube - tuberelayexpclip
    Whenever the relay is in self oscillating mode, the amp meter will display a reduced value, or sometime a multiple value than when the relay is off. At recent test (no video) I notice that the current will reduce when I grab the switch cable (see picture) tightly. The current displayed in amp meter will multiply to twice or sometime 4 times when the relay is put inside synthetic leather bag.
    The current will be reduced to the same amount no matter what the load is. If the load draw low current, the amp meter will display negative value. But when multiplied, the current will get twice the normal load would be.
    I don't know if this relate to ether energy or not. But I really want to know what happen, and if possible make use of it.
    No audio
    Hard to tell what's going on in your video but from your description you've got lots of weird effects going on... Will try check some of it out...
    thanks for your input, for a 'mere beginner' you've been noticing a lot if irregularities and we love weird and cool here :-)
    Keep up the great work!
