Aromaz Radiant Energy Joint Research Group
  • Hi, nice Videos at all, impressive.
    Right now i got a funny thing at my second Bedini.
    I have 2 Coils behind there, and when i start it, it only turns slow.
    I need to adjust first at the Pot to a 'idling Rpm', then i can turn it higher.
    Its like, Frequency needs first to settle at a certain Point, and then you can push it to a higher Frequency.
    Mind to put a Pot at the Min 6:30 or 8:40 from your Video at the secondary or primary Coil and turn it around a bit, when a strange Thing show up?
    A think, a resistor at a Coil is like bloading the Coil a bit bigger.
    Maybe just need to catch up the long Waves, that they stay into Resonance with the other Coil.
    Edit.
    Maybe there is a Way, to 'pump' the big Coil into the small one.
    • I can't find references to neon gas being purple
      Only to neon gas being orange, and to purple 'neon' lights / signs being different colors due to other gas mixes or due to the use of phosphors.
      90v neons being made of argon and neon gasses, yes. Lighting orange, yes. Purple mushrooms, no.
      We have a problem, hueston.
      Ps, I think I have the answer.
      • ''orange neon'' purple flash
        Put the above into google, and apart from web page design color choices, and clothing colors (seriously, that's SO 1980's...) you will get my own posts.
        WTF?
        Nobody has noticed before? UM.
        Hueston, looks like we ain't coming back down..
          ''in a dc exited lamp, only the negative electrode glows'' - then why does an ac current between the collector and emitter of a 2n3055 glow on the emitter (negative) side (from dc applied to primary converted into ac sine wave in secondary of Bifiliar wound coil), and when manually sparked, does the neon emit purple mushroom cloud enclosing whole neon globe?
          Because switch on and off thru spark does not create 'conventional' electricity?
          Methinks 'yes'
          Try connecting the two points to bridge rectifier first, then to NE-2 and have a look again. Been doing it all evening through out my original plus new single layer coil systems and got some clarity on a few mystical points.
            WTF?
            I am lost ?? What post with purple clothing?
            Like dancing feet? Try purple socks!
            No serious, pass me a link, not find in Google, unless I am posting wrong. Now first go home to see what Obama said between his lines - and sleep.
            • Not many, to be sure..
              Seasonal Colors
              https://www.onsalepromos.com/products/762030340
              Vans - Classic Slip-On ((Checkerboard) Neon Orange/Neon Green/Black) - Footwear by Vans - masa.la/shoes
              But some, nonetheless. Which is far too many
                Methinks 'yes'
                Wiki:
                AC/DC .. what about if the neon is in "the air" unconnected to a circuit/power source .. they didn't cover that one .. DID THEY!?
                They didn't cover electrostatic lighting of a neon .. did they .. it's a cliff-hanger.
                That color thing, purple, orange, black or blue, could just be a "in the eye of the beholder" kind of thing
                Last edited by Vortex; 01-20-2009, 11:48 PM. Reason: to clarify I was speaking of wiki info
                • Originally posted by Vortex View Post
                  Wiki:
                  They didn't cover electrostatic lighting of a neon .. did they .. it's a cliff-hanger. That color thing, purple, orange, black or blue, could just be a "in the eye of the beholder" kind of thing
                  Observation is needed my friend; If you experiment and look you will find much more value in the NE-2 than thought of before.
                  The purple colour is also in the eye of the camera - you can not see it direct because camera does not register due to light effect; but you can see the purple as reflection; like on the casing of the transistor.
                  HV in the air does not need to go through the legs of the NE-2, the HV itself excited the gass directly - and make light. The terminals are not lit from their legs, it is reverersed Excited gas lits up the terminal! Look closely and carefull. Similar effect when holding the glass tube in your hand - increased antena and gas illumination.
                  Put two copper plates some distance appart (as antena):
                  A: Connect them each to one leg of neon and observe,
                  B: Connect them to bridge diode and then to neon and observe.
                  Above I have a posting with static experiment in neon.
                  Only one filment lits up.
                  • Yes, yes,
                    Static one leg, hv / radiant?? (i'm beginning to suspect only partial radiant in form of voltage spikes - will explain in videos later) one or both legs also more inbetween, depends.
                    But why purple flash?
                    Why so damn bright?
                    Why mushroom cloud, independent of neon electrodes?
                    Is it a quicker switch off / on than transistor ?
                    What does it look like on a scope?
                    Can we devise method of making it constantly purple? What would THAT look like on a scope?
                    None of these questions are rhetorical.
                    • Increase effect?
                      I'll see if I can find a metal cog, put it on my electric motor, and have it striking the end of a wire. Another wire or bendy razor blade contact on the flat of the cog. Instant switch.
                      Or try a hv quenched dc spark gap..
                        I have tried with three different kinds of NE-2's (not same supplier and slightly diffferent in shape/size) can not get the purple flash which makes me think it might be due to gass composition.
                        Anyway, the neon detective helped me to test AC-DC all over and with slight modifications I can actually charge 80V capacitors from the two wires around dluorecent tube - up to 48V. Either one of terminals form copper wound and aluminum foil antenna on the other side - up to 28 V.
                        Now going to attempt the not so possible......
                        Remember your experience before with HV/HFq spot burn? Had the same last night. I was sitting relaxed and playing with neon detective when I started smelling burning flesh - but felt none. I froze and just looked around. No connection - until I see my toe is touching the ground plate, which just happend to be connected to base of 2222. I looked and saw a nice black spot and smelled it. After shower two hours later it was still there. This morning it is gone, no one smallest indicator that it was ever there. I tested the same setup - not with my toe! Was surprised to see it does in fact has corona like spark and burn track through paper.
                        • Thanks Aromaz
                          Thanks for trying Aromaz, I'll see if I can get different neons to work also, it was very hard to duplicate for me too, ended up just brushing two single strand copper wires inbetween neg of battery and emitter, not as bright as using neon leg as switch, but more reliable.. I put wire around end of screw that protrudes off end of bolt from side,. Glued nut down, and glued another wire close to end of the one on the bolt. Turning screw back and forth quickly so wires sparked when contact made/ broken made purple flashes reliably.
                          • Neon Detector
                            Remember that there is a requirement of +30% more energy to get the neon bulb started, to light it up initially, than it takes to keep the neon bulb lit continuously.
                            @Inquorate and Aromaz
                            I was joking around in my previous post.
                            I remember someone speaking about, they were using something as a shield.
                            My question to them would be: Was it really a shield or a reflector ?
                            A shield would be great, but a reflector would be a great thing to find.
                            • Shield
                              That was Electrotek, and it was magnetic tape from old vhs. I can't find any.
                              I got that you were joking too ;-)
                                Yes to overcome the dielectric gas and make ions jump - you need in most lamps as little as 45 Vdc. That can vary according to the space between the probes, so you will find most probes slant closer towards the tip.
                                This voltage is affected by temperature too. I heated a NE-2 up to 120 deg C and then only needed 22 Vdc to get them lit – and keep alight with 16V in a NON-HV environment. I repeated a similar experiment with corona discharge yesterday, by heating up the copper pad I am using as spark base, I actually got as far as 37mm blue corona sparks – much better than maximum 12 mm before on same circuit.
                                However, when the gas is lit from HV in environment (or your finger/body antenna) it does not need this voltage and the reverse actually comes into operation – the gas heats up the probe.
                                Any metallic sheet can be either. Or collector. Or magnifier.
                                A) If you ground earth the sheet metal/foil it becomes a shield.
                                B) If you connect a wire to it and use that wire as terminal somewhere else it will be a collector.
                                C) If you just use it not connected but curved it will act like a reflector - as I did in some of my older videos where I played with lights in front of aluminum and copper reflectors. For the same matter, try to get a discarded TV Sat dish - they are in fact pure energy collectors. Interesting reading from people who install these sat-dishes; the bigger ones sometimes shock them even long before connected to any power supply. First thing thy do when setting up - is to earth dish!
                                D) It can also be used as magnifier if you pulse a small current through it - refer to older Radio technology in how they amplify the antenna to appear bigger than it is in order to capture much bigger waves than the size of the antenna.
