I don't think a 4th dimension is necessary to explain charre, etc as above page suggests. Because voltage polarity is due to actual potential difference, free electrons travelling up into sky as lightning, and pos nuclear particles travelling down as gravity - is not subject to perspective. No need for 4th dimension to differentiate between someone looking up and seeing clockwise spin around verticle axis, and someone looking down and seeing anticlockwise rotation around verticle axis - as up and down are a result of gravitational force resulting from and causing up/down difference.
There are a number of ways to get alternative energy.
I do understand what we should do and what the possibilities are;
only problem still remaining is the BIG one; By what method?
The options are:
1. To break nucleus apart - yes it can be done, it is done right now
in CERN. It does not need to form a chain reaction. Scientists know
how et al - but it is VERY expensive.
2. To change the Proton to electron - been done in nature; and now been
done in CERN
3. To change Neutron to Proton or electron - Been done in nature, not yet
done by scientists -though they are working on it right now.
4. To use neutron to capture photons and then release in energy form.
Theory only, based upon possibilities of quark’s.
The above is definitely beyond our capabilities - even if all of us work together;
financial requirements are huge.
Below are options which is possible on small scale and within reach of a
low budget experimenter.
4. To charge electrons with photons and to release those photons again.
There are number of options to look at here, basically it is the same
science on which solar cells are based. Can you design a better and
more efficient way? I think Tesla also did extensive work on material
being exposed to HV, HF and light intensities.
5. To force free photons together and then use them to activate electrons.
6. To capture free electrons from aether/vacuum - This is the methods I
am pursuing now in my elementary lab; together with lots of theoretical
research.
7. Magnetic field: This is probably the highest possibility and will be my next
option to experiment with extensively. In this case I am referring to the
possibilities of making magnets self oscillate; or possible high speed vortex.
I am sorry folks, reality beats the dreams; but the dreams can change;
Now Corrie says; "If you can not conquer your enemy, then join them by
making yourself appear to be one of them; while you use their proviand to
prepare yourself for battle - from within"
Now that I understand the processes as presented by conventional science;
And I understand the basic process as presented by Quantum Physics;
And I understand the basic process as presented by various AE promoters;
- though the Quantum is not all proven;
- though the Alternative Energy is completely unknown
I am trying to see how I can use these ingredients to make my own cake:
My current direction of thoughts:
Stage 1:
How can I capture electrons from the aether?
---> By using magnetic force first to extract max possible electrons from a
material (Base plate) and pass them on to Stage 2 and Stage 3
---> Then bombard the material with electrons from aether – catalyst like Barium & Infra Red? Other option I want to try in coming week is use of
liquid Nitrogen and UV3 radiation.
Stage 2:
Then super energize them with photons;
---> By exposing electron saturated matter to High Frequency light (UV2 for now)
Stage 3:
Pump/pull them through a conductor
---> Coils and motion at high speed
---> Use that energy to oscillate magnetic fields – THIS IS A ???????
Stage 4:
Then release the photons to recycle back to stage 2 as catalyst;
---> Current, Amps, similar like CEMF action ?????
And use the electrons to keep the cycle in motion;
---> Magnetic control, spark gap and vortex motion ????
I think I have done Stages 1 & 2 quite well, just waiting for some money to build
a system for observation, verification and monitor.
I will cut and post videos soonest I have some reasonable
equipment to show measurements. Unfortunatley I will most
likely have to build them myself, fortunately there are some
ideas and contraption designs floating around the ether.
More help in this matter will also be appreciated.
More practical help - hope to be back on board experimentally in the next week or so. Was going to buy Oscilloscope this week, but fridge died in this 35 + degree heat.
Anyhoo, more reading, this one not so much 'theory' but closer to 'method'.
Hey, if we practically cancel out magnetic field in a coil by making Bifiliar pancake coil, and the magnetic field is not there to resist change in magnetic current, will the voltage then only rise at instant of switch closure due to electron bunching effect? And can we energize another coil with this voltage, (not Bifiliar winding of same coil)
Subtle twist on the tesla coil? 1 to 1 ratio..
Hey, if we practically cancel out magnetic field in a coil by making Bifiliar pancake coil, and the magnetic field is not there to resist change in magnetic current, will the voltage then only rise at instant of switch closure due to electron bunching effect? And can we energize another coil with this voltage, (not Bifiliar winding of same coil) Subtle twist on the tesla coil? 1 to 1 ratio..
I am not sure how you will be able to affect another coil if there is no magnetic field?
Though there is something in the far back of my mind of a gent in the 1840's that generated electric charge with two coils connected like this; not to have actual current flowing. I seemed to be more of a ping-pong game with some energy taped off for whatever he could use it on - that was way before Tesla or Edison. What did they use electricity for in 1840's ????
Dr Tewari (Prof in nuclear physics, physics and maths with very broad spectrum of knowledge) - probably can say genius - doing great leaps into alternative energy research. He has the resources, students, manpower - and the Indian government behind him - with very big financial support from both government and private sectors. I followed a series of 32 hours video from him in December. I have very big respect for him. Best still: He is not only doing theory, but he also design and execute many experiments to verify his theory. What you describe above i9s very much what Dr. Tawari did with his Space Power Generator.
As far i did see from the last Aether Theories, Aether is the Force.
So Aether is the Force, what is the attractionfield, or the Force what appears from the smallest Parts.
Even the question is, are the parts at last, or only Force, what alligns Particles or creates Particles.
You can affect the Field with an other Field, to use it.
But thinking about Aether still makes a feeling like a Big Stone in my Tummy
Anyhow i only can count 4-5 Forces, wich i can allready align to other things,
as to the Aether thing. :P
The Field around Wire or lead does allways exist, so you cant really cancel it out.
Maybe it will move at on other Way, or align better, but never been gone.
It is complex, when you start thinking about how the Magnetfield will start align in different Variations, even, when you turn a steady Field, like magnets glued on a Disc, and you turn it, the Field appears at an other Point,
and even the Direction of turning is importend.
And maybe sometimes, it will build a Dipole, what is in 90°, and is stronger then the other Field horizontal,
or swap the Poles at an other Coil, when they are close.
I think, there is still a alignment of 2 Fields, when 2 Coils are attached together.
But well, at last, i am for making a Potential, like it happens at Clouds at a Storm.
You load one Side Negative, and have a positive Side, and can wait, till Current happens.
But you need to have allways a Balance to this both Sides.
Means, you need to charge them both all time, that you must give, and can take (or become).
Like JB says, just pushing Electrons at one Side of a Pole doesnt make Sense,
when the Charge will start boiling.
The System still need to be closed at one Part.
But all theorie is nice, till it starts, to going to be practice.
A virtually unlimited field of energetics, accessed by tickling Mother Nature’s sense of balance. She is infinitely willing to perform for those that can master her vibrational initiation.
A radiant energy world once embraced will likely require a new mathematics, new resultant theorems, and even a reordering of historical fundamental principles. This regauging of beliefs once applied, will have us see things of immense scale in a new way. This new awareness will likely teach us “that which we once believed was infinitely large and complex, is most often made up of that which is finitely small and simple.”
What John Bedini (and others like him) haven’t said but implied is of greater importance than what has been diagrammed and made obvious. Mr. Bedini knows that the only way to protect that which is infinitely valuable to mankind, is to provide it through an unquenchable new world of language, learning and discovery by all of humanity.
So to say that Bedini’s snake oil lamp is only good for lighting, is most likely missing John Bedini’s real message. In his heart, I do believe he does want others to see the light… but not the obvious glow, but the infinite potential of harnessing that which is unseen.
@Inquorate;
The De Palma machine has been resconstructed by number of people, to the
exact details available and with variations. Nobody else to this date could
get it to even work economically. I do not say that it can not be done; but ?
@DavidE
Personally I do believe that the ultimate answer is going to be in manipulation
of magnetic flux in combination with manipulation of electrons. Each of the
people who did had some success in this field, had their own ideas.
Strangely enough that none of them are the same as another.
