Aromaz Radiant Energy Joint Research Group
  • #76
    @Inquorate, thanks . In here car coil is valuable even at junk yard. It still have price at about half of the new one or even more .
    About aether, I think we should try to make a squarewave as perfect as possible since Tesla mention that it is the power being cut that make radiant energy radiate.
    • #77
      Gentleman,
      What do you all think of the idea that a co-ordinated effort should be undertaken?
      The advanced researchers could team up with research assistances, and be overseen and co-ordinated by the project head.
      I, for one, would be happy to assist one of the advanced researchers.
      My guy could have me verify his findings.......... run down side ideas as they occur to him, thus keeping him on the main track........etc.
      Some of the expense for material could be attenuated due to less duplication of parts needed, and so on.
      What think you all?
      Carl
      • #78
        Let me put forth Aromaz as the nominee for project manager.
        I put the motion before the house.
        What say you all.
        Carl
        • #79
          Radiant Effects In My Picture
          @Carl: I think you've got a good idea.
          @Everyone: I've built an electrode assembly which produces Radiant Energy when a bisphasic spark is discharged. When the central electrode is copper, here is the picture:
          http://www.energeticforum.com/attach...relectrode.jpg
          The upper right hand corner of the picture shows three secondary but distant effects from the discharge. To see these effects clearly, it's best to download the JPEG and open it with an application which allows the image to be enlarged a few times.
          First, there is a yellow light which corresponds to the position of a meg ohm value shunt resister across the terminals of one of my other capacitors. (Not used in the circuit.) This seems to be projecting a fountain of energy upwards a short distance. One end of the resistor is pointing towards the camera.
          Second, There is a blueish green energy at the top of the door bell transformer used to power the small motor in my interrupter. This column of energy is just to the side of the welded top seam of the transformer, and seems to be discharging some additional energy to the weld itself. Or to a point just to the left of the weld.
          Third, there is a complex pattern of yellow energy above the interrupter's top strap electrode. There is no corresponding physical object in this location.
          When I used an electrode with a different composition which localizes the Radiant Energy, none of these effects were visible.
          Any thoughts?
          • #80
            I am not sure what Aromaz will think of this idea.
            He has taken a bit of a sabbatical.
            This is a case of the cats away and the mice play.
            Carl
            • #81
              Distant lights
              @ Electrotek - that's way cool. Are both electrodes copper? Do you have carbon resistor in your gray tube?
              what are the discharges like? Luminous gaseous discharges? Ethereal, translucent, semi-transparent, flame-like, plasma ??
              Can you post video?
              Perhaps you have inadvertently set up conditions for making aether luminous??
              What is the frequency of system?
              Thankyou for posting those observations..
              // as for a project head, I say nay. If we all were working on same experiments, we wouldn't have noticed all these odd effects, like Aromaz's 'electricity' without current, my caps not charging at a distance but still lighting neons, etc etc......
              But I would say that any member using this thread who shares details of their experiments who can duplicate their own 'weird effects' can ask another member to attempt to duplicate it...
              do we owe each other that?
              Just
              • #82
                Check out this guy's experiments!
                If only he knew about the aether.
                WEIRD SCIENCE: The Morton Effect
                • #83
                  Carl
                  @Carl; thank you for the compliments.
                  Though the cat is away; it does not mean he is asleep.
                  I am checking in here at least twice a day.
                  @ All:
                  As for coordinated: Yes, I do agree. That is what I would like to see. In that manner we will be able to work like a large laboratory with different segments - all sharing the ultimate aim.
                  I am silent at present because I have my investors here, till Friday on their annual visit and there are many important issues to be taken care off.
                  I got a small research grant:
                  One new development is that I will now get a very small grant dedicated for this Alternative Energy research. From my part, this has now become a serious issue and I will personally be dedicating a minimum of 300 hours a month to this research and studies. This are due to my different operation managers now being upgraded to where they need to take complete care of their operations; leaving me with more free time. Hmm…. ‘Free time for free energy’
                  Where I would like to see this going:
                  This forum has only one direction and purpose. To reach the point where we can access and use vaccum/radiant/aether/scalar energy. How we are going to achieve that is up to the participants of this thread. Forget about Overunity and the possible results like HHO. For now there are enough other threads with that on line.
                  Currently I foresee that we need to go through a sequence:
                  A: Understand what we are working with and how this is operating
                  B: Work on getting equipment to measure this phenomena – Inquorate has doing excellent groundbreaking there
                  C: Invent original equipment to enable us extracting this energy
                  D: Invent original equipment and methods to utilize this energy
                  Though it is only four points, I do think this will probably take ten people a full two years of hard long hours working, learning and sharing to reach the dreamed of end results.
                  With participants on this forum working together, I will be very happy. If not, I am anyway going ahead full steam on my own. It would just be nicer to have more brains, hands and abilities together – else the road is lonely.
                  Oh yes; one last remark for now: There is no value in duplicating other/old/ancient work except for the purpose to understand what we can learn from that. For instance; to build a Tesla tower and tune till you are blue in the face is not going to reach overunity, neither does Tesla wireless, or Grays tubes, or whatever we can do from existing knowledge. Now that sounds harsh but the reality is: If such copies of those devices were possible with all the current knowledge – then a number of people would have succeeded in reaching ‘overunity’.
                  Thus; we should learn what we can from those; but we should rather work on dissecting, joining, remodeling and adding in new ingredients. Use all the old knowledge, cut, grind, blend and weld it all into a new monster. Unless we can get new original ideas into this cake mix, it will NEVER work and time will be wasted.
                  I am not going to send money all over the world, but what I intend to do is get maybe one or two people innitially here in Thailand and when somone on this forum comes up with a good potential idea, we can produce the proto here and share the info back. That way all of you can safe on expenses for components - The hand work is never a problem; it is the brains that count and are lacking.....
                  Some people can scan the internet, some can contribute their electronic or electrical knowledge, some can design circuits, or do small trials, some can build and test full scale .....
                  Typing in keywords on Google just gives a phenomenal large abount of websites to scout. 'Radiant Energy' is 1+ Mil, 'Vacuum energy' 710K, Aether is nearly 2 million. THAT is a heck of a lot of research to do.
                  I will be fully active from this weekend again.
                  Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                  • #84
                    Originally posted by Electrotek View Post
                    @.... I've built an electrode assembly which produces Radiant Energy when a bisphasic spark is discharged...Any thoughts?
                    No thoughts form me now, but this very interesting. Question is: Can you separate the different energies?
                    Impressive bright spark by the looks of it!
                    • #85
                      Congratulation for the funding .
                      Aether anergy and alike seems to be known for a long time. But few can utilize it. It seems many succesfull demonstration of utilizing aether energy done in a form of battery charging. I hope this join effort can make us go beyond that.
                      I don't have anything good to offer except my idea, so I will try my best to learn anything related and then share anything I know.
                      @Electrotek, can you detect anything using something like Inquorate detector? or maybe just placing amp meter or volt meter near it.
                      • #86
                        @Inquorate: Thanks for your interest in my effect.
                        At this point the green discharge seems to be the primary operand. Both electrodes are copper and there is some carbon in the Tube. This results from the periodic spark making a little burn spot on the side of the wire. As more carbon builds up at this burn spot, the plasma discharge gets bigger.
                        The discharge is primarilly opaque when the energy density is high enough, but the green light towards the bottom of the Tube is somewhat irridescent.
                        The frequency of the effect is rather slow, about once every 4 or 5 seconds, so a video wouldn't help much. It's better to have a single picture showing the energy. I think I can see an etheric effect in the background which I've seen depicted diagrmatically on a number of occasions. I'm still wondering about the yellow hologram in the left corner.
                        @Aromaz: If I can see how an energy is shaped, I could probably make something which would collect it. But that would be in the area of shape resonance.
                        • #87
                          My ISP is barely functional at the lowest speeds, so it takes a couple of hours to download a video. So I haven't got to see Inquorate's detector. But this is an important area, and I'm trying to piece it together from his discussion. A bifilar coil might be more effective, but I haven't had time to try anything like that yet. Sparks are only my hobby; I still have to devote most of my attention to my Inertial Propulsion research.
                          But I did dig out my compass. The next time I fire the circuit, I'll see what registers.
                          • #88
                            Detector
                            @ Electrotek - I'm working on an improved version, and from now on will post pictures of circuits and designs, just for you sweetie :-)
                            All you had to do was ask ;-)
                            • #89
                              @Aromaz,
                              We have used your circuit without diodes and applied 24 VDC on the circuit below pdf, page 13..
                              http://www.panaceauniversity.org/Tesla's%20HV%20impulse%20lighting%20methods-Imhotep's%20Radiant%20Oscillator.pdf
                              We have blown 6 3055 transistors... Eventually we have found that we have shorted primary of our Russian coil...
                              So could you please measure the primary resistance of the your coil? And indicate the brand of the coil that can handle 24V?
                              We would like to use FIR lamp as load and we will get free samples from China.
                              Can you check this site. Energy Conversion by Articulated Transfer
                              POLYPHASE TRANSFORMERS May HELP!!
                              Nuri Temurlenk
                              Turkey
                              • #90
                                Originally posted by samedsoft View Post
                                @Aromaz,
                                Nuri Temurlenk
                                Turkey
                                Re blown transistors: See my posting #46 on Page 2 here. Hope you are using TO-3 pachages and not Tip. TiP's are good for short runs or 12v on longer runs, but for 24V better to go for TO-3's mounted on heat sink.
                                Since there is no current draw throught he coil, the wires should not have burned. I did run my cheapy Chinese with 36v already; though they do get warm, still ran for about 1 hour.
                                http://www.energeticforum.com/renewa...-video-55.html Posting #1643
                                OK, here is what I can give you:
                                I have four coils, 2x No-Name, 2x Hitachi.
                                Though slight different in resonace, they work nearly the same.
                                Two coils of same 'make' tested exactly the same. Mass production.
                                Used in latest video were all the No-Name brand.
                                When 2x coils, they are the same pair.
                                Set #1 = No-Name (on left)
                                + to - = 1.92 Ohm
                                + to HV = 10.42 k Ohm
                                HV to - = 10.42 k Ohm
                                Set #2 = Hitachi
                                + to - = 1.6 Ohm
                                + to HV = 8.56 k Ohm
                                HV to - = 8.56 k Ohm
