@ Broli Nice Link about teslas work, a lot to read through.
And a lot of things, what i did not see before. really intresting.
@Sucahyo Yup thanks, about the Page.
And the 'funny' thing is, you can see this Forms anywhere at the Nature.
It is like, it builds like the Energy is flowing.
Then i understand anyhow, when the Religion says, God is anywhere.
Even when i not really agree, that there is a God, what is watching from 'above'.
Sounds more like a good Reason for some, to try to same, and try to 'watch us from above'.
Now, just need to find the Point, where OU appears.
About the Transistor, what i ve seen, is, the Transistor only goes hot, when the Frequence at the Base is higher, and the switchrate is higher.
That cause the heat. But when you are in the specs from the Datasheet from it, and dont have to much Current at the Base for Trigger, and same for C and E,
it should not doenst matter, where it is connected, inside the Coil or outside.
But when it goes hot, you can use a Sheet for cooling it down.
Usual you can do a lot with Electronic parts, so far you keep them Cool.
Even work with them over her limit.
Heat is her Enemy, what mostly let them burn. And too much Current usual cause the heat.
