Electrogravitics
  • #16
    MIT News: Thrusters powered by ionic wind may be an efficient alternative to conventional atmospheric propulsion technologies.
    ... there have been few rigorous studies of ionic wind as a viable propulsion system. Some researchers have theorized that ionic thrusters, if used as jet propulsion, would be extremely inefficient, requiring massive amounts of electricity to produce enough thrust to propel a vehicle.
    Now researchers at MIT have run their own experiments and found that ionic thrusters may be a far more efficient source of propulsion than conventional jet engines. In their experiments, they found that ionic wind produces 110 newtons of thrust per kilowatt, compared with a jet engine’s 2 newtons per kilowatt. The team has published its results in the Proceedings of the Royal Society.
    These findings are not about to change aviation overnight but do have potential as Dr Steven Barrett explains in this podcast interview.
    • #17
      At the moment, the most practical way I see is the kynetic propulsion methods. I know there are also electrical but I think it can be difficult to apply due to extremely high voltage needed.
      So it will be important to understand how and why the kinetic propulsion works.
      • #18
        This is an option to create an easy kinetic propulsion device. The technique is based on a gauss rifle. When we close the circuit power is released to the coil and the metallic ball moves and impacts with the rounded end of the closed tube, creating a linear acceleration.
        An example of a very similar concept is this video created by Veljko Milkovic.
        As you can see, the impact of a piece into the main body accelerates the body:
        https://www.youtube.com/watch?v=GuTMYgQDUzs#t=0m45s
        This technology, if properly engineered, can created a propulsion effect that can be used to lift an object.
        • #19
          Seth, I was getting ready to build the beer can motor. how did you make the center positive?? did you add a brush?
          • #20
            My woerk in electrogravitics:
            gravitator - YouTube
            must first understand the nature .... and then imitate
            • #21
              change the geometry of your capacitor
              • #22
                n
                https://youtu.be/iCbIpfbtEsw
                • #23
                  Originally posted by antigraviticsystems1 View Post
                  Thanks for the pictures.
                  The evanescent wave can induce a particular wave attribute on certain materials.
                  Some speculate that those materials make up an amorphous material.
                  This is a verbal review of evanescent waves:
                  POSSIBLY difficult TRANSLATE SPAIN SPANISH Help ?
                  https://www.youtube.com/watch?v=MNvM1Rc01Pc
                  For those who follow and in addition is an example of elastic properties
                  of amorphous materials:
                  https://www.youtube.com/watch?v=EzFjZJEAt18
                  a 3D simulation of evanescent:
                  https://www.youtube.com/watch?v=j2DmEchCU_E
                  • #24
                    EUREKA......
                    https://youtu.be/SGY7milLEgo
                    • #25
                      EUREKA!!!... I HAVE DONE IT
                      https://youtu.be/9c0NWTxzUM8
                      • #26
                        hello, i would like to point out something to you on the issue:
                        [VIDEO]https://www.youtube.com/watch?v=5hEJOwwn4-Y[/VIDEO]
                        and to the video in the description below there are links, where I have put my concept
