He he, of course, there are awful lot of bad physicists. I think I am a good one, at least I hope so. My mind is open, there better be some interesting results in this experiment.
Do you happen to use some IM app like live messenger? I would like to add you so we could chat about these stuff more often in realtime. I don't have a single person on my list who shares the same interests.
Why exactly shouldn't someone replicate the experiment? Isn't that basically the point of an experiment. I know that if I could make one, I would/will. In fact, I want to make three!
Three, you say? Tesla was obsessed with the number three.
Most people make one Tesla coil for sparky light shows. Nothing wrong with having a bit of fun. I like the singing sparks especially.
Few people make twin Tesla coils, couple them, measure energy received/transmitted, and debate the results.
But Tesla coil triplets?
Is it really possible to couple one transmitter with two receivers?
If one loaded receiver is coupled, how will loading a second receiver change both the energy transmitted and the energy received by the first receiver, and will the total received/transmitted energy of the triplets be greater than that of the twins?
Has anyone here successfully coupled two or more Tesla coils or purchased any Meyl equipment?
The discussion and investigation of Scalar waves is certainly a worthwhile one. Konstantin Meyl, Scalar - Faraday vs. Maxwell et al. Why has this thread died on the vine?
But about this tread - personally, I haven't had that much time to devote for this issue, however it hasn't been completely forgotten. I hope I will manage to translate some work of mine towards the experiment, but can't give any promises, unfortunately. Studying physics does take enough time.
I wonder why the clock is set up this way? I would think that a ten or twenty hour clock would work better. Twenty hours in a day I think would work better, in todays world anyway. Good thing money is not set up this way.
So did Tesla find something new using three? Other than three phase power,
but Tesla invented the three phase power system we use today. So there must be something to it.
Come to think about it, Tesla also used 60 CPS in his alternating current systems. There are 60 seconds in a minute, sixty to an hour. There is that 6 thing again. Again, good thing money is not set up on 3 6 9 12 24.
One thing to keep in mind is, man wrote the laws regarding the conservation of energy, not nature.
Nature writes it's own laws regardless of what man thinks or does.
3 6 9 who can understand this simple code
and yes , the key is hidden in clock
why our clock has 24 poles ?
we are set here ,it is planned, it is construction, we are observed
we are fighting for our souls
Thanks Tehnoman for passing the word on the open source project, i jus wanted to add the post i made in my thread if that is alright
thought to create this thread dedicated to the Open Source Project for Tesla/Jackson Wireless Transmission since i could not find any mention of it in the forum.
could be an improvement to the set up...that is my litlle contribution...
found this research which actually proves that the shape i proposed does have special properties yeahhh
A helical antenna, consisting of a winding over a spherical surface, is proposed and investigated, both theoretically and experimentally. The winding is such that a constant spacing between turns is maintained. It is fed coaxially, with the inner conductor forming the helical winding and the outer conductor becoming the ground plane. Radiation characteristics of the proposed spherical helix are calculated, using the method of moments, and compared with the measured results. The results of this investigation indicate that radiation properties of the spherical helix are markedly different from those of the conventional cylindrical helix. Of particular interest is that, over a certain bandwidth, the proposed helix is capable of providing circular polarisation over a broad beamwidth. This property and its compact size make the spherical helix attractive to mobile radio communication systems with low channel capacity.
not sure where you got curious about 3 6 9. The most free energy thing I have encountered is this :
"The numbers 3 and 6 represent the Yin and Yang in the form of magnetism and the number 9 is the S curve."
In Rodin math, basically, 3*1 = 3 , 3*2=6, 6*2 = 12 which you have to add 1+2=3 so back to 3, 12*2 = 24 back to 6, 24*2 = 48 back to 3...so on so forth. 3 and 6 are dual.
9 on the other hand does not change. Any multiple of 9 results in 9 if you add the digits.
If the bird that we see quacks like a duck and swims like a duck, and so on all the way down the line, then it‘s a duck.
If it crows like a rooster and can‘t swim, then it‘s not a duck. It
doesn‘t make any difference how many people insist on calling it a duck, —it still isn‘t a duck.
The physicists‘ atom is an imaginary atom constructed of
imaginary particles.
Irwin Schroedinger tells us, “If the question is asked, do the electrons actually exist on these orbits
within the atom, the answer has to be a decisive no. “The atom of modern physics can only be symbolized by
a partial differential equation in an abstract multi- dimensional space.”
