Hi folks, I've been running some tests with my motor thats almost like Hugh Piggotts axial windmill generator and using it as a generator to test a method of charging battery cells and I am wondering, why are we not charging cells individually as in breaking up the 6 cells of a 12 volt lead acid or just using the already made 2 volt lead acid that are sold. What I am seeing is that as others on the net have pointed out is that instead of destroying 12volts by charging 6 2 volt cells in series which is just like counter emf and then after that 12v is exceeded current flows. instead we charge cells in parallel and the generator is free to provide a cascade of amperage at that lower voltage and a lower speed enabling a faster charge time for the same mechanical input to the generator. Not to mention we can now gear down a motor to spin the generator since we need a much lower speed due to lower voltage demands and thus operating the drive motor at its most efficient rpm. And charging cells in parallel we avoid heat losses, etc. let me know what you folks think
peace, love, light
peace, love, light
