Darkwizard, I know your test will light the bulb. However, sephiroth brings up a very good point. The duration of the reed switch closure could be going well past tdc. The ability to adjust/advance/retard the pulse duration of DW's light bulb test, combined with sephs LED test seems like a good way to see whats going on here.
R. Adam's secret: Radiant AUTOGENERATOR COIL
The test has been performed... I have uploaded another video...
YouTube - Sephiroth vs Darkwizard : : The Saga Continues
But I still encourage Darkwizard to perform the test himself."Theory guides. Experiment decides."
Nikola Tesla
Originally posted by Sephiroth View Postclose but not quite... AS (the keyword here is "as") you induce a magnetic field at the core current/voltage will be generated in one direction. Then AS you remove the magnetic field voltage/current will be induced in the opposite direction...
Loving this topic guys. Props to all."Once you've come to the conclusion that what what you know already is all you need to know, then you have a degree in disinterest." - John Dobson
Originally posted by ren View PostBut what if there is a diode in the circuit? Can we force it to only push one way? At the correct time with the correct polarity?
and if you put a single diode on it then the voltage will still be generated on either side of TDC but the current will only come with one of the peaks....
It is an interesting experiment though... because if you have the diode set up so that the current is generated on the peak before TDC then it will be possible for the current to continue after TDC and repel the magnet after it has passed (if the coil has a high enough inductance and there is no impedance). That is why a shorted out coil produces hardly any drag on the rotor. This wont happen if it is shorted out on TDC with a reed switch though... you need that first peak to generate current."Theory guides. Experiment decides."
Nikola Tesla
posts moved
The original post #'s 155-233 have been moved to here:
http://www.energeticforum.com/renewa...tor-coils.htmlSincerely,
RPX & MWO http://vril.io
Cheers Aaron
Right guys... let's leave this poor thread alone so it can get back on topic... please post any comments you have about my video or anything about this debate in the new thread
I will repost my video over there..."Theory guides. Experiment decides."
Nikola Tesla
Theyr Ideas are not bad, Cody just need to put the Diode across the Coil after the Switch and do one for the output.
I think, you are not done right now with a Circuit, so we can look at it ,
But its the same at your last one, they will improve the System.
But its anyhow hard to build with this much Coils, when you dont have them by the Hand.
But seems they play around with some other Things, so we have to wait, till someone will come back again.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Hi Joit ,
Seph and Muller has open my eyes, north pole is generating half cycle before tdc, one coil can be both generator or power coil, a north pole magnet is attracted to a steel core, the current generated repels the magnet , the net force is 0, it will continue rotating because you induce fem in the same coil when the magnet passes tdc, when the switch is off the back emf is generated at the coil, and it travels across a recovery diode, the same diode is utilized to use the energy generated by the magnet before tdc.
So now we can have good torque, energy and radiant recovery.
the trick is using unifilar coils, relatively low impedance per coil but high impedance in all the system, six coils twelve magnets.
All the mechanical energy can be used to move a generator with no lenz law of course.
Umm, yes. when i even only can figure the Half from all that now
But there is the Way, to recover the Energy back with the Diode, lead it back ( with another Diode) into the Circuit, and have no Drag for this.
One for Loop the Coil(s), one for lead back. So simple.
I think even,when you put few Transformers beside, you can get a lot back from it.
Right now, i still try to figure out, what the best way is, to get it back.
I have a lot Variations in Mind with 2-3 Diodes, and a switch, when it is needed.
But i am sure, it will give enough Piower that way, to power it up by itself.
And if not, then enough, to amplifier it pretty well.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Umm well mainly, loop the Coils with a Diode,
Today i did loop the Triggercoil with 2 Diodes parallel from Base to Emitter, and seems, it was better as only one Diode.
And then, another Diode from one End from the first Diode, and you can bring the Energy back into the Circuit.
And about Transformers, how you can find them in Power adaptor.
Just connect this Transformer to Minus from a Circuit, put a Diode in loop, place it beside a Rotor, and one Diode back to the Circuit.
Or one Diode from '+' Coil to Circuit, and backside from the Diode the loop back into the Coil.
I did it with a single Aircoil, what i got from one from this Transformers, placed a Reedwitch at +Coil, then one Diode after the Switch for loop back to Minus from Coil, and one Diode to Circuit, and it worked for me great .
Just had to find the Point at the Rotor with the Switch, where it increases Speed.
I still need to play around with it, i hope, i can show it soon complete.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Because its compact, and allready done.
Not much effort for a Result
I did not mean, to connect for transform, only, to use the Coils from it.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
YouTube - Bedini High Voltage Without Power Supply
That is the proof.
Just moving the magnets will produce High voltage, an obvious gain.Last edited by darkwizard; 03-20-2009, 02:10 PM.
