darkwizard,
I think your ideas would be accepted better if you could please provide some visual evidence so we can see that what you are saying is true in reality. Is there any way you make a video showing the rpm of your motor before and after the generator coil is hooked up. Using an actual tachometer so there is no dispute whether or not there is a drag on the motor. I would make the video myself but i dont have the circuit made yet.
Cody, i haven`t a tachometer, not a camera, simply, i haven`t the Patmac circuit. I have an adams pulsed magnetic switched reluctance motor one big coil,and a generator coil, my circuit is this:
I have sony t290 celular phone, i work on a lan games cyber and no money (argentina) for a cam.
In a couple days will pickup a photos. I have used a old hard disk for the rotor from the garbage
But when you state something then you should can show an Example, or can explain it.
Just say, 'It does' is nothing.
Even when its only the Electrons are, what are flowing.
Even, when they are around the Magnet too, and at the Wire, and they are noway the same, wich are flow at the one end in, and the other End out.
And you say, there is no current at the Wire, but Power ..
Actually, its not really importend, if there is current flow in a unattached coil.
there is no use for it.
Bedini Words: The inventors who have discovered this have used various variations, but here we show a common one.
First, we add an "energizer" (often referred to by various other names) to the circuit. This device makes the del-phi waves we will utilize, but does NOT make currents of electron masses. In other words, it makes pure Ø-dot. It takes a little work to do this, for the energizer circuit must pump a few charges now and then. So the energizer draws a little bit of power from the motor, but not very much.
But that has nothing to do with ONE Coils, a single one, what is not attached.
You do mix up things, and then tell People dont understand.
This is a Coil in a Circuit, and its complete something else.
Just shows one more Time, that you have not the right understanding and you mix up Things.
There,
Joit, there isn`t a current , nothing, understand, nothing.
Do you know what electrons are? The free electrons of the copper atom moves a little gaining energy with the magnet, but that is not current, only potential difference, true dipole.
you explain it with
The core coil gets magnetized, the potential energy remains stored in the core, but the current is not developed until the circuit loop is closed.
Once you say, there is no Current in a Coil when a Magnet turns around, then its Power, what is in, Now, the Energy is stored in the Coil.
And if it would from Dipole, as you says before, there must be Current in.
So now what, is there current or not.
Without Energy, you cant have a Dipole.
And even Copper is Diamagnetic.
And even that is not complete right, The Energy dont stays stored at the Coil.
When you put away the load from the Source, the Energy will left.
But there is Current at the Moment, when you move the Magnet.
There is nothing 'stored in a Coil.
Or you could load a Cap with a Coil or light a bulb or anything, when you did turn a Magnet before around the Coil and build up a Dipole ..
But there is nothing anymore in the Coil. And in that case you can clear say,
you cannot store Energy in a coil like in a Cap. Closed or Open.
And nowayday in a Dipole.
And even the Triggercoil does something else, what you try to suggest.
It doesnt looks like, you know the Circuit very well, more from reading it, and trying to understand.
Energy is not current, the only way to measure the energy is current, but the energy is the dipole.
You don`t understand the basic principles, how can i explain you?
Put several coils, is the same thing, there isn`t current, why you can`t see, are you blind? the coils are discharged together one time per revolution on the jim watson machine, what is the thing that you can`t understand, the potential flows as a entity pure zero flow , only radiant high voltage spike.
The time of the pulse is a very sharp pulse, current don`t build up.
There are several bedini words on this. This is almost ordinary particle physics.
Ok, i think there has been a lot of confusion as to what we are doing here to create this radiant spike from a generator coil. Patmac has confirmed to me that what i have been doing is where he started, so i am providing a video to clearly explain the basics of how this works. Patmac i know you posted all this with videos however i think a lot of people could not see what you were doing. I tried to go through the basic concepts very simply and slowly so everyone can understand how this is functioning. Once again, this way does put a load on the motor, but this is where pat started and developed his circuit from there, everyone interested should grasp these simple concepts first. Here is the video. YouTube - Radiant Energy From Generator Coil
I tested the time take charge my 1.5F capacitor with the generator coil:
Charged to 12.02 Volts
Time taken: 3m:43s
J=12.02x12.02x0.75x223
J=0.485
It's no so much energy extracted, but considerating my motor....
Magnets are 10mm x 3mm disk type, little magnets, if I would use big magenets like Muller. Or maybe ceramic magnets but biggers is better than little magnets stronger neos.
jetijs,
I just tried how you suggested
My results: that doesnt work, i no longer get any high voltage collapsing spikes, and there is barely any charging capable from it. I know its weird to think of directly shorting the legs of a generator coil together and getting any effect at all from it, but trust me, it does give you a HV spike just like a bedini motor. Why it does this, im not exactly sure.
Patmac,
Im still having a hard time understanding what you are saying. I think im just going to have to build your circuit and give it a try.
cody
I've tested that concept with my circuit AND It's works
I think am on the way, Bedini motors produces his energy in this form.
Transistor makes the spikes short the coil BUT WITH THE BATTERY IN SERIES with the coil. Extra energy come from the magnets. This means:
High efficient Bedini needs big magnets with big core, magnets ceramic avoid drag but big and this is good for the coil, coil need magnet field being as big as be possible.
To get good overunity with a SG system many coils are necessary, with big core and big magnets, using many coils around the rotor is possible make it turn with very little energy. This means Bedini big machine if draw 10 amps, the output must be enormous.
Patmac,
It didnt work at all for me, all the high voltage effects disapeared when i did that. Maybe i had something hooked up wrong, ill play around with it again tomorrow and see if i can get it to work in series.
