R. Adam's secret: Radiant AUTOGENERATOR COIL
  • Insted of having electronics shorting the coil on and off ,why dont you just
    place a magnetic sheild piece on the magnet????
    This way you gonna have double impulse by magnet..
    Insted of having a big roller coaster=curent,you gonna have 2 sinuidal wave=
    voltage..
    If i`m wrong correct me!
    Alain D
    Hope die last!!!
    • magnetic shield, it is possible? and not expensive?
      i don`t know
      • Originally posted by darkwizard View Post
        i don`t know
        if you have ever taken a harddrive to bits theres a magnetic shield in them.
          i don`t know
          Just put a strip of magnetic shield to have youre waveform divide in 2..
          If i was equiped with the right tools i would tried this..
          It seems pretty obvious when i start to read this tread that it has to be
          a way to cut the waveform to obtain the abrut scalar form...
          You light our minds my friend...
          Alain D
          Hope die last!!!
          • You are talking about aluminum? hard disk diamagnetic plate?
            • Here in Mendoza - Argentina is very difficult to obtain the materials needed to build a home generator.
              • How to Tell When Your Hard Drive is Going to Fail - Stepcase Lifehack
                top left hand corner banana shape.
                also
                Magnetic Field Shielding Materials
                • Originally posted by peper10 View Post
                  voltage..
                  Alain D
                  Hi Alain,
                  It would useful you could draw a hand sketch in Windows Paint how you think the shield is placed on the magnet. Can it be fixed to the magnet for good or you have to move it wrt the magnet? If you need to move it than how much mechanical energy is needed, compared to a MOSFET switch that needs very little input energy.
                  Here is a link to a similar page Bodkins kindly showed above.
                  Hard Disk Drive Magnets For Wind Turbines - Wind
                  It indicates the hard disk magnets polarities as glued to the so called "shield" i.e. a backing plate. This plate is thick enough with respect to the strength of the magnet and has a high permeability to close the flat Neo magnets' opposing poles on one side so that on the outer side of the plate there is no or very very little stray flux. You can find similar behavior with any soft iron or other ferromagnetic plate of correct thickness.
                  Alain, I would appreciate further explanation or even better a rough drawing how you think the setup with the cover plate.
                  thanks, Gyula
                  • Soft iron attracts magnet.
                    • This link is very useful, look up the waveforms.
                      The Silicon-Controlled Rectifier (SCR) : THYRISTORS
                        Yes, I agree.
                        (To put it more "precisely": permanent magnet or electromagnet attracts any ferromagnetic material.)
                        So why do you mention this?
                        • Why don`t use a controlled rectifier? Is really easy.
                          • as request
                            here is a sqetch of what i ad in mind..
                            The black strip is the strip that goes over the magnet and attach to the
                            I hope you ad a great day.
                            Alain D
                            Hope die last!!!
                            • I`m working in another circuit, actually, it will utilize the energy from the magnets , no lenz drag, radiant charging ....
                                wheel..[ATTACH]1955[/ATTACH]
                                Alain D
                                Hi Alain,
                                OK, now I may have got it how you meant. The black strip is supposed to make a 'figure of eight' flux distribution around the face of a magnet from a given pole, hence the induction can happen twice. Is this so how you also thought?
                                It needs some tinkering with the right materials and their correct shape to get the best results possible in a given setup.
                                Thanks, Gyula
