R. Adam's secret: Radiant AUTOGENERATOR COIL
  • #31
    elias
    it's for generate electricity, the motor is driving with adams style configuration transistor + reed, this generator coil no generate drag when is discharged when reach aprox 30 volts drag begin.
    You can charge capacitor with a very little drag using this system, to 16 volts.
    Steve Jobs. Apple CEO
    • #32
      Lenz Drag is originated when current builds a magnetic field that opposes the initial magnetic field that generated the initial current.
      IF the magnet is at the "top dead center" when the current is established, and the rotor is moving, then the current will generate a magnetic field that repels the magnet, but that is bad thing because it will create magnetic friction.
      That friction is the product of not having net direction of the rotational field.
      • #33
        The exact timing showed by adams.
        • #34
          I'm not too sure you are putting that much of a load on the rotor... To charge a 330uf cap to 100v in 30 seconds is the equivellant to .05 watts for 30 seconds... or to put it another way, 12 volts at 4 milliamps... that amount of output wouldn't put significant drag on the rotor.
          Nikola Tesla
          • #35
            Originally posted by darkwizard View Post
            Dear Joit: Current Builds the opposite magnetic field. If there isn`t current, there isn`t opposite magnetic field. There are two different drags, what we are talking is about Lenz Drag.
            The drag you mention is the material core drag. That are two different things.
            First. I am not your Dear Joit
            And second. I talk about Lenz Law too, sorry for you, when you miss that.
            I dont talk about Material Drag, not with one word. Can it be, you only read, what you wanna see?
            I mentioned about the same what Sephiroth shows too.
            The Energie what you get out from the Magnet, and the Field what is build up dont give enough Energie back for a strong enough repel of the Rotor.
            • #36
              @Darkwizard
              And one more thing at Lenz Law, that it helps you to understand it.
              Lenz law appears around the Lead, this case, the Wire, and each Diode, when it lets Current trough, the same Force go back through the Diode.
              At the same Moment.
              Thats why a special Coil would be better, as one, what is normally wound.
              Maybe you can get out more Energy from such a Coil.
              • #37
                Joit Maybe you have to read the physics book.
                If there isn`t current in the coil, how in the world a magnetic field will be generated in the coil.
                The original Lenz Law states: "The Induced current is such as to OPPOSE the CHANGE in applied field."
                • #38
                  If there isn`t closed loop there isn`t current ....
                  • #39
                    Another thing, the energy is such that no generates significant drag, not repels the magnet but is free.
                    Currently in my motor i have a generator coil putting 10 volts 50 ma , the spikes are higher than in patmac configuration.
                    • #40
                      my bedini motor consumption is 12 volts 30 ma, imagine what !
                      • #41
                        I dont think i have to read a Physik Book.
                        Its mostly only Full of Crap to get confused.
                        AND NO NEED TO WRITE CAPS OR BOLT, I CAN READ NORMAL LETTERS
                        When a Coil is beside a turning Magnet, the Coil dont need to be attached to anywhere, but there will be Current in.
                        You can proof that with another Coil inductive.
                        And i think, the Drag what Energy makes is much more as you think.
                        You can build a Magnetfield only with Wire.
                        The Wires dont make the Field, its the Energy what build up the Field.
                        Maybe the Force is additional from the normal Energyflow and additional the backflow, what makes it so strong.
                        And about your Coil, Bedini says, the ammount of the Turns give you the higher Backspikes.
                        Not sure, if you both have the exact same Coils, that you get different Spikes.
                        And it even did depends for me at both Coils, how much turns they had.
                        But anyway, the circuit from Patmac looks different from a Bedinicircuit.
                        And only got for Free enough Energy, mm i dunno.
                        I play now since a while around with my Coils.
                        I tried big Magnets, bigger Magnets, even have a Core with a Magnet build, that the Rotor has a slight Push.
                        When i look at a Bicycle Dynamo, it has not much Wire in, and can produce 6V/0.5A with 90Feet(30m) 0,3 Wire.
                        But i hardly get 8 V from same lenght of 0,4mm Wire.
                        And if i take a load at this Coil, the Current goes back to 3 V.
                        When i connect this Coils as Source, it looks more like, it slows it down more.
                        And thats why Cody is right, when he says, you need a Strong Source.
                        That Field what is build will allways have a loss against the Energy, what is used.
                        You would need a Trick, to gain more Energy.
                        i am sure, the way is an other, its more Balanced.
                        • #42
                          HA HA HA HA HA HA HA
                          THERE ISN`T CURRENT IN A OPEN PATH, OPEN LOOP. SORRY
                          • #43
                            Currently it isn`t anti-Lenz but it is controlled Lenz Law .
                            • #44
                              The field builds just when the free electron is out from the copper atom, not in another time, and that is the current, a conservative loop flow of electrons in a circuit.
                              • #45
                                BEDINI'S FREE ENERGY GENERATOR
                                What Jim Watson did? What Rick did? What Doug did?
                                What John did? What Robert did? What Tesla did?
                                http://www.icehouse.net/john34/Window.wmv
                                http://www.icehouse.net/john34/bedinicolemotor.mpg
