Originally posted by morpher44
Here's another ignition coil circuit. It gives you an idea of the internal coil wiring. If in doubt, check the windings and windings to case ground with your ohmmeter.
Read the text carefully - it's very informative.
Ignition Coil High Voltage Circuit
And here's how to drive a flyback coil from an old TV or monitor.
Sam Goldwasser's Flyback Transformer Circuit
There is nothing that says that you must use two transistors. You can "halve" the circuit and turn it into a conventional Joule thief circuit. But two transistors gives you more POWER!
In order to view these ASCII schematics you must use Courier or other monospaced font.
