What you must have is the end of one wire connect to the beginning of the other.
It is a center tapped primary, and it is often the case that it is off center.
But for your first one, just do it and see.
Hi Jeanna
I'm not sure what you mean by the quote above. I have the start of my 3T and the end on 13T primaries going to positive the end of the 3T going to base w/resistor and start of my 13T going to collector. I assume thats correct because its working.
My circuit ran all night a total of 14.5 hours on the C cell. The light faded quite a bit but battery voltage was still running at just over .5 volts. I unhooked it and the battery is starting to come back some. My draw was around .180 so about .25 watts. I had an extra C cell so now I have a fwbr and cap hooked up and trying to recharge run down C cell.
Jeanna I think I have those same bulbs I bought them at Sams. Came 3 in a pack. The Sams near me carries 4 different types of bulbs. 2 of them I dont like, the flood light (green color) and a 3.5 watt bulb thats too whitish blue. The other 2 (1.5 watt) bulbs have a warmer yellowish color. The ones on my circuit are the small end bulbs. I have them in my chandalier and one of my ceiling fans. The ceiling fan light fixture has 4 bulbs in it and give decent light in my 11x14 room. (lights of america 19 leds) The other bulb I like also has 19 leds and good color just has a standard size end. I use 4 of those in a 1/2 bathroom and they give off decent light.
I did light up a gutted 14 watt cfl but the light wasn't very bright. I'll try a 10 watt when I can find one.
I also lit up one of the 1.5 watt leds on 2 hearing aid batteries! (very dim though)
Thanks for sharing Jeanna and Lidmotor
Hi Jeanna
