Incandescent Lamps
The video is easy to view, not all jumping around like so many others. Really helps with seeing what the coil looks like.
I'm seeing a lot of posts where the light is an incandescent lamp, not a LED. First time I've seen this used on a JT. A Tungsten filament has a positive temperature coefficient (tempco) so it acts different than a regular resistor. If you put a voltmeter and ammeter on a lamp, the current will not go up linearly with the voltage like it does with a regular resistor..
A LED is nonlinear too, but in the opposite direction. It won't conduct until the voltage gets up to a certain point, 2.5 or more volts for a blue or white LED. Then it starts to conduct heavily. The incandescent lamp is the opposite. At low voltages it will conduct very heavily (low resistance) and as the voltage rises and the filament heats up, the current then rises only slightly, like the resistance is increasing. It is!
This is probably why you never see the lamp used on a JT. IF you want to run a lamp from a low voltage supply, you just use a low voltage lamp. But one resulr\t of the different V-I characteristics of incandescent lamps is that the brightness of the lamp can fool the eye into thinking that the effect is due to the JT making it bright. If you use a 2 AAA cell lamp on a JT with the transistor disconnected, it may look bright just from the 1.5V battery, without the JT adding anything. You think the JT is running but it's not.
The JT likes to have a load that is like a LED, where the load doesn't conduct at low voltages. That allows a lot of feedback and strong oscillation. The opposite is happening with the lamp: the lamp loads the JT at low voltages, and tends to damp oscillation.
If you connect the lamp to a winding that is separate from the primary or feedback winding, then the load doesn't occur until the magnetic field is changing, which to me means that the damping effect is not as great, if at all. But then the circuit is not really a JT, it's a DC to AC converter.
I'm aware that people may be bored and turned off with this theory stuff, but if you are aware of what is going on in the circuit, it will help you immensely when you experiment and allow you to get the most out of your project.
Back to experimenting...
