* Basics
o Ohm's Law
o Resistors
o Capacitor
o Inductor
o RLC Circuit
o Voltage Divider
o Series/Parallel
+ Inductors in Series
+ Inductors in Parallel
+ Capacitors in Series
+ Capacitors in Parallel
o Thevenin's Theorem
o Norton's Theorem
* A/C Circuits
o A/C Response of Capacitor
o A/C Response of Inductor
o Caps of Various Capacitances
o Caps w/ Various Frequencies
o Inductors of Various Inductances
o Inductors w/ Various Frequencies
o Impedances of Same Magnitude
o Series Resonance
o Parallel Resonance
* Passive Filters
o High-Pass Filter (RC)
o Low-Pass Filter (RC)
o High-Pass Filter (RL)
o Low-Pass Filter (RL)
o Band-Pass Filter
o Notch Filter
o Twin-T Filter
o Crossover
* Other Passive Circuits
o 3-Way Light Switches
o 3- and 4-Way Light Switches
o Differentiator
o Wheatstone Bridge
o Critically Damped RLC
o Current Source
o Transformers
+ Transformer
+ Step-Up Transformer
+ Step-Down Transformer
+ Long Distance Power Transmission
+ Transformer w/ DC
o Inductive Kickback
o Blocking Inductive Kickback
o Power Factor
o Power Factor Correction
o LC Ladder
o Phase-Sequence Network
* Diodes
o Diode
o Diode I/V Curve
o Half-Wave Rectifier
o Full-Wave Rectifier
o Full-Wave Rectifier w/ Filter
o Diode Limiter
o Zener Diodes
+ Zener I/V Curve
+ Zener Voltage Reference
+ Zener Voltage Reference w/ Follower
o DC Restoration
o Spike Generator
o Voltage Multipliers
+ Voltage Doubler
+ Voltage Tripler
+ Voltage Quadrupler
o AM Detector
o Waveform Clipper
o Triangle-to-Sine Converter
* Op-Amps
o Op-Amp
o Op-Amp Feedback
o Amplifiers
+ Inverting Amplifier
+ Noninverting Amplifier
+ Follower
+ Differential Amplifier
+ Summing Amplifier
+ Log Amplifier
+ Class-D Amplifier
o Half-Wave Rectifier (inverting)
o Peak Detector
o Integrator
o Differentiator (inverting)
o Schmitt Trigger
o Oscillators
+ Relaxation Oscillator
+ Triangle Wave Generator
+ Sawtooth Wave Generator
+ Sine Wave Generator
+ Voltage-Controlled Oscillator
+ Phase-Shift Oscillator
o Negative Impedance Converter
o Gyrator
o Capacitance Multiplier
o Howland Current Source
o Current-to-Voltage Converter
* MOSFETs
o n-MOSFET
o p-MOSFET
o Switch
o Source Follower
o Current Source
o Current Ramp
o Current Mirror
o Common-Source Amplifier
o CMOS Inverter
o CMOS Inverter (w/capacitance)
o CMOS Inverter (slow transition)
o CMOS Transmission Gate
o CMOS Multiplexer
o Sample-and-Hold
o Delayed Buffer
o Leading-Edge Detector
o Switchable Filter
o Voltage Inverter
o Inverter Amplifier
o Inverter Oscillator
o Logic
+ CMOS NAND
+ CMOS NOR
+ CMOS XOR
+ CMOS Flip-Flop
+ CMOS Master-Slave Flip-Flop
+ Ternary Logic Inverter
* Transistors (Bipolar)
o NPN Transistor (Bipolar)
o PNP Transistor (Bipolar)
o Switch
o Emitter Follower
o Common-Emitter Amplifier
o Unity-Gain Phase Splitter
o Schmitt Trigger
o Current Source
o Current Source Ramp
o Current Mirror
o Differential Amplifiers
+ Differential Amplifier: Common-Mode Input
+ Differential Amplifier: Common-Mode w/Current Source
o Push-Pull Follower
+ Simple Push-Pull Follower, with Distortion
+ Improved Push-Pull Follower
o Multivibrators
+ Bistable Multivibrator (Flip-Flop)
+ Astable Multivibrator (Oscillator)
+ Monostable Multivibator (One-Shot)
o Oscillators
+ Colpitts Oscillator
+ Hartley Oscillator
+ Emitter-Coupled LC Oscillator
o Logic
+ RTL Inverter
+ RTL NAND
+ DTL NAND
+ TTL NAND
+ TTL NOR
+ ECL NOR/OR
* Combinational Logic
o Exclusive OR
o Half Adder
o Full Adder
o 1-of-4 Decoder
o 2-to-1 Mux
o Majority Logic
o 2-Bit Comparator
o 7-Segment LED Decoder
* Sequential Logic
o Flip-Flops
+ SR Flip-Flop
+ Clocked SR Flip-Flop
+ Master-Slave Flip-Flop
+ Edge-Triggered D Flip-Flop
+ JK Flip-Flop
o Counters
+ 4-Bit Ripple Counter
+ 8-Bit Ripple Counter
+ Synchronous Counter
+ Decimal Counter
+ Gray Code Counter
+ Johnson Counter / Decade Counter
o Divide-by-2
o Divide-by-3
o Traffic Light
o Dynamic RAM
* 555 Timer Chip
o 555 Square Wave Generator
o 555 Internals
o 555 Sawtooth Oscillator
o 555 Low-duty-cycle Oscillator
o 555 Monostable Multivibrator
o 555 Pulse Sequencer
o 555 Pulse Width Modulator
o 555 Schmitt Trigger (inverting)
o 555 Missing Pulse Detector
* Transmission Lines
o Simple Transmission Lines
o Standing Wave on a Transmission Line
o Termination of a Transmission Line
o Mismatched transmission lines (Pulse)
o Mismatched transmission lines (Standing Wave)
o Impedance Matching (L-Section)
o Impedance Matching (Shunt Stub)
o Stub Frequency Response
o Low-Pass Filter
o Light Switch
* Memristors
o Memristor
o Memristor Response to Sine Wave
o Memristor Response to Square Wave
o Memristor Response to Triangle Wave
o Memristor Hard-Switching 1
o Memristor Hard-Switching 2
* Tunnel Diodes
o Tunnel Diode I/V Curve
o Tunnel Diode Relaxation Oscillator
I also would like to inform you on a simple yet very useful Spice based circuit simulator, also completely free and fully working, you can download and install on you computer, it is not obligatory to sign up for download.
Hey everybody, since this looks like a place to share great circuit simulators I want you to know about Qucs. I've just began to use it and it is incredible powerful. It works on both Windows and Linux, and Mac as well if I'm not mistaken.
I've been playing with this simulator a lot lately and find it very educational and entertaining. I've found that it doesn't simulate everything I'd like, but it does a fairly good job on the Joule Thief. Try it out for yourself. Be sure to play with the Potentiometer slider to see how it affects the circuit.
$ 1 5.0E-6 20.712724888983452 50 5.0 43
r 432 208 432 272 0 220.0
w 336 224 336 256 0
v 224 288 224 160 0 0 40.0 5.0 0.0 0.0 0.5
T 336 192 368 208 0 0.1 1.0 0.06351305143782035 5.002248615326721E-14 0.999
w 336 160 384 160 0
t 432 272 336 272 0 1 -11.641325227766169 -0.9043331912973003 100.0
w 336 288 224 288 0
v 288 160 288 256 0 0 40.0 5.0 0.0 0.0 0.5
w 288 160 336 160 0
d 336 256 288 256 1 0.805904783
w 224 160 288 160 0
w 336 160 336 192 0
w 384 160 384 224 0
w 384 224 368 224 0
w 368 192 416 192 0
174 416 192 448 208 0 10000.0 0.5099 Resistance
o 5 64 6 35 20.0 9.765625E-5 0 -1
o 2 64 0 35 5.0 0.2 1 -1
o 7 64 0 35 5.0 0.2 2 -1
