Hi.
Currently I am conditioning some dead 200Ah bateries with my Bedini self oscillator. They are getting better and better, but eventualy they reach their best capacity and that is about half or less of the original battery capacity. This is so because the battery plates are in bad condition as the batteries were abused very much. A new 200Ah battery costs about 350-400$, I got these dead ones for nothing. But it takes a long time to get some usable capacity back from them and in the end you get a big (in size) battery bank that has only a fraction of the rated capacity. That is not very practical. So I guess that it could be much cheaper to build some lead acid batteries from scrach. The target size would be some 3000-4000Ah, because I calculated that this is what I would need to power my household needs in a event of blackout. Also I am working on a big wind turbine and a need for such a big storage battery becomes greater and greater. So what do I need to build a good lead acid battery? I can get lead sheets. I can get acid electrolyte mixture. I can build custom casing. But I need some advice.
1. What would the best plate thickness be? How thick are the plates in deep cell marine batteries?
2. How can I calculate the amp hour rating depending on the plate surface area?
3. What would be the best to use as a spacer between plates?
I intend to charge this battery only with Bedini type radiant chargers for the first time on.
Any input would be apreciated
Thank you,
Jetijs
Thank you,
Jetijs
