Cheap vs Expensive Simulators
Michael,
IF there is a problem with the simulations by Woopy and Inquorate, it has to do with the "sample rate" of the simulation. There is actually NOTHING happening in these designs that a "full physics" simulator can't model. Boeing and Airbus design and fly whole airplanes in their simulators these days, and when they build them, they WORK PERFECTLY!!!
The trick is to make sure the simulator MODEL is perfectly defined.
The biggest problem with "Working Model 2D" is the 2D part. Every force that falls outside of the flat plane is simply "zeroed" when in reality, may not be zero. Also, short, transient spikes of force may be missed by the sampler timing. Anybody who has studied the SSG project is familiar with these issues.
Michael, I completely disagree with your idea of the best placement for the weights on the wheel. Your placement assumes that GRAVITY is the driving force, which it would be IF you could put the weights where you say they should be. The problem is, GRAVITY will not put the weights where you need them to be for GRAVITY to drive the wheel!
Its a "catch 22".
I discuss my analysis of this problem, in depth, at the beginning of this thread in my article The Mechanical Engine. If you haven't read the article yet, you may wish to review it.
The idea that the weight must move on a "transient excursion" is based on my experience of building more than 40 "working models" of gravity based designs that worked very well, but did not rotate continuously. Careful observation teaches that "gravity alone" is not enough to drive the wheel, and that "another force" must be present, at least periodically, for the system to run. The slightest "off-set", such as an early return of a weight to a more advantageous position, is all it takes to make the system work.
Since both gravity and inertia are considered to be "uniform forces", the best candidate for producing a "non-uniform force" is the centrifugal force from a swinging pendulum. [Ted, yes I know that inertia is not a uniform force under all circumstances, but for this discussion, please indulge me
Inquorate's ideas have made me look at this situation again with "fresh eyes" and there may yet be a simple solution that leans on gravity more as the driving force and uses centrifugal force to create the "weight shifting bias".
Keep up the great work, guys!
Peter
Peter
