Like everybody else here we all need to build our ideas, even if they don't work and then show them not working. Then suggestions could be made I guess. You might could gradually knead in a few more explicit terms, give us some awe to chew on.
The Mechanical Engine
Originally posted by Inquorate View PostStill waiting for payday to get a big piece of plywood and a couple of bolts etc.. Bit crestfallen about ppls findings from attempts so far but also encouraged by simple experiments with a Crossbeam and two pendulums, one swinging..
Possible solution to gate problem
This is a possible solution to the gate problem. The hinge has a limite of 5 degrees backwards and is placed between the cam wheel and the weight wheel. Just past the 12 position the weight wheel is still 5 degrees back but the cam wheel is already on the external cam and moving downwards, when the weight wheel is here the hinge will close to the straight position giving a double weight downward force from the click back to straight. This is momentarily but the swing to dead stop action in the gravity field gives quite a punch.
Michael NLast edited by Michael John Nunnerley; 04-09-2010, 05:40 PM.
Originally posted by Michael John Nunnerley View PostThis is a possible solution to the gate problem. The hinge has a limite of 5 degrees backwards and is placed between the cam wheel and the weight wheel. Just past the 12 position the weight wheel is still 5 degrees back but the cam wheel is already on the external cam and moving downwards, when the weight wheel is here the hinge will close to the straight position giving a double weight downward force from the click back to straight. This is momentarily but the swing to dead stop action in the gravity field gives quite a punch.
Michael N
Nevertheless, how does your weight get shifted back out towards the perimeter once it goes past 9 o'clock? I see it out at 12 o'clock, but no mechanism to get it there.
Ted
I like the solution Michael Nunnerley proposes in Post #203 => http://www.energeticforum.com/50482-post203.html
I don't quite see where the hinge is located so I can't very well comment on it being 5 degrees... but if it's BACKWARDS it has a ring of truth, because we all have pretty much acknowledged the need to think in multiple directions -standing as we are in the deep interior of a sand-locked pyramid- is the only way to solve this.
I'm glad to escape the box.
@Ted: I think them being on the same bar sliding to the right is pulling the 9 o'clock weight over with it. Or maybe I misunderstood your question. I was of the opinion that the small wheel riding onto the top of the cam was pulling the weight back up for the outward ride toward 3 o'clock... which I suppose would represent a negative factor but considering the hard slam happening at 3 o'clock doesn't cripple the action. I take it that's where the hinge action occurs also. Hammer time.
Great deductions Michael Nunnerley. Lock and Load I allays say.
Hmm. Correction => I could see where more than 5 degrees might bring the weight down to 4 or 4:30 but it's needed at 3 o'clock to help lift the opposite weight looks like. That will have to be decided upon building and trying a few different hinges.
Once an outer rim is added, the weight of the balls could be increased, so then the size generator being run by it could likewise be increased. The rim would be supported by the main hub not the balls or even touching the balls. Rim Weight increase = corresponding Ball Weight Iincease = Circular Momentum Horsepower increase <> I'm sure everybody else here can write it in a better format.
I was born for shovels.Last edited by CloudSeeder; 04-01-2009, 02:49 PM.
Originally posted by Ted Ewert View PostI take it back, this might work. You're right, the axis does shift out around 3 o'clock.
Ted
Michael N
Top view of which I am still working on.
A bit more to the secound diagram, this explains a little more
Serious doubts
Michael, et al,
I have serious doubts about your current design. The reason is I have built units based on these ideas before and they didn't work. Further analysis showed that to lift the weight up the cam requires the wheel to invest WORK (MOMENTUM) previously stored in the wheel. When this work is removed from the wheel, the wheel slows down.
Your design asks the wheel to LIFT the weights against gravity. There is an intuitive tendency to believe that the cams will "relieve" some of this load, but when you build it, you find that it does not. Think of it as pushing a weighted wagon up an inclined plane. Even if you have well oiled bearings and wheels, it is still harder to push up hill than on a flat surface. That is the extra work I am talking about.
This situation is EXACTLY what forced me to consider the design I have proposed. In my Mechanical Engine, the weights only FALL in the gravity field, while stored momentum in the wheel is never asked to LIFT a weight by direct action. This is also why the "spring return" is required, so the gravity powered swing of the weight outward can be "reversed" without removing any momentum from the wheel. This is also why I believe that the discovery of the "piano hammer movement" was the original key to Bessler's success.
Keep up the great work, you guys.
PeterLast edited by Peter Lindemann; 04-01-2009, 03:42 PM.
How are you set for money for prototype parts? I can PayPal ya a few after my disability check comes in in a few days if you need assistance.
One thing I see is that the hinges are going to receive repeated sharp -and destructive over a few dozen/hundred revolutions- impacts. 5 degrees is probably going to be close to perfect, but the hinge impacts needs some sort of buffering, air bag, spring, something to keep the hinges from disintegrating.
I know what you need but I don't know what it's called. It's a type of spring. I'm sure if you Google springs you'll see it. It has two ends sticking out that would each go to the opposite hinge. I think that would work.
Looks like to me you're In Like Flint.
Cams
Hi guys, whenever I made cam / ramp devices in my virtual wheels, they went backwards. I'm inclined to agree with dr lindemann, but quite happy to be wrong.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
