Originally posted by Michael John Nunnerley
I'm trying to get my weights as far out along the circumference as possible. This gives me the greatest potential between top and bottom to develop some power.
The wheel has the same balance whether the weights are close to the center axis or further away, so why not move them out. For a pendulum you have to have some distance between the catch and the fulcrum, but not for a cam type wheel.
The more I think about it, the more I'm convinced that in order to get work from a force, such as gravity, we have to let the force accelerate a mass, and then harvest that power through deceleration. Even the pendulum works on this principal.
If a wheel is rotated in a horizontal position (vertical axis), and one of the weights is suddenly extended out and away from the axis, the wheel will slow down according to the conservation of energy. If that weight is pulled back in, the wheel will speed up.
When the wheel is in a vertical position, and that same weight is extended (at the proper position) via a ramp, gravity accelerates the mass, which effectively increases the torque on the wheel and mitigates the normal slowing effect. When the weight is pulled back in towards the axis, the wheel naturally speeds up and excess energy would be available. If energy can be merely conserved on the first cam ramp, the second ramp is all gravy.
Anyway, I'm just thinking out loud.
Cheers,
Ted
