Well, it's not a fluke, I've created 4 running devices ..
but that depends upon your definition of running?
I think the software I'm using is broken.
It generally stops processing if I try to monitor things.
All of my devices are unbalanced but not by design.
They are Chaos devices by design.
I'm using rubber and steel to get some extra kick out of the movements.
Steel on steel is too much kick.
I didn't know what I was doing when I started, so all these except the last one are very large devices..
1st device, WildOne, has 8 - 2 meter length pendulums on 5.5 meter across arms, takes 192 frames before it takes off into hyper space. The software is screwed up?
This device runs not in one direction but both., back and forth.
The 2nd devise, Wiggler, is a 8 double-pendulums on 5.5 meter across arms. Both parts of the double-pendulum is just over a meter each. This one just wiggles back and forth mostly and at 900 seconds it's still wiggling like at the start.
The 3rd device, PacMan, has 8 double-pendulums on 5.5 meter across arms.
First section of pendulum is one meter and second is 0.39 meter circle.
This one works like the Wiggler but blasts off into space.
The 4th one is a copy of Inquorate's mounted on a two foot rotor.
Hey, a small device
I couldn't get the device to rotate with a slow down bar installed.
Very slow rotation.
This is the only device that rotates only in one direction, once it gets going.
Since it is so hard to create these devices with this software I used
no collision on the pendulums so I could get the number of pendulums
on the devices without having to rebuild the deive.
The WildOne and PacMan in the virtual world hang together, but in the real world they would fall apart from the forces. that must be why the software keeps stopping.
Would been nice to try these designs on some other software and see what comes of that.
Data files for these devices are in a zip file at this link:
RapidShare: Easy Filehosting
Working Model 2D required, if you don't have to software don't download the file.
There are will only be 10 downloads of this zip file allowed by rapidshare.
Randy
Hey, a small device
Very slow rotation.
Randy
