It’s leading the current by 90 deg. The current is lagging 90 deg behind in a coil, and the speed of the voltage is fairly infinite. So the voltage spike has already done everything before current even gets to the coil. This wave form was a snapshot from my digital scope which I could see exactly what was going on in my motor (a sort of hybrid), in any case after two weeks of thinking about it I finally came to this conclusion.
Update: K, after thinking about it, it's on the negitive side of the wave form, but does not disclude the positve radient, Maybe there are two types...
Anyway, after polarity switch, which is what everyone seems to be saying..
One is a water fuel cell that I haven't released any details on and another coming together soon is an SG with a modification that hasn't been released either. Must have results to post before saying anything.
i was doing some experiments with voltage step up and so on and i can across an odd effect i was pulsing a step up transformer with 6 dc and then i had a neon hooked to the suppose'ed negative with both pins i might add the suppose'ed positive was not connected and if i touched the neon glass the gas would light up and even follow my finger what the heck is going on with that was it some kinda radiant energy effect?
my two cents worth...
I think your finger is acting as a ground plane, plus it's also injecting 60hz into the tube, which just match's the ignition point of the gas. best guess.
The pulsing of 2.3khz is for the coil I presume, this is not what i'm talking about. 60hz exists everywhere, our body's pick it up all the time, it's the frequency of north American power lines (wall socket), however our body's act as an antenna to it and other frequency's, if you stick your finger on a scope probe it shows up right away.
Have you ever played with a plasma bulb? They work from the inside and look for a conduction ground plane outside. you can put your hand on the glass and the high voltage goes right to your finger... very cool!
i never have played with a plasma globe there neat ive seen on youtube ppl burn through paper with a pin and penny and light lightbulbs
now i add a voltage multiplier lights the neon better but i cant get it to run on one wire i wish i had some mini stainless tube to make a mini meyers cell
For stainless steal I like to hunt around -Car salvage yards, metal salvage yards, metal salvage stores. recycle yards. If your just experimenting and don’t care about shape, try metal things around the house like utensils, broken or fractured tools that you don’t care about, some of these contain stainless steel. On a budget? I like going to the “one buck” and “reusable” type stores.. here you can find bargains galore. The reusable type stores are the best for finding odds and ends, tools and electronics for a few bucks, most of which contain valuable parts inside which aren’t even made any more, like old radios and the like. As for stainless steel, you can substitute temporarily with another metal, just to see if things work they way they should. Later you can then use the real thing.
Hello,
I am answering to Aarons explanation of radiant energy. well, more questions come up here....
IF we succeed in tapping this as a new energy source- for the moment there is only a bunch of toy sized models of these machines around-what will happen to the environment?
the first reaction of one of my friends when I showed him the Bedini machine was: "What will happen when we make one that is the size of a house?"
When this is scaled up, running everywhere on the planet- will this drain our life force or do damage to other beings in other places we don't know of?
AND: I always wonder if we will not draw some unwanted attention to this little obscure planet of ours. ...
this is more philosophical than technical, but it might throw a light on some things-for instance the fact that the Methernitha group in Switzerland got scared of the possible effect they might unleash when getting their scaled up testatika to run...this is -I have heard at least- the reason why they stopped working on it.
Another possibility with radiant energy is the uncontrolled runaway situation that might cause an enormous sudden surge of power into the device. Causing immediate destruction of the machine and possibly even a lighting strike. It happened to Bob Boyce with his electrolyser.
I am trying to get a picture of what we will gain when we use this new technology.
I wishe everyone on the forum a happy holiday season!
Hello,
Albert
Hi Albert,
Well, I don't think so, I believe that this energy (Radiant Energy) is dynamic and is pouring unto us like a waterfall, and never ends. This is certainly the energy all of us use daily, all of the plants and animals use. If it were so this energy would have been exhausted a long time ago, but this energy pours onto us endlessly and is a blessing from our creator. Gravity never ends?! because it is based upon this energy. You can take a look at http://www.energeticforum.com/renewa...uperlight.html for more info.
I agree to elias. I have heard of many cases when people who are near these devices (joecells, Searl effect generators, moe-joe cells) experience good feelings and vitality even healing effects. For example, John Searl was able to heal his face burns in very short time just by sitting near his generator when it was operating. Doctors could not explain that. Although if not properly tuned, the cells could also radiate out DOR or negative side of the orgon/aether.
To be honest I don't know whether harnessing this energy will affect us spiritually. Most of us agree that the energy is very much like (or even identical to) chi, the life force.
We also agree that it is (as far as we can tell) limitless.
However, subtle things appear to affect our relationship with the life force. It depends on what you believe here but for example if you believe in Feng Sui then something as simple as having a fountian in one corner of your room can greatly improve this relationship.
And if you believe in astrology, then even subtle gravitational forces from distant planets and stars appear to affect this relationship as well.
so it isn't unlikely that these devices, that strongly interact with this energy, may affect us as well. These effect could be benificial or detrimental.
As tesla noted certain frequencies could cause a stinging sensation even at a distance and other frequencies gave the feeling of euphoria.
I don't believe that they will suck the life force out of us, though i do wonder what influence they may have. Definatly worth researching though first we need to better our understanding of these forces before we can draw any conclusions.
Nikola Tesla
i think these devices must be safe as tom b. said the energy comes from virtual protons and they force out this energy in an unusable form we are just transforming it to usable energy turning the battery in to a receiver for what is floating around all the time for any receiver to use ie the human body the earth everything
