Aether
  • Aether
    I have been reading some matarial on aether and its behaviours and also been looking at how it is used in current free energy devices.
    I have a question on one of the properties of aether which is that low density areas lflow to high density. If this is the case then would this mean that if anything ever obtains a lower density than the surrounding environment then wouldnt this mean that it would never be refilled with aether until it moves to an area of lower denisty than itself. Is this correct.
    Attraction
    As well lets say you have two items and one of them is atracted to the other how do you test which of the two is attracted to the other. I must be missing something because this sounds like a dumb ass question, so if it is forgive me please, its late.
      My theory is : Aether is nothing more but Earth magnetic field.
      For example inside permanent magnets there is stationary current of electrons in quantum wave state. That is possible only because Earth magnetic field is removed from inside of permanent magnets by a process of preparing it, and the properties of material allow for many such electron rings rotating by Corioliss force. So permanent magnet is a source of magnetic field because Earth magnetic field is continously trying to "get inside" and is condensed around magnet.
      Sound crazy I know but don't forget about it .... The same process Steven Mark used in TPU and many others in free energy devices.
      That also mean that there are many ways to turn off the magnet : for example by changing its structure or by allowing Earth magnetic field to flow across internal of magnet for a moment (that convert electron rings into normal current dissipated as heat inside magnet and turn off completly field of magnet). I'm glad I finnaly got that theory quite complete.
        Ether
        Ether is a carbon static potential it is a homogeneous mixture of its two components, Hydrogen and Oxygen energy.
        If stressed between two potential differences the two componets (as in magnetism)North (Hydrogen energy) and South (Oxtgen energy) we have suction, attraction to the centre which it carbon in the steel rod!
        EVERYTHING is made using this process the Trinity of the Three H and O Plus the carbon static potential all matter comes from this place.
        Like a number eight on its side 8 the center is the stressfield.
        All magnetic action is indepentent of pressure of air and occurs also in the vacuum. So magnetism is a state of space devoid of matter.
        i.e. A state of the Ether
        Please everyone read:
        Karl Schappeller The Physics of the Primary State of Matter
        I have a copy if people would like it please tell me where to upload it,
        It is very important for understanding the Ether and the relationshionship with Matter and Consciousness.
        Bx
          The potential difference is key.
          Look at the Atom Not merely a convenient schematic planetary supposition of the electron revolving round a nucleus.
          But a Dense entity whose space is vacumm.
          the kernel and the shell functioning as a whole the nut.
          In the case it is the hydrogen core in the glowing state and its cold complementary oxygen stressfield, the living Atom! No other exists in Nature, it is the creative entity of the life energy or Biomagnestism.
          Look at the Sun Hydrogen core and the oxygen stressfield.
          Hydrogen and oxygen are the north and south of the magnet, the material of the magnet is carbon,
          The ether is a latent potential carbon, stress it and you get Hydrogen and oxygen (before it turns in to Matter)the north and south of the magnet.
            Need To Talk Primary Physics
            This thread is the most important thread here, if WE understand the Ether WE understand how to use it.
            We NEED TO TALK PRIMARY PHYSICS Not Secordary or Present Physics, because its deals with the secordary states of matter and their Functioning.
            Like the magnetic field is in PRIMARY PHYSICS because its in a PRIMARY Ether state Not the function of it but the makeup of it that holds it in place.
            Potential Difference; all thing have Potential Difference
            Electricity is Unpolarised magnestism;polarised it you get + and - or PRIMARY PHYSICS H and O of the stressfield.
              Chapter 1 Aether - The Quantum Key
              Chapter 1 - AETHER
              "The first philosophy (Metaphysics) is universal and is exclusively concerned with primary substance."
              - Aristotle (340BC)
              The Aether that I share in this book is the smallest irreducible stuff that we know of. Everything is fundamentally composed of and interacts with this Aether in one way or another.
              Conventional science believes that the existence of the Aether has been disproved. This is a flawed belief based on a very old test that was seriously flawed and I give references to this.
              If you are an energy healer, researcher or just want to know about these things, the Aether is what you need to learn about. It is an infinitely existing gaseous fluid made of potential particles that are smaller than the smallest subatomic particles. This is where all of our life potential comes from.
              The Quantum Key
              RPX & MWO http://vril.io
                If you have two magnets, and hold them a half an inch apart so they are attracted to one another, the aether becomes rarefied between the two. This polarizes and creates a low pressure zone in the aether, which is what causes the the two magnets to be "pushed" together.
                This same type of thing happens in a Bedini coil when hit with a pulse. The Bloch wall is pulled apart, creating a low pressure zone in the aether, which is then equalized by what Bearden calls "energy from the vacuum".
                Stress the aether and harvest the energy, that's the way to get limitless power.
                Ted
                  Aristole
                  This is from my Alchemy studying
                  Aristole held that the four elements had two qualities, either hot (Hydrogen energy)or cold (Oxygen energy) PRIMARY PHYSICS and wet or dry (Secordary or Present Physics).
                  Earth is cold and dry;
                  Air is hot and wet;
                  Fire is hot and dry;
                  Water is cold and wet;
                  If you cross the stressfield of H and O this changes the Secordary or Present Physics
                  Fire crossing the stressfield of water,water is a resistor the water will boil.
                  Arron will be reading your book after Karl Schappeller The Physics of the Primary State of Matter.
                  I now understand the green glow of the EV gray Tube(bio-magnetic energy)
                    What is aether
                    I really dont know what aether is. I think first we have to identify its key behaviours. Sure we can go off what others have said but we need a way of experimentally proving and showing that it does behave this way. Peter mentioned that he placed a glass of water in an orac and after 30 hours pulled it out and place a rose in it whose petals would fall off withing 30 seconds apparantly due to the property that lower potential flows to higher potential. This is a nice experiment. I would like to see more like this and more direct. Though it could be that the lower potential is flowing to the higher being the reason for the petals fulling off we do not know this for sure as we cannot see the actual movement.
                    Coming up with experiments is key
                      the sg fan experimentally proving Ether is filling the battery
                      YouTube - Maybe negative resistor
                      read Karl Schappeller The Physics of the Primary State of Matter and you will see why
                      Your friend is your needs answered.
                      He is your field which you sow with love and reap with thanksgiving.
                      And he is your board and your fireside.
                      For you come to him with your hunger, and you seek him for peace.
                      Kahlil Gibran
                        No Proof
                        Hi Bodkins we just are under the impression that it is the aether that supples extra energy to the sg and other. It is like flicking a switch see extra energy come out the end and announcing that it is due to such and such even though having no direct proof. There needs to be more fundamental
                          Tesla said that in closed loop circuit, aether move from positive to negative. This force the electron move the opposite way. I think Bearden mention that proton also move too but in much harder way.
                          I think gravity happen because earth radiating aether. While atom being showered by aether it will try to move to the opposite direction of aether, which is go down. I think this what make aether generating / absorbing device has levitation ability. it absorb or generate aether thus reduce gravity.
                          and I think god created this world with many level of aether. Don't know which level gravity is, which level radiant energy is, which level fire is, which level light is.........
                          Currently agree with Dale Pond - Keely, if you trace it to the smallest particle, you will find nothing. World is created from nothingness. What we experience, like seeing things, smell, touch, kick, is what matter do in atomic level.
                          • #14
                            Bodkins, aaron and dmonarch
                            @bodkins, email to my gmail
                            @aaron, maybe nxt pay
                            @dmonarch, the proof is in the pudding. Do we need to prove the air exists by making bubbles when we can see it moving the treetops?
                            @ Sucahyo, tesla said aether moves pos to neg? I was thinking that for a long time.. Remember bodkins how the dual diodes to actual ground increased brightness of neon? And I've been thinking of it recently again, because since electron movement is opposite to traditional notation; how do the electrons coming off the battery negative 'know' to have high voltage before they get to the coil?
                            The voltage / polarity of aether spin is the longitudinal wave that travels in the instant of switch closure.
                            Much love to all,
                            Ben
                            • #15
                              Not enough
                              Hi Inquorote. Nice analogy however I have yet to see any such direct action like you mention, just assumptions. Dont get me wrong I do think there is an aether. I would just like to see the experiments to prove its nature. Such as flowing from lower to higher density, etc.
